cbr 600 01 not cranking or fuel pump priming
jerry gerbil
PostPosted: 19:29 - 07 Mar 2020    Post subject: cbr 600 01 not cranking or fuel pump priming Reply with quote
as title says all lights work, if you jump the starter solenoid it cranks and if you put battery to fuel pump it primes relays are good at a loss ECU fried ?
Nobby the Bastard
Harley Gaydar
PostPosted: 19:45 - 07 Mar 2020    Post subject: Re: cbr 600 01 not cranking or fuel pump priming Reply with quote
Have you checked the fuses?
Triumph Sprint ST 1050
sickpup
Old Timer
PostPosted: 19:45 - 07 Mar 2020    Post subject: Reply with quote
Does it have HISS fitted?
Islander
PostPosted: 19:51 - 07 Mar 2020    Post subject: Reply with quote
It could be the fuel cutoff relay.
PostPosted: 19:59 - 07 Mar 2020    Post subject: Reply with quote
This. ^^ Is the HISS light coming on or flashing a fault code.
Do you have the kill switch on? Laughing
jerry gerbil
PostPosted: 20:14 - 07 Mar 2020    Post subject: Reply with quote
yep have checked all fuses relays are good hiss light goes out bank angle sensor checked unplugged cleaned every connector I can see no codes flashing up totally stumped
sickpup
Old Timer
PostPosted: 20:30 - 07 Mar 2020    Post subject: Reply with quote
Well you could always answer my question, does it have HISS on it and further questions have you ever had it running and if so are you using the normal key?
Is the kill switch in the on position?
The trick here is to answer the questions I ask as they are relevant and ignore any questions asked by Jaffa90.
xX-Alex-Xx
PostPosted: 20:58 - 07 Mar 2020    Post subject: Reply with quote
You've got it in neutral, kickstand up, and killswitch set to run? Stupid questions, but always start with the basics Wink
DILLIGAF
jerry gerbil
PostPosted: 06:32 - 08 Mar 2020    Post subject: Reply with quote
yes it was running till yesterday morning yes it has Hiss yes original key yes kill switch in normal position
there is also power getting to ecu ,fuel pump relay (relays are good) and starter relay
PostPosted: 06:48 - 08 Mar 2020    Post subject: Reply with quote
Alarm/immobiliser fitted?
Easy-X
PostPosted: 12:46 - 08 Mar 2020    Post subject: Reply with quote
On my Honda if I go to put it in gear and the stand's down it cuts out. So that's the neutral (or shift) sensor and kickstand switch it must be looking at.
Worth checking both of those switches/sensors and the associated wiring.
sickpup
Old Timer
PostPosted: 14:46 - 08 Mar 2020    Post subject: Reply with quote
So now we know the basics.
The fuel pump should prime as soon as the ignition is on, this would be a combination of the key being turned on and the kill switch being turned on. Flicking the kill switch on and off a few times the pump will re-prime.
First thing to check is power is going through the kill switch. then that things like the side stand switch and the neutral switch are all working.
Other than when priming the fuel pump only gets power when the engine turns over so you need to connect a multi meter to the relay to check its getting power in and power out. Checking that there is power going to the relay will confirm if the HISS system is working, if it gets power it is, if not it isn't.
Also check there is a spark.
Should the HISS light on this model go out when the ignition is switched on and does it?
Has the chip fallen out of the key?
Is the antenna for the key chip still connected?
jerry gerbil
PostPosted: 13:28 - 09 Mar 2020    Post subject: Reply with quote
was the diode in ignition barrel /hiss that drops current down to 9v to ecu but just bought a zxr 900 so ill fix when I get around to it thanks for all the suggestions and advice was very helpful
sickpup
Old Timer
PostPosted: 19:14 - 09 Mar 2020    Post subject: Reply with quote
This suggests the reg/rec has died.
How exactly did you work out it was the diode? Without an obvious reg/rec failure this isn't something that anyone would check as they rarely if ever just fail.
jerry gerbil
PostPosted: 19:35 - 09 Mar 2020    Post subject: Reply with quote
the diode in the hiss is supposed to drop the current to 9v if you look on internet about pink wire from ignition it should come up took a lot of looking but its out there
ThatDippyTwat
PostPosted: 20:51 - 09 Mar 2020    Post subject: Reply with quote
Current? 9v? That's not how it works.
Current is measured in amperes (amps). Voltage is measured in, unsurprisingly, volts. There's also a good chance you are referring to a resistor and not a diode, but I CBA to look at schematics for bikes I don't own.
I suggest you learn a little more before lecturing people.
jerry gerbil
PostPosted: 21:05 - 09 Mar 2020    Post subject: Reply with quote
wasn't lecturing sorry I put diode instead of resistor don't worry I wont bother you anymore bye but thanks to all who tried to help
The last post was made 6 years, 219 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 90.77 Kb
