| Riejufixing |
 Riejufixing World Chat Champion
| doggone |
 doggone World Chat Champion
| Ste |
 Ste Not Work Safe
| Pete. |
 Pete. Super Spammer
 Posted: 15:55 - 22 Mar 2020 Post subject: |
What's the trench for?
Digging is about the most basic simple task a man can perform. Push the spade into the ground, lever, lift, tip and repeat.
If you're going to use a mattock be sure there are no services. A spade is bad enough but you can swing a mattock though a cable no problem at all even if it's armoured. ____________________ a.k.a 'Geri'
| WreckTangle |
 WreckTangle Scooby Slapper
| Polarbear |
 Polarbear Super Spammer
| pepperami |
 pepperami Super Spammer
| JackButler |
 JackButler Traffic Copper
| MCN |
 MCN Super Spammer
 Posted: 16:57 - 22 Mar 2020 Post subject: |
I know where you're going with this. 😉
This is The Shitting From a High Place sort of parallel thread.
The towers and the moat was the clue. 👍 ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Riejufixing |
| pepperami |
 Posted: 17:06 - 22 Mar 2020 Post subject: |
| MCN wrote: |
The towers and the moat was the clue. 👍 |
I is smiling
PS : not high enough. ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| Tankie |
 Tankie Crazy Courier
| JackButler |
| MCN |
 MCN Super Spammer
| Pete. |
 Pete. Super Spammer
 Posted: 18:42 - 22 Mar 2020 Post subject: |
Clay is good for building on......so long as you're building a tent. ____________________ a.k.a 'Geri'
 - Super Spammer
 Posted: 18:44 - 22 Mar 2020 Post subject: |
| Riejufixing wrote: |
I'm digging out for an outbuilding base. It will be 6m x 5m (including a concrete "apron"). The idea is to trench, then dig out the rest to the same level. There may be a better way...
Digging is simple, but I don't want to do more than enough work, or have to make more concrete than I need. |
How wide and how deep? a 5M x 6M building will have 22M of trench to dig out. At 1M deep, and 1M wide, that's 22 cubic metres.
A cubic Metre of concrete weighs 2.5 ton, so you'll need 55 tons of concrete.
Best of luck doing that with a bucket and spade. ____________________ TZR250 2MA road, TZR250 1KT road, TZR250 2MA race, TDR250, YZF-750R Boost colours.
Jaguar S Type 3.0 V6 Sport R, VW Transporter T5 GP LWB Shuttle 140ps DSG. |
| MCN |
 MCN Super Spammer
 Posted: 18:53 - 22 Mar 2020 Post subject: |
| MCN |
 MCN Super Spammer
 Posted: 20:51 - 22 Mar 2020 Post subject: |
OP said it was a base.
You can easily build a tent on a concrete base.  ____________________ Disclaimer: The comments above may be predicted text and not necessarily the opinion of MCN. |
| Polarbear |
 Posted: 22:50 - 22 Mar 2020 Post subject: |
| MCN wrote: |
And you can get by with straw instead of bog paper. Sorted. ____________________ Victory Cross Country American tractor. |
| Riejufixing |
| Riejufixing |
 - Super Spammer
| JackButler |
 Posted: 08:04 - 23 Mar 2020 Post subject: |
Forgive my technical expression, but footings it is.
You're wanting a slab, or a raft, made of concrete to place a structure on, or maybe just the apron is concrete?
If you're cutting into a slope then you need to think about how you're going to retain the wall you're exposing. Depending on the height & stability of what you're holding back this retaining wall will need a foundation.
The slab, or raft itself will also need a foundation, this again depends on the stability of the ground. Please bear in mind that an MOT type hardcore foundation needs to be a minimum of 100mm to have any strength at all, 200mm-300mm is common, but it can need to be as much as 600mm.
Given any thought about drainage yet?
If you consider the height which your base needs to be & work downwards from there, then even basic math will soon tell you that you're going to need to move quite a lot of muck, hardcore & concrete to get even a rudimentary base for even the lightest of wood structures.
How familiar are you with manual labour? ____________________ I clean my guns with the tears of the snivelling, left wing scum. |
| MCN |
 MCN Super Spammer
| yen_powell |
 yen_powell World Chat Champion
The last post was made 6 years, 201 days ago. Instead of replying here, would creating a new thread be more useful? |
