Are Scooters Safer?
CorriganJ
PostPosted: 11:21 - 08 Mar 2020    Post subject: Are Scooters Safer? Reply with quote
I see a ton of people in Madrid riding scooters without any protective gear (okay helmets are mandaory, but most do not cover the chin. Who needs a chin anyway?), but most people on motorbikes here do wear some sort of gear.
I was wondering if this is just because people with scooters are less "into" the bike scene and therefore don't invest in the gear, or if they actually don't need as much?
Presumably both travel at about the same speed (30mph in the city centre, hard to do more anywhere around here) but one thing that occured to me is that if a scooter falls on you, it's much less likely to trap or break your legs or ankles as... well... there is a massive huge gap where your legs go.
I don't know. Just general musings really. Also, I'm tempted to buy a Vespa PX while I'm here just for the giggles, and because I feel like a scooter might be more practical for city living. Or would I be better off with an actual motorbike? Should I just a touring bike down from the UK for a few months?
PostPosted: 11:38 - 08 Mar 2020    Post subject: Reply with quote
I'd say they are more dangerous. You have more control of a bike because it has footpegs, it is more stable because it has bigger wheels and better suspension and it has more road presence so car drivers are less likely to take the piss.
The bike doesn't generally land up on top of you unless you fall over at walking pace or less.
MCN
PostPosted: 12:23 - 08 Mar 2020    Post subject: Reply with quote
Italian Scooterists are not in the same sphere as Scooterists of other more sophisticated euro nations.
For some reason they appear follow a 1950s road traffic act (for when the roads were much quieter).
I don't think there is any policing and obviously they pay for (buy) the CBT pass cert.
Only a tool passes traffic on the wrong side of the road going around a bend when there is no escape space.
They rely heavily forntheir safety on the better nature and patience observed in other road users.
That's Italian Scooterists.
Apart from that, the only 'safe' aspects are possibly better protection from the elements around the legs.
But the performance is shite.
I think they handle like a fair ground dodgem car. And some look similar to a dodgem car too.
xX-Alex-Xx
PostPosted: 12:57 - 08 Mar 2020    Post subject: Reply with quote
Doesn't matter what you're riding (sportbike, scooter, bicycle).... dragging your uncovered skin down tarmac at 30 mph feels the same no matter what you just came off ....
DILLIGAF
PostPosted: 13:08 - 08 Mar 2020    Post subject: Reply with quote
I think they are because these scumbags in London that drive around with no helmets on hardly ever seem to get deaded, sadly.
Triumph Trophy Launch Edition
MCN
PostPosted: 13:46 - 08 Mar 2020    Post subject: Reply with quote
Maybe they need to be pressed harder into making a mistake then.
Gene pool clean-up.
Teflon-Mike
tl;dr
PostPosted: 14:20 - 08 Mar 2020    Post subject: Re: Are Scooters Safer? Reply with quote
CorriganJ wrote:
Are Scooters Safer?
Safe-ER? Safer than what?
Dancing with a rabib Alsatian? Smoking crack cocaine? Crossing the champs-de-lise? What?
Its all a rather Daz washes Whiter connundrum.... yes it probably does.. wash whiter than say mud, but probably not as white as bleach, which probably isn't so great if what your washing started orange! It's all rather relative!
Scooters tend to have step-through frames, so the engine is a bit harder to drop on your leg, but by the same token, it also tends to be at the back, and all sprung weight and supported by diddy little wheels, so it's more likely to fall over in the first place... pays your money and take your chances...
No, scooter's aren't inherently 'safer' than anything else. Safety is what you put IN your head, not what you put your head in! Is a crash helmet any safer than a lion's mouth? Its all down to the rider, NOT the type of bike.
barrkel
PostPosted: 04:46 - 09 Mar 2020    Post subject: Reply with quote
The scooter shape doesn't save you much from getting stuck between the bike and the road. I've crashed maybe 7 times on scooters, about 3 out of those I got my foot stuck between the scooter and the road. I always wear boots - you will lose skin if you don't.
One crash was a u-turning driver who was letting his friend off at a bus stop - he did a u-turn out from in front of the bus as I was overtaking it. I hit my knees on the handlebars and slid face-first off his bonnet. That was the only accident which had significant visor damage and probably the only one where a full-face made a big difference. On a big bike I might have done more damage to my genitals hitting the tank.
Other crashes where I got caught were typically low speed high-sides, where the rear loses traction, you steer into the slide, then the bike gets traction again and slams over very sharply on the outside of the turn.
Another crash was an Uber driver who changed his mind about where he was going, indicating one way and turning the other. I slammed my hip into the panels on the side of his car, denting them and giving me a bit of a bruise, but I was otherwise uninjured. I could imagine breaking a leg on a bigger bike in that accident.
