Cut Out
J30NNN
PostPosted: 18:53 - 14 Mar 2020    Post subject: Cut Out Reply with quote
Bought a little Yamaha YFZ 125r as a stop gap on Monday. All fine on the test ride so parted with the cash.
Went to the fuel station to fill it up on Tuesday. Fueled up, went to put it into 1st and it cuts out. A friend suggested that it was the side stand switch so collected the bike in a van and replaced that. However, it made no difference.
Clutch lever has no purchase (feels disconnected) and still experiencing the same issue. Any thoughts or advice? Shocked
martin734
PostPosted: 20:02 - 14 Mar 2020    Post subject: Reply with quote
Have you checked the clutch cable? Were there any noises coming from the engine/gearbox while you were riding it?
Current bike: ST1100 "Big Red"
J30NNN
PostPosted: 05:51 - 15 Mar 2020    Post subject: Cut Out Reply with quote
I did and the cable is in one piece. No noises as I was riding it.
jaffa90
PostPosted: 10:59 - 15 Mar 2020    Post subject: Reply with quote
Did the bike jolt forwards when selecting fist gear?
J30NNN
PostPosted: 11:25 - 15 Mar 2020    Post subject: Cut Out Reply with quote
Jaffa, yes, exactly what happens...
Nobby the Bastard
Harley Gaydar
PostPosted: 11:49 - 15 Mar 2020    Post subject: Reply with quote
Put it in first, pull the clutch in and see if you can roll the bike along.
Triumph Sprint ST 1050
J30NNN
PostPosted: 08:42 - 17 Mar 2020    Post subject: Cut Out Reply with quote
No luck Nobby. Took it to a mechanic who reckons that the clutch cable has not been installed properly.
Easy-X
PostPosted: 10:47 - 17 Mar 2020    Post subject: Re: Cut Out Reply with quote
Did he also ask if you wanted the headlamp fluid topped up? Laughing
Seriously though, a clutch cable is about the simplest control on a bike (throttles tending to be dual cable and brakes all hydraulic these days.) One end attaches to the lever, the other end to the arm on the engine case, it's very hard to get wrong!
Let's just say if it was me I'd require "further clarity" to the mechanic's statement Thinking
xX-Alex-Xx
PostPosted: 12:20 - 17 Mar 2020    Post subject: Reply with quote
You've adjusted the cable at the lever so there's only about 1cm of free travel at the end of the lever before the cable starts moving yeah?
DILLIGAF
Riejufixing
PostPosted: 13:13 - 17 Mar 2020    Post subject: Reply with quote
https://www.manualslib.com/manual/612268/Yamaha-Yzf-R125.html?page=53#manual
The last post was made 5 years, 329 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 61.03 Kb
