| Amber Phoenix |
 Amber Phoenix Traffic Copper
 Posted: 13:59 - 21 Mar 2020 Post subject: Yamaha FZ6 S2 charging issue - battery, rectifier or stator? |
Got a 2007 FZ6 S2 which broken down a few days ago. Started on button in morning to go to work, started on button leaving work in evening. But half way home (~6 miles), engine management light came on, pulled over, dash died. Wouldn't start, flagged up a error code 46 - 'faulty chargin system'.
Since, I've charged battery and bike started fine, so now I'm trying to diagnose the faulty part(s).
After full charge, battery shows 13.1V. Idling: 12.2V. At 5k, 12.1V.
- According to Haynes, regulated voltage output should be 14.1-14.8V.
Half hour later, battery still started bike. But 3 days later, it was flat - reading 6-7V.
Battery is a good Yuasa, fitted Nov 2018 (so says fill sticker on it).
I checked current leakage, disconneting neg terminal and measuring current between it and battery: zero.
- So I don't believe there's a short or current drain.
I checked regulator, again only getting 12.1V out of it at 5k.
I checked reverse / forward bias on rectifier: all three diodes in each direction check out fine.
I checked stator output.
22V AC at idle, 70V at 5k output.
But resistance across the coils is a bit high: 0.7 ohms.
All three coils are consistent.
- According to Haynes, alternator stator coil resistance should be 0.22-0.34 ohms @ 20C
So now I'm still not totally sure what's knackered.
The battery going flat in space of 3 days implies a duff battery.
Not getting 14+ volts from rectifier indicates something dodgy there.
The high resistance on the stator implies it could be on way out, even if output voltage is high.
Any ideas on narrowing down things more? What parts would you stick your money on? ____________________ Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007
| mentalboy |
 mentalboy World Chat Champion
| Nobby the Bastard |
| Amber Phoenix |
| Amber Phoenix |
| Hong Kong Phooey |
| Amber Phoenix |
| Nobby the Bastard |
| Amber Phoenix |
 Posted: 15:27 - 21 Mar 2020 Post subject: |
OK, I'm getting more and more convinced to just replace all three together, stator, reg and battery and hopefully resolve all charging issues in one go.
Genuine new parts are silly money - £330 for stator, £220 for rectifier!
So, looking at aftermarket stuff on Wemoto, M&P and ebay. Are Touramax or Electrosport brands alright? Any I should avoid?
M&P have Electrosport branded stator and reg for £97 and £67 quid. ____________________ Beginner Biker Adventures Blog
Yamaha FZ6 S2 2007 |
| Nobby the Bastard |
| Amber Phoenix |
| Nobby the Bastard |
| Tankie |
 Tankie Crazy Courier
| mentalboy |
| Amber Phoenix |
 Posted: 16:52 - 21 Mar 2020 Post subject: |
I'm going with you mentalboy, just ordered new stator, reg and battery. Sledge hammer approach, and avoid faffing about and needing to buy parts twice if the stator takes more stuff out.
Thanks everyone. ____________________ Beginner Biker Adventures Blog
| mentalboy |
| Amber Phoenix |
 Posted: 15:30 - 25 Mar 2020 Post subject: |
So, aftermarket regulator and stator turned up today. Batterr on backorder (thanks for not teling me about that M&P...)
Just checked resistance on new stator, it also read 0.8 ohm across each coils. hmm. Then checked resistence of probes touching, read 0.4 ohms - ahh! Damned mulit-meter is reading high.
So, that would imply the stock stator on my bike is reading 0.3 ohm per coil, which is within range. And with 70VAC at 5k revs, output seems acceptable. So, I may leave that on for now, and will try just new reg and battery initially. Just hoping I get new battery soon with all the current lockdown in place... ____________________ Beginner Biker Adventures Blog
| Polarbear |
 Polarbear Super Spammer
The last post was made 6 years, 202 days ago. Instead of replying here, would creating a new thread be more useful? |
