Spray Painting Air Compressor help
Tp1992
PostPosted: 04:07 - 10 Mar 2020    Post subject: Spray Painting Air Compressor help Reply with quote
Hi,
Sorry if this has been asked before but I just wanted to put the question out there myself to get a answer for the specific model I'm looking at.
So I've been wanting to spray my bike for a long time and now I've finally decided to go a head with it and looking for any advice or info on equipment.
https://www.spraygunsdirect.co.uk/index.php/compressors-kits/standard-compressors/sealey-compressor-24-litre-2hp-6-8cfm-displacement.html#sthash.a1RHHXrC.dpbs
I'm looking to get this air compressor and would like to know if it'll be suitable for what I intend to do. I have a CB600F Hornet and would like to sprey the tank and plastics.
If this air compressor isn't suitable for the job then any recommendations would be appreciated Smile
I have a rough idea of the other equipment I need just not sure on the air compressor, are these things worth buying second hand to save a bit of money?
MCN
PostPosted: 06:53 - 10 Mar 2020    Post subject: Reply with quote
TLD open your link yet.
Have you spray painted before?
Buying the gear is simple. 🤣
Prep, Paint choice and application is a whole barrel of laffs.
Hawkeye1250FA
PostPosted: 10:25 - 10 Mar 2020    Post subject: Reply with quote
Volume not big enough (50L +)
Also what MCN said.
I would suggest borrowing a compressor and buying your own gun (cheap) and have a practice. It may put you off 😁👍
That aside, I find it relaxing - if you have loads of time spare crack on and have a go.
1993 RF400R - 2002 Bandit 1200 - 2012 1250 FA
PostPosted: 13:28 - 10 Mar 2020    Post subject: Reply with quote
More volume is more volume, they go through air very quickly.
Oil-less bearings for preference.
Other considerations are:
1) Spray booth. The overspray makes a horrendous mess. It gets absolutely everywhere (including under doors, through keyholes, up under dust sheets). Also keeps dust off your piece. Ideally a sealed area with ventilation or all that overspray settles again. You can buy popup tent type spraybooths if you don't have an area you can section off.
2) PPE. Proper respirator or forced air ventilator, not just a dust mask. Most especially if you are using 2k paints. Minimum P3 mask for spraying normal paints. I'd want a proper forced air respirator (plugs into compressor, which you locate away from where you're spraying so it doesn't suck in the overspray) or gas mask for 2k coatings. They give off nasty fumes.
Baffler186
PostPosted: 15:05 - 10 Mar 2020    Post subject: Reply with quote
[url]https://www.amazon.co.uk/dp/B074J9LDLB/ref=cm_sw_em_r_mt_dp_U_LX6zEbCWAR31Y [/url]
This one is a 50ltr, higher flow rate, similar price to the one you were looking at
Current: 2009 SV650 S, 1990 Kawasaki GT550
Previous: 2009 CBF125, 1998 GSF600, 2004 FZ6 Fazer, 1978 CB400a Hondamatic
dynax
PostPosted: 15:09 - 10 Mar 2020    Post subject: Reply with quote
Unless you have access to a hefty compressor don't bother, your other option although not as cheap would be using HVLP but for decent kit you are still looking at hundreds Thumbs Up
Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber
megaross
PostPosted: 09:26 - 11 Mar 2020    Post subject: Reply with quote
When it comes to spraying it's kind of waste of time unless you've got a big compressor (think 200l) which is capable of delivering the massive cfm of air required for a long length of time.
Spraying uses 12-18cfm and that is a lot of air. Also remember professional spray guns cause mass air turbulence so having a clean working environment becomes far more important than compared to spray cans.
24l is basically basically enough for blow gun and tyre inflator, maybe a small air ratchet or 3/8" impact. Most air tools that are even worth having you really can't run on something that small, they just aren't capable of throwing out enough cfm fast enough and would pretty much always be running.
Me personally? If a rattle can isn't good enough I'll pay a professional to do it, bikes aren't super pricy to get sprayed professionally anyway.
'07 Tiger 1050
stirlinggaz
PostPosted: 02:39 - 14 Mar 2020    Post subject: Reply with quote
not necessarily.
i started with one of those cheap 25l jobbies for lidl/aldi.
after some practicing & buying a decent hose & good quality hvlp gun i was soon spraying 2 pack single colours on plastic fairings.
seeing as most bikes plastics aint that big, your not actually spraying for that long so the reservoir gets time to "refill".
they turned out far superior to any rattle can job.
biggers definitely better but the wee compressor certainly wasnt a waste of time, far from it.
it was crap with the rattle gun though (one of the reasons i went bigger)
imho its all about the gun, the products (paints thinners etc) & preparation.
cheers,
GAZ
sickpup
Old Timer
PostPosted: 20:15 - 14 Mar 2020    Post subject: Reply with quote
You will struggle running spray guns with large nozzles from a small compressor. You will get away with using a small compressor with a mini HVLP gun but you won't get much runtime between the compressor recharging. Luckily a mini HVLP spray gun is very cheap.
I've used a small compressor to spray Land rover door tops and they came out nicely, much better than using spray cans.
Nowadays I have a 14cfm compressor with a 150litre receiver with moisture filters which will do most things I need but is over the top for a normal home, it's 6' tall and weighs over 100kilos. I also run 3/8ths or 1/2" airline which helps get the air where I want it.
stirlinggaz
PostPosted: 02:38 - 16 Mar 2020    Post subject: Reply with quote
sickpup wrote:
You will struggle running spray guns with large nozzles from a small compressor. You will get away with using a small compressor with a mini HVLP gun but you won't get much runtime between the compressor recharging. Luckily a mini HVLP spray gun is very cheap..
i didnt Very Happy & was full size gun with large & small "bottle" & 2 or 3 different sized nozzles.
BUT i would have if i didnt just do 1 panel at a time.
being silly, i didnt have an air fed mask so just using normal particle type (i know i know) .
so to minimise exposure had extractor fans on & was only in the room for a minute or so.
enough time to do 1 coat on 1 panel.
took me ages (2 or 3 coats of primer, colour coat & lacquer) but wasnt in a hurry & turned out surprisingly good for my 1st attempt (i got a lot of compliments when bike was back together) especially after compound etc.
never once did i have to wait on the tank refilling/recharging.
stuck to that method even when i got another compressor & decent mask but i agree a wee 25l would be no good for large surface areas but like i said most bike plastics break down into quite small bits & biggest is usually tank.
so wouldnt write the wee ones off, theyre great for that 1 off job. i only went bigger after a year or so as decided i liked doing it & bigger definitely makes it easier & quicker.
cheers,
GAZ
The last post was made 5 years, 347 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 73.45 Kb