Scooters are typically ridden in cities, so speeds are lower. All my accidents were between 5 and 20mph. Either you start braking for the hazard when you see it, or you're doing a tight turn and lose traction; either way, you're not normally going super fast. None of my accidents were fast enough to tear my jeans, never mind get road rash.
On a big bike, you've got more acceleration so you can get into trouble much more easily, and if you don't have experience, inappropriate speeding is more likely and it will end up much worse. On the other hand, scooters are more maneuverable and in many cases it's possible to go more quickly through tighter gaps, swapping lanes etc. than on a big bike, so you could get yourself into trouble from agility rather than speed.
It's easier to swerve on a scooter when you have less experience because you can roll the bike with your body weight, but big bikes can swerve quite easily too, you just need to give it enormous sudden counter-steer, which takes a while to develop as an instinct, though some people probably take to it more naturally than others.
I commute in jeans, boots, leather jacket, gloves and full-face helmet. I've had one crash where I was wearing full gear (motorcycle boots rather than street boots, and armoured trousers) and while that crash certainly hurt less, the inconvenience is a poor tradeoff, despite the crashes I've had when not wearing all the gear.
If I had a long motorway commute, I'd probably consider an aerostich suit or similar one-piece textile that is quick to put on and take off. I do however notice myself taking a little bit more risk with high speed corners in the wet when wearing more gear, risk compensation psychology is something to bear in mind.
Claud 14.7 to 1
PostPosted: 22:48 - 10 Mar 2020    Post subject: Reply with quote
Well a scooter crash at 30 mph and a motorbike crash at 30 mph... I guess there is not much difference, but I don't have any real evidence for this. Maybe there are some crash tests online or research on crash tests etc.?
Brakes are generally better on most motorbikes though (generally), so assuming the same low speeds, I think a motorbike would be "safer".
Overall it depends on the rider I think. I would guess many scooter riders in Spain or Italy don't really think of safety protective gear as motorbike riders do. Some do though. I've seen a fair few accidents on scooters in Spain (Barcelona) and it's a real issue.
They jump red lights, move off before the lights change green and don't stop when the amber is showing (try to squeeze though) and at a cross junction when both parties do this, it's pretty much a guaranteed crash.
1198
PostPosted: 03:10 - 11 Mar 2020    Post subject: Reply with quote
The bloke who came zooming past me (I was walking!) on a step thru earlier who’s idea of protective clothing was a pair of shorts - in March, in Cumbria. Brave, very brave. Not my idea of safe but there you go. I wouldn’t ride like that in any season personally...
A100man
PostPosted: 11:19 - 11 Mar 2020    Post subject: Reply with quote
'Don't be an amber gambler..' !!
https://www.youtube.com/watch?v=H4TDEPP1R9Q
bhinso
PostPosted: 16:13 - 11 Mar 2020    Post subject: Reply with quote
For some reason hat reminds me of the Harry Enfield "Women, for pities sake - don't drive".
Easy-X
PostPosted: 20:49 - 11 Mar 2020    Post subject: Reply with quote
https://www.youtube.com/watch?v=BDtVJiK8Lws
barrkel
PostPosted: 03:24 - 12 Mar 2020    Post subject: Reply with quote
My experience strongly disagrees with that one. Maximum braking force isn't the limit at low speeds, it's doing an endo / stoppie or losing control by losing traction on the front. It's virtually impossible to do a stoppie on a scooter without getting out of the seat, loading the front and using body english to shift momentum forward. The rear weight bias means the rear brake on a scooter does a lot more work, and does it effectively. On Honda scooters with combined braking, I've had multiple emergency stops and never lost the front, whereas I've had several unintentional stoppies on big bikes without ABS, and more than a couple where the rear started to come around after swapping from ABS bike to non-ABS bike (ABS trains you to apply both brakes simultaneously because this works extremely well in questionable traction).
At very low speeds (<10mph) a big bike ought to be able to stop a few cm sooner than a scooter because the geometry enables the front to bite the road more and sooner, but the exact same effect turns into a stoppie and reduces effective braking at slightly higher speeds.
I'd bet that my SH300 (stock mushy Nissins) could stop in a shorter distance at any speed below about 40mph better than my S1000R (firm Brembos). I wouldn't bet a lot, but I'd be very confident there would be extremely little in it and it could easily edge to the SH.
There's no saving idiots. One evening in Stepney while I was wating for a recovery vehicle to pick up my scooter that the police had found after it being stolen, I saw two delivery rider accidents at the same junction, one a C90 and the other a scooter. People in a rush not taking care are a liability no matter what they ride.
dowoziyo
PostPosted: 04:56 - 12 Mar 2020    Post subject: Reply with quote
much more important safety criteria are the condition of the road, driving culture and technical condition of the bike
https://pornogratuitici.com/fr/
Cheers!
megaross
PostPosted: 10:37 - 12 Mar 2020    Post subject: Reply with quote
No, gearless scooter riders are usually just totally unaware of the potential damage they can do to themselves without proper safety gear.
