Mikuni bds 26 Carburettor
Suzuki intruder
PostPosted: 11:40 - 18 Mar 2020    Post subject: Mikuni bds 26 Carburettor Reply with quote
Hi everyone I’m really stuck I have a sticky carburettor when it’s on full throttle it cuts the bike out. I’ve striped it cleaned it. It’s doing the same thing. Only way it works is when you spray carb spray it revs fine and the plastic black ball thing moves back and forth. The bike is a Suzuki vl125cc the carburettor is a Mikuni bds26 I cant find any secondhand new is £600+
Is there another replacement for their model it’s has to throttle cables one to Push and one to pull.
If anyone can help it would really be appreciated.
Thank you in advance
Easy-X
PostPosted: 13:06 - 18 Mar 2020    Post subject: Reply with quote
That carb has been copied extensively and re-cast from the finest Chinesium Wink I'd take a peek at Amazon, eBay, Aliexpress, etc. and you'll probably turn up something similar.
If it was me I'd just get something like this:
https://www.ebay.co.uk/itm/For-Suzuki-EN125-Marauder-GN125-GS125-GZ125-Carburetor-Carb-Motor-Engines-26mm/163660393280
And see about swapping the throttle wheel thingy that the dual cables connect to from your original to the new one. Feck all money to have a go Smile
But before that I'd strip it and clean it again. This time check every channel for blockages and get the jets, emulsion tubes etc. under a magnifying glass. Also check the black rubber diaphragm for tears.
Suzuki intruder
PostPosted: 18:30 - 18 Mar 2020    Post subject: Reply with quote
Hello Easy X
Thanks for the reply I thought that as well but it also has a throttle body position sensor on it as well.
I’ve been told the carb that on fleebay has a strong enough spring to load it back.
Thanks
Easy-X
PostPosted: 20:44 - 18 Mar 2020    Post subject: Reply with quote
Suzuki intruder wrote:
Hello Easy X
Thanks
Oh dear. Well looking at the pictures of the el-cheapo carb versus the proper VL one it looks like there was a space blanked off where the TPS would be. How do you feel about bodgery Wink
Suzuki intruder
PostPosted: 01:38 - 19 Mar 2020    Post subject: Reply with quote
If it works no harm in a bit of Bodger and badger.
Bhud
PostPosted: 01:34 - 20 Mar 2020    Post subject: Reply with quote
I've got a fair few BDS26 parts, and they're much better quality than the Chinese copies. The float bowls are attached by 4 screws, for a start. The finish is also a lot better. But if the Chinese ones also work, then what difference does it make? Regarding the TPS, I'm unfamiliar with your bike, but the idea is that the ignition timing changes according to throttle position. I never noticed any difference in performance with the TPS ripped out, when the timing was advanced 4 degrees anyway.
nathlx
PostPosted: 22:24 - 18 Jul 2020    Post subject: Reply with quote
Any update on how this went? I am in exactly the same situation, got a (free) suzuki intruder 125, only problem its been sat for 12 years outside.
It almost ran after some cleaning but I stripped the carb and found the choke has siezed into the carb body, and the float slide doesn't move up and down anymore, I think I need a new carb but I cannot find one anywhere except an old one on ebay for 190quid!
I found that the v-star 250 also uses the mikuni bds26 but without the TPS, and with accelerator cable connection on the other side, the chinese imports look good but as you said, all have no TPS!
Is no TPS a dealbreaker? Anyone got a UK source on a vl125 carb? Laughing
The last post was made 6 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.18 - MySQL Queries: 13 - Page Size: 51.26 Kb
