graphogen
nickbilljim
PostPosted: 14:59 - 18 Mar 2020    Post subject: graphogen Reply with quote
Hi I have 1986 suzuki savage, the clutch was slipping a bit in 4th gear
I had to take the engine to install a new piston and cam,whilst I was at it I checked the clutch plates they had hardly any ware and a small bit of glazing on 2 of the steel plates
after soaking all the plates in brake fluid for 24 hours I cleaned up the glazed plates with a light abrasive, all the plates look and feel perfect.
I rebuilt the engine and used a small amount of Grophogen on the cam,this bike has a wet clutch (the oil in the sump also lubricates the clutch) now the clutch slips in all gears until warm but it still slips even when warm
I changed the oil to silkolene comp 4 10 w 40 in case the old oil had moly in it.
could either the wrong oil or the graphogen permanently ruined my friction plates?
Can you use graphogen on bikes with wet clutches
many thanks Nick
MaybeGuy
PostPosted: 15:44 - 18 Mar 2020    Post subject: Reply with quote
Did you check the plates for warpage?
Did you check the springs were still in spec?
Is your basket fucked?
Just replace the clutch pack. It's cheap and will save all this messing around.
Riejufixing
PostPosted: 16:11 - 18 Mar 2020    Post subject: Re: graphogen Reply with quote
Can't think why it would be a good idea. I'd be inclined to clean it all off, put it all back together, and check the adjustment.
Might be useful:
https://www.manualslib.com/manual/1165889/Suzuki-Ls650-Savage.html?page=1#manual
PostPosted: 16:15 - 18 Mar 2020    Post subject: Reply with quote
First things first check the clutch cable for free movement and if it has the cable going to the left side of the engine - check the pushrod clearance.
dynax
PostPosted: 16:26 - 18 Mar 2020    Post subject: Reply with quote
Ignore what i said Laughing i should read more Thumbs Up
Mike.
Bikes: Xena, Bridget,Florence
https://www.youtube.com/channel/UCmihUc0xXxYbR4_0l-F1FzA/videos?view_as=subscriber
nickbilljim
PostPosted: 16:44 - 18 Mar 2020    Post subject: Reply with quote
the push rod is 12.5mm as spec
when re-assembled there is a couple of mm play when you move the lever that depresses clutch push rod
they do 3 different push rods, but my plates are not worn, so I should not have to change it according to the manual
PostPosted: 17:14 - 18 Mar 2020    Post subject: Re: graphogen Reply with quote
Please say you didn't actually soak your clutch plates in brake fluid then put them back in your engine.
nickbilljim
PostPosted: 17:28 - 18 Mar 2020    Post subject: Reply with quote
sorry it was brake cleaner
Nobby the Bastard
Harley Gaydar
PostPosted: 17:35 - 18 Mar 2020    Post subject: Reply with quote
In that case they've probably disintegrated. You should only use it to clean the metal plates.
Triumph Sprint ST 1050
PostPosted: 18:53 - 18 Mar 2020    Post subject: Reply with quote
Yes. Soaking in a highly volatile solvent won't have done the friction plates much good. You normally soak them in oil.
The last post was made 5 years, 323 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 64.54 Kb
