| TheMadWelshma... |
 TheMadWelshma... Two Stroke Sniffer
| Riejufixing |
| TheMadWelshma... |
| Riejufixing |
| TheMadWelshma... |
| TheMadWelshma... |
 Posted: 14:24 - 24 Mar 2020 Post subject: |
Well, I'd suggest the oil is leaking out of the notch in the bottom of the crankcase mating surface.
Which begs the question, should there even be oil in here? Because that notch looks like it's been machined in there which would mean that compartment is not supposed to be oil filled. If it's supposed to be a dry alternator (anyone know?), engine oil is finding its way into there from somewhere.
There also appear to be a couple of chunks of loose metal casting and some alloy shavings lying about in there, which is not a good thing.
I suspect if you find where that metal has come from, the mystery will be revealed.
https://www.bikechatforums.com/download.php?id=103239 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Bhud |
 Bhud World Chat Champion
| Riejufixing |
 Posted: 14:54 - 24 Mar 2020 Post subject: |
Try getting hold of the alternator rotor (the big circular metal thing in your second picture) and see if you can move it up and down or side to side. If there is any appreciable play there, chances are the main bearings are shot. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| TheMadWelshma... |
| TheMadWelshma... |
| TheMadWelshma... |
| Riejufixing |
| TheMadWelshma... |
| Riejufixing |
| kramdra |
 kramdra World Chat Champion
| Riejufixing |
| WD Forte |
 WD Forte World Chat Champion
| TheMadWelshma... |
| TheMadWelshma... |
| TheMadWelshma... |
| WD Forte |
 Posted: 22:38 - 26 Mar 2020 Post subject: |
Dont get stuck/ripped off on any 'genuine AJS' parts bollox
It's a Lifan 244FMI engine
Wemoto sell bits for it here
https://www.wemoto.com/bikes/chinese_motorcycle/engine_244fmi_125cc_twin/00-10
Crank Left Hand Oil Seal [AB1633] £3.96
Alternator Generator Cover Gasket [AB4913] £4.79
Cant see from your pics but some rotors have a 'holding on' bolt
in the middle which when removed allows a slightly bigger bolt in to draw the rotor off the tapered shaft.
After the rotor is off, the rest is pretty easy ____________________ bikers smell of wee |
| TheMadWelshma... |
 Posted: 22:58 - 26 Mar 2020 Post subject: |
| WD Forte wrote: | Dont get stuck/ripped off on any 'genuine AJS' parts bollox
Bloody hell. Brilliant stuff. I used them a few years back for mini moto stuff for the 🧒 bike. Ahem. I never thought of them. Cheers. Mate.
After the rotor is off, the rest is pretty easy |
The last post was made 6 years, 196 days ago. Instead of replying here, would creating a new thread be more useful? |
