| Gazz |
 Gazz World Chat Champion
| NJD |
 NJD World Chat Champion
| Nobby the Bastard |
| cresad |
 cresad Nova Slayer
| Gazz |
| Gazz |
| Teflon-Mike |
 Posted: 21:10 - 15 Mar 2020 Post subject: |
| Gazz wrote: | | Nobby the Bastard wrote: | Sounds.like it needs.bleeding. |
Tried that, I posted a thread on here a while back thinking that was the issue but there is definitely no air in the system.
Some also suggested changing the master cylinder which was also done. |
If the lever has full travel, or most of, then either there's air in the lines that's squashing, rather than the piston moving; there's no fluid in the lines, or the fluid is escaping...
If the brake was just a bit spongy, maybe you could use a quick-fix or bodge.. this sounds like something far more dire, and time for an overhaul.
I would start with a fluid-flush and bleed, make sure that there REALLY is no air in the lines. But cutting to the chase, I would likely pull the calipers and strip, expecting to renew both pistons and seals and bleed nipple(s), because when the pistons get old and manky and start sticking, its usually a sign that the surfaces have gone and they are dragging crap into the seals and chewing them up...
Your call, but I would say that you are probably way beyond and quick-fox bodgery here, and the things need a thorough going over... I mean, brakes DO tend to be pretty important at the end of the day.. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| martin734 |
 martin734 Spanner Monkey
| sickpup |
 sickpup Old Timer
| Easy-X |
 Easy-X Super Spammer
| Gazz |
| sickpup |
 sickpup Old Timer
 Posted: 23:01 - 15 Mar 2020 Post subject: |
If the pistons aren't moving, the lever should be soild.
If it isn't, there is a leaky seal or air in the system.
But hang on. What EXACTLY is happening? You say only on the first press? Does that mean it then firms up on subsequent presses? Does the brake engage then? What then, do you ride it a bit and it goes loose again? Because that can be a sign of warped rotors. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Hong Kong Phooey |
 Posted: 23:22 - 15 Mar 2020 Post subject: |
Yes, sounds like pad knockback. Check runout on disc(s).
What bike? 2010 Sprint?
If you're rebuilding, due to sticking pistons then you might be able to salvage the pistons and just change the seals.
https://www.ebay.co.uk/itm/164015584664 ____________________
'81 CG125, '97 FZS600 : '99 CBR600F4, '09 KTM RC8 |
| Gazz |
 Posted: 00:20 - 16 Mar 2020 Post subject: |
Hope this works :
https://vimeo.com/397859043
Its been like that since I bought the bike. Pervious owner said that he had just fitted new discs and pads and put new fluid in it (blue stuff) so he obviously knew that there was some sort of issue and tried to rectify it before reselling the bike on to me.
Without going into detail about the previous owner, (that's for another day to discuss) I'd just like to get the issue sorted so that I can finally use the bike.
Firstly I bled the brakes, thinking that was the issue, then bought and fitted new master cylinder (2 of) , rebled, exact same issue there.
Checked pistons, some of them don't move; but all move when you hold the one down that moves freely and pump the lever. |
| Gazz |
| sickpup |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 sickpup Old Timer
| Gazz |
| Easy-X |
| Hong Kong Phooey |
| jaffa90 |
 jaffa90 World Chat Champion
| sickpup |
 sickpup Old Timer
| Nobby the Bastard |
| Hong Kong Phooey |
 Posted: 14:07 - 16 Mar 2020 Post subject: |
| sickpup wrote: | | Hong Kong Phooey wrote: | First pull of the lever is ok, but after that the rotor is pushing the pads out so second pull requires longer lever throw, on an internet forum without sight of the bike, that sounds feasible no? Pad knockback doesn't necessarily have to be warped discs. |
No it isn't feasable. All discs suffer from uneven wear, you actually need it to a small degree to stop the pads binding on the disc but any uneven wear/warpage large enough to knock the piston back far enough to require more than one pull on the lever would be felt while riding.
Ok, I'll bite. To what degree do Brembo machine in this uneven wear on brand new discs?
I did also state that warped discs might not be the only cause.
| sickpup wrote: |
| Hong Kong Phooey wrote: | Also ABS bleeding is a bitch. There's a function in TuneECU to trigger an ABS bleed. |
No it isn't, excusing Harleys which have a normally closed system as far as I am aware every other manufacturer uses a normally open system so bleeding should be no different to on a normal system.
The TuneECU setting is to flush the ABS pump.
Flushes out what exactly?
https://www.thetriumphforum.com/threads/abs-bleeding-breaks.14130/
| sickpup wrote: |
| Hong Kong Phooey wrote: | IIRC blue brake fluid was phased out/ banned a while back as its not DOT4. |
The blue brake fluid was banned in the USA at least because the blue colouring was carcinogenic but a quick google says it is still available here and is indeed DOT4 under the name ATE TYP200 |
Not just US. I believe if you can get it, it's old stock. Probably marked not for road use too.
"Description
In our opinion, this is the best brake fluid on the market! This product has superceded the old racing blue brake fluid ATE TYPE 200 Amber Brake Fluid is designed to excel within the extreme demands made on a race vehicle or by high performance drivers and exceeds all DOT4 standards." ____________________
| sickpup |
 sickpup Old Timer
 Posted: 14:16 - 16 Mar 2020 Post subject: |
| Hong Kong Phooey wrote: | Ok, I'll bite. To what degree do Brembo machine in this uneven wear on brand new discs?
Not just US. I believe if you can get it, it's old stock. Probably marked not for road use too. |
In order.
I have no idea.
Brake fluid. Your link actually states that the brakes can be bled without the software. Think of it this way when the bike is switched off the brakes still work. Obviously on a Harley the brakes never work
The blue stuff is/was only non-compliant to DOT standards due to the dye, it was still DOT 4. |
The last post was made 5 years, 320 days ago. Instead of replying here, would creating a new thread be more useful? |
