Heated grips spinning
TravisBickle
PostPosted: 16:55 - 23 Mar 2020    Post subject: Heated grips spinning Reply with quote
Hi guys what would you recommend for spinning/slipping heated grips? Obviously only the throttle one is causing a problem at the moment. I want something fairly sturdy so it doesn't give out when I'm pinning it but also don't want anything too permanent in case for whatever reason in the future I need to remove them.
Got gorilla glue glue on standby. Recommended or no?
2024 BMW M1000XR
2021 Honda CMX500 Rebel S
2016 Triumph Tiger 1050 Sport
Tankie
PostPosted: 17:08 - 23 Mar 2020    Post subject: Reply with quote
Evostick, Gorilla glue dries / sets hard .
cover bar end in evostick and push on grip while it's still moist.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:14 - 23 Mar 2020    Post subject: Reply with quote
Dont bother with super glue, water makes it break down and as it does to a hard layer heat expansion makes it crack off.
Impact cement or gorilla glue (its water activated so spray water on before putting the grip on) work fine.
Triumph Sprint ST 1050
Nobby the Bastard
Harley Gaydar
PostPosted: 17:16 - 23 Mar 2020    Post subject: Reply with quote
TravisBickle
PostPosted: 18:46 - 23 Mar 2020    Post subject: Reply with quote
2024 BMW M1000XR
Freddyfruitba...
PostPosted: 19:03 - 23 Mar 2020    Post subject: Reply with quote
The official recommendation is normally cyanoacrylate glue (aka superglue); I've never heard of it being a problem other than you have to get the grips to the right position PDQ before it sets and locks them in place for all time. I've heard that hairspray is supposed to work well though (especially if you want to retain the option of being able to remove/reposition the grips some day
PostPosted: 19:10 - 23 Mar 2020    Post subject: Reply with quote
You spin me right round, baby
Right round like a record, baby
Right round round round?
TravisBickle
https://i.imgflip.com/3tqf4j.jpg
2024 BMW M1000XR
Nobby the Bastard
Harley Gaydar
PostPosted: 19:34 - 23 Mar 2020    Post subject: Reply with quote
No meatspin link? I is sad.
PostPosted: 00:41 - 24 Mar 2020    Post subject: Reply with quote
I have only ever fitted handgrips (heated or otherwise) with hairspray. Never had a problem with them slipping. It will be into double figures of handgrips.
Degrease boththe inside of the grip and the bar with solvent, apply hairspray, slide grips on, wait an hour for the spray to set.
To get them off again, wiggle the straw off a WD40 can under them and squirt/wiggle until they are free.
The last post was made 6 years, 207 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 62.59 Kb
