| PotatoHead202... |
 PotatoHead202... Scooby Slapper
 Posted: 22:17 - 04 Mar 2020 Post subject: CBF500 ABS - 30 MPG |
I've got a 2006 Honda CBF500 ABS that I use a lot for commuting through town to work. It's got 66,000 miles on it. In the roughly last 1000/1500 miles it's had the carbs cleaned, seals replaced, new boots, new air filter, plugs and oil/filter.
My commute is about 6/7 miles each way through Reading to work but it is taken on the occasional longer jaunt.
I'm getting quite annoyed/suspicious of the fuel economy which seems to be just over 30mpg. 14.72 litres of Shell V Power (i realise v power is overkill but it doesn't excuse the awful economy) and the fuel light is coming on around 100 miles. Now although I accelerate fairly briskly most of the speed is around 30mph due to it being urban with one or two faster stretches to 40mph.
There is absolutely no discernible loss in power and regardless of how cold it is outside it starts with the choke first time every time and idles without issue.
Chain is adjusted correctly, new T31 tyres, brakes are clean and not binding, standard jets/filter/silencer. It does backfire a bit when I've pulled up to the lights and give it a rev.
Any ideas on what this could be? Worn jets maybe? Valves were done about 2000 miles ago. I'm told from other owners that i should be expecting almost 60mpg - ok, maybe not in town, but 30 is taking the piss. ____________________ Suzuki V Strom 1050XT, Honda CBF500 ABS, |
| Easy-X |
 Easy-X Super Spammer
 Posted: 23:20 - 04 Mar 2020 Post subject: |
30?! May as well get a car! At one time I had a Golf GTI, quite horrifying when I calculated it did 16 to 25 mpg
If it was running really rich I'd have thought you'd have already noticed a significant performance drop-off. That and a heady waft of petrol from the exhaust all the time.
My money's on fuel leaking away somewhere. Notice any patches on the ground when it's left standing? (Dry concrete surface is helpful.)
Nothing while standing? Worth checking the carb bowl overflow pipes while running. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| NJD |
 NJD World Chat Champion
 Posted: 23:41 - 04 Mar 2020 Post subject: |
I own the 1000, but don't know much about the little 500. Can the bikes ECU be read for fault codes by your local shop? Can't find a manual with MIL codes for this model, seems odd. Carb's on a bike that has ABS is unique.
Guy on the 1000 forum has mpg issues and a scan found three issues that could all be contributing factors.
At that mileage I'd be careful how much money you're willing to throw at it before taking a cut, or pleading ignorance, and P/X'ing it for something else.
You mention the work the bikes had done, but was the bike fine before the carb rebuild or filter change?
If you can remember the last time it ran fine I'd take the work its had done since then one by one. May be unrelated, but maybe not. ____________________ The do it all, T̶h̶e̶ ̶b̶r̶o̶k̶e̶n̶ ̶o̶n̶e̶,̶ ̶T̶h̶e̶ ̶b̶i̶g̶ ̶l̶u̶m̶p̶,̶ ̶C̶h̶o̶n̶g̶ ̶N̶o̶o̶d̶l̶e̶ |
| Riejufixing |
 Riejufixing World Chat Champion
| Riejufixing |
| Polarbear |
 Polarbear Super Spammer
 Posted: 23:54 - 04 Mar 2020 Post subject: |
30mpg, Jesus, I get better in my Jaguar.
1st thing, 6 miles will hardly get the bike warmed up properly. How much idling is there when doing that journey?
If you fill it up and go for say a 50 mile ride on decent roads do you still get that mpg?
If you don't have an obvious fuel leak and the exhaust doesn't stink of unburnt petrol then you have the choice of digging deeper, ie spending money on a decent shop checking it out. They will have the gear to check exhaust gasses, air/fuel flow, compression etc.
Or as said, you decide that 66000 miles is a good innings and it's time to change. For a 6 mile commute I's be looking at a small scooter and a bigger bike for fun times only. Some would say push bike, but I'm not a sadist so maybe an electric assisted push bike.  ____________________ Triumph Trophy Launch Edition |
| wr6133 |
 wr6133 World Chat Champion
| blurredman |
 blurredman World Chat Champion
 Posted: 09:38 - 05 Mar 2020 Post subject: |
Keep track of the mpg properly..
Fuelly.com
Also- Checked the oil level and that petrol isn't getting into the engine when standing? ____________________ CBT: 12/06/10, Theory: 22/09/10, Module 1: 09/11/10, Module 2: 19/01/11
| 2wheelLover51 |
 2wheelLover51 Two Stroke Sniffer
| PotatoHead202... |
| PotatoHead202... |
 Posted: 15:08 - 05 Mar 2020 Post subject: |
So slightly oily plug but also carbon build up . What oil there is seems to be almost coming from above.
No blue smoke, just some steam after a cold start up. Absolutely reeks of fuel around the exhaust though. ____________________ Suzuki V Strom 1050XT, Honda CBF500 ABS, |
| Polarbear |
| PotatoHead202... |
| jaffa90 |
 jaffa90 World Chat Champion
| PotatoHead202... |
| sickpup |
 sickpup Old Timer
| PotatoHead202... |
| sickpup |
 sickpup Old Timer
| PotatoHead202... |
| sickpup |
 sickpup Old Timer
| PotatoHead202... |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| sickpup |
 sickpup Old Timer
| PotatoHead202... |
| Robby |
 Robby Dirty Old Man
The last post was made 5 years, 342 days ago. Instead of replying here, would creating a new thread be more useful? |
