Indicator problem
reggyrat
PostPosted: 20:00 - 16 Mar 2020    Post subject: Indicator problem Reply with quote
Hi,I am a newly registered BCF member and wondered if any of you knowledgeable owners could help.My scooter is a Yamaha Majesty YP400
The right indicator works ok,but none of the lights work when switching to the left position.I assumed that one of the bulbs on the left side had failed.However,when I activated the emergency switch,all the indicator lights work fine.Obviously then it isn`t a defective bulb to the left side.
Has anyone any idea please?
Nobby the Bastard
Harley Gaydar
PostPosted: 20:05 - 16 Mar 2020    Post subject: Re: Indicator problem Reply with quote
It's either the switch or the wiring.
Triumph Sprint ST 1050
reggyrat
PostPosted: 20:57 - 16 Mar 2020    Post subject: Reply with quote
Thanks,I will look into it when I get the chance
steve the grease
PostPosted: 01:56 - 17 Mar 2020    Post subject: Reply with quote
The last guy is absolutely right. It could be as simple as a connector unplugged/dirty connection. One of those cheap testers ( Lidls had them on last week) with loads of LEDs is really useful for tracing a fault like this, theyre only a fiver ( you can get a full multimeter for a tenner) which will buy you about 10-20 minutes of a mechanics time .
find out the indicator feed wire colours ( Hondas use orange and light blue, dunno about other makes. ) Trace back as near as possible to the switch .
reggyrat
PostPosted: 19:49 - 17 Mar 2020    Post subject: Reply with quote
Much obliged for your reply.I have a multimeter,so I will take your advice when I can access the scooter(it`s staying with a neighbour at the moment,don`ask,it`s complicated!!!!)I have time as the MOT isn`t due for a month or so and I am very busy,but will have a go as soon as.
Thanks
droog
PostPosted: 08:27 - 18 Mar 2020    Post subject: Reply with quote
All good advice from the folks above - I have done a lot of winter riding in the past and the salt water and damp conditions can lead to electrical switch problems - switch contacts can become furred up (verdigris) and start to work intermittently and eventually fail or the wiring itself can become frayed or break (this can happen with wiring that interacts with the handlebars as the constant right to left movement can fray and break wires over time).
If a handlebar switch is not working then personally I would open up the switchgear clamshell and physically inspect the switch - if it looks furred up and dirty then give the switch a squirt of electrical contact cleaner and remove the dirt/virdigris gently with a small jewelers file/pick toothbrush - or whatever does the job.
If this does not fix the problem then as mentioned take a look at the connector block - if the wiring here looks dirty or corroded then it might be necessary to remove the wiring from the connector block (again you will need a small pick to remove the connector from the block) - assess the condition of the terminal and clean/replace as necessary.
If the work above is not necessary or does not fix the problem then as mentioned you will need to get the multimeter out and do more extensive checking of the electrical system for breaks in the wiring or problems further down the line - but it is probably just a dirty switch or connector that is causing the problem.
reggyrat
PostPosted: 19:13 - 18 Mar 2020    Post subject: Reply with quote
Thanks Droog,
what a helpful group BCF is turning out to be.You have given me some points (no pun intended!) to look at,when I get the chance.Obviously a strip down of the switch is a must,but I was wondering if you have found WD40 to be suitable for lubrication and contact cleaning in this situation.
Anyway,thanks for your thoughts on the problem
Nobby the Bastard
Harley Gaydar
PostPosted: 19:23 - 18 Mar 2020    Post subject: Reply with quote
Wd40 is an oil. It wont clean or get rid of corrosion.
Switch cleaner is your friend but won't get rid of corfosialon.
droog
reggyrat wrote:
Thanks Droog,
No worries mate, regarding the contact cleaner - personally I would use a dedicated electrical contact cleaner for this job - funnily enough WD-40 have their own electrical contact cleaner, I've got a can myself to clean my bike's electrical switches and contacts if they start playing up:
https://wd40.co.uk/specialist/fast-drying-contact-cleaner/
reggyrat
PostPosted: 19:36 - 18 Mar 2020    Post subject: Reply with quote
Thanks Droog,I will bear that in mind.
The last post was made 5 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.24 - MySQL Queries: 13 - Page Size: 63.63 Kb
