| Freddyfruitba... |
 Freddyfruitba... World Chat Champion
| Riejufixing |
 Riejufixing World Chat Champion
| Suntan Sid |
 Suntan Sid World Chat Champion
 Posted: 21:19 - 16 Mar 2020 Post subject: |
Had the same problem a few weeks ago.
Car wouldn't start, charged the battery up, off we went!
Couple of days later same thing, but this time we needed to leave the car in an airport car park for a few days, so it was new battery time.
Went to the local motor factors and told him what I wanted, he asked "how old the battery was", "8 years old" I said.
He laughed and said "you're lucky, they normally last 5 or 6 years"
I didn't fit the new battery straight away, stuck with the old one, and kept the new one in the boot. The old battery was flat after four days in the car park, so put the new on.
Charged the old one up again, it lasted a couple of weeks.
From fully charged, if you attach a meter, you can see it losing charge, about half a volt every couple of hours. ____________________ "Everybody needs money, that's why they call it money!"  |
| Nobby the Bastard |
| Riejufixing |
| steve the grease |
 steve the grease Crazy Courier
| MCN |
 MCN Super Spammer
| doggone |
 doggone World Chat Champion
| Tankie |
 Tankie Crazy Courier
| megaross |
 megaross Borekit Bruiser
 Posted: 08:56 - 17 Mar 2020 Post subject: |
Test for a parasitic draw. Get your multimeter, black lead to com, red to amps and set it to measure amps.
Disconnect your negative cable and connect your multimeter between that and your battery. Leave it to settle it's tits down if it's a modern car with loads of electronics.
If you've got a draw over 50ma (ish) then it's got a parasitic draw (start pulling fuses to find out where from).
If not then your battery is probably toast, you can do a time analysis on that by disconnecting the battery and measuring the voltage every couple of hours. It'll become obvious fast if that's the case.
Annoyingly I once had a parasitic draw that was intermittent, two wires were shorting in the boot turning the light on but only if the car had shaken them into position so it didn't show on the tests, I only found it by chance. That was fun to find  ____________________ '07 Tiger 1050 |
| Nobby the Bastard |
The last post was made 5 years, 328 days ago. Instead of replying here, would creating a new thread be more useful? |