Bike or car, it still buggers you up when a car pulls out on you or knocks you off, or you go sliding down the worlds coarsest sandpaper at 30mph or whatever.
The biggest one I see regularly which I think is absolutely nuts, no gloves. Just baffling - if you don't want to wear gear it's your choice but I always think
1. Are you hands not fucking frozen and covered in dead flies, battered by stones kicked up etc.
2. What do you think happens when you put your hands down and slide on them down the road at 30mph? Bear in mind if they do a full thickness skin graft (amputation is more common) it'll basically render your hand an inflexible numb apendage. To say nothing of how easy it is to shatter knuckles.
'07 Tiger 1050
MCN
PostPosted: 13:06 - 12 Mar 2020    Post subject: Reply with quote
Yeah... there are a couple of units on here who I'd love to shatter some knuckles against. 🙄
PostPosted: 17:33 - 12 Mar 2020    Post subject: Reply with quote
I suspect that would be more a function of the 40kg difference in weight. Even then, I suspect that would be a poor bet. You shoud test it.
PostPosted: 17:43 - 12 Mar 2020    Post subject: Reply with quote
You get grazed palms. It stings reasonably badly for a bit and you have to pick little bits of gravel out for months afterwards.
Hope this helps.
bacon
PostPosted: 21:22 - 12 Mar 2020    Post subject: Reply with quote
My most painful crash to date was a relatively low speed slide, prob 20mph. Thanks to gear I got away with just a very bruised hip/ass.
A scooter can still cause a lot of injury. People on the continent probably just don't give a f rather than it being safer. Seeing the way Europeans ride scooters I'd argue they put themselves in far more danger than the average bike rider in the UK.
adam277
PostPosted: 22:43 - 15 Mar 2020    Post subject: Reply with quote
I slide off my BMW R1150GS at about 30mph and the bike skidded for a good while.
I also headbutted a car. Mr. Green
Zero damage to the bike apart from indicator.
Yet, if the same thing happens to a scooter your spending £££££ on new panels.
Doesn't mean much for the rider though.
I'd say Scooters that have larger wheels are quite safe though.
Smaller wheeled scooters suck on UK roads due to the amount of pot holes.
Bikes: Previous Bikes: Piaggio x8 125: 2012/2013, YBR 125: 2013/2013 BMW R1150GS 2013/2017, Honda CBR600RR 2017/2017, Honda CB500 2018/2018, Suzuiki Address 110cc 2019/2020, BMW R1200GS 2021-2023
Current Bike: Honda CBF 125: current
Claud 14.7 to 1
PostPosted: 23:32 - 15 Mar 2020    Post subject: Reply with quote
Sure, I mean that's why I wrote "generally". I've ridden quite a few scooters and quite a few different bikes. It all depends what machines we are talking about and what the condition of the machine is. There are always exceptions to the "rule".
The Honda SH300 is probably the top end Honda scooter for its physical size and has quite large disk brakes all round (for a scooter), uprated callipers compared to probably 95%+ of the other scooters out there in circulation and certainly the regular scooters which most people use day to day, in general.
I would imagine the latest SH300 models have linked brakes and ABS (as well as uprated brakes compared to most regular scooters). I have no doubt the SH300 has great brakes for its class (I was planning on buying this scooter so I know a bit about it) but also it's a 300cc scooter and the top speed is quite a lot higher than a regular 50cc, 100cc or 125cc conventional or "regular" scooter, which are the ones riding around Madrid for the most part, and in general everywhere really and I think the kinds of scooters we are talking about.
A "regular" scooter with 1 disk brake and 1 drum brake has pretty poor brakes in my experience and I've ridden a fair few. Ok, they do the job - which is to stop the bike reasonably well from a low speed. However, on some "regular" scooters the brakes were such bad quality and in such bad condition that it almost felt like they were doing nothing. On the other "regular" scooters I've ridden it was better, but not by much really.
But even lower end motorbikes (say 400cc upwards) with 2 disk brakes seem to stop far better especially from higher speeds (30 or 40mph) and bikes with double disk brakes up front, certainly.
The regular run-of-the-mill 50cc - 125cc scooter riding around Madrid/other city has pretty average brakes or even poor brakes in my experience, but of course if you take the top of the line 300cc Honda scooter for its size, which is far faster and more expensive, it's another story.
Claud 14.7 to 1
PostPosted: 23:35 - 15 Mar 2020    Post subject: Reply with quote
Hahaha... finally a term used for these people! Laughing Thumbs Up
The last post was made 6 years, 178 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 130.88 Kb
