Is there any way of activating the ABS?
Gazz
PostPosted: 00:57 - 21 Mar 2020    Post subject: Is there any way of activating the ABS? Reply with quote
Still trying to get to the bottom of my braking issue and thought that I'd give this a go before I contact the dealership.
Basically I want to try to see if I can activate the abs to see if there might be air in the abs module which would hopefully be pushed out by fluid if the abs kicked in.
Hopefully, this is how the system works.
I've seen someone on another forum saying that you need to take the bike to the dealer for a brake bleed as they need to activate the abs solenoid in the pump when bleeding.
Any suggestions to safely get the abs to kick in?
P. S. The abs light is on on these bikes until they go over 6mph so I'm assuming that you'd need to be doing over that before the light goes out and the abs is functional.
sickpup
Old Timer
PostPosted: 02:50 - 21 Mar 2020    Post subject: Reply with quote
Ride fast and slam on the rear brake.
colink98
PostPosted: 09:10 - 21 Mar 2020    Post subject: Reply with quote
I'm going to suggest the ABS unit is just an inline unit as part of the break system, as such it should not need bleeding as a separate action.
Ride it like you stole it.
The Artist
PostPosted: 09:15 - 21 Mar 2020    Post subject: Reply with quote
I am not sure about this particular bike but on my cars ABS system, if you get air into it, it cannot be bled through use.
It must be plugged in to a dealers controller to activate the valves to flush the air out.
People have tried triggering ABS lots of times and it would make it better but not completely get rid of the air.
Obviously your bike may be different but I would think unless you can find a proper procedure online, then you are going to need to ask a dealer to do it for you.
PostPosted: 10:49 - 21 Mar 2020    Post subject: Reply with quote
My Trophy is a dealer job if you have issues but with the pipework on that it isn't surprising. I think most ABS systems nowadays are so complicated you are pretty lucky if you get away with any home maintenance other than pad changes.
Just to make you feel happier - My Trophy brake pipework.
https://s3.eu-central-1.amazonaws.com/img.partsss.com/models_pdfs_details/11645/triumphtrophy-1215-seabs-system.png
Triumph Trophy Launch Edition
Easy-X
PostPosted: 12:52 - 21 Mar 2020    Post subject: Reply with quote
ABS bleed: the system needs to be "opened" to allow fluid to flow through as if the ABS wasn't there. How easy this is to do depends on the bike. TuneECU app might do it or there might be a "one weird trick" combo of shorting certain wires and turning the ignition X times in Y seconds. Failing that, back to the dealer Sad
Mate at work's just done it on his CBR600RR. He did explain the procedure but I sorta glazed over half way through Shifty
raesewell
PostPosted: 14:49 - 21 Mar 2020    Post subject: Reply with quote
There may be a jumper lead available depending on which bike you have.
Yamaha FJR 1300 Normanton West Yorkshire
Pigeon
PostPosted: 20:00 - 21 Mar 2020    Post subject: Reply with quote
Gazz, what bike is it?
I use a cheap Bluetooth OBD2 device and TuneECU to trigger the ABS solenoid on my Striple.
Prior to this, the method was stamp on the rear brake.
sickpup
Old Timer
PostPosted: 20:19 - 21 Mar 2020    Post subject: Reply with quote
It's almost like I know what I'm talking about. Thumbs Up
Maybe the OP should y'know, just change the master cylinder seals instead of all this messing about.
Gazz
PostPosted: 10:57 - 22 Mar 2020    Post subject: Reply with quote
The master cylinder has been changed.
sickpup
Old Timer
PostPosted: 14:30 - 22 Mar 2020    Post subject: Reply with quote
Yes I noticed that in the other thread but assumed that because you bought 2 you bought 2nd hand ones but you didn't say that so my mistake.
So just to check, you bought a brand new master cylinder yes?
Just and a look at the calipers for that bike and they look like re-badged Nissin's so why not just fit a front master cylinder off a 1989 onwards GSXR750 or 1100? They at least work with thise calipers.
The last post was made 5 years, 298 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 68.56 Kb
