yamaha wr125 r 2011 clutch cover oil seals
squbany
PostPosted: 17:39 - 28 Mar 2020    Post subject: yamaha wr125 r 2011 clutch cover oil seals Reply with quote
Hi im new in bike world...
need to replace oil seal with is in clutch side cover.
but canot find right one
anoyone hire replace that before and can help me find right one???
yamaha wr125r 2011 thanks. Rolling Eyes Rolling Eyes Rolling Eyes
SQUBANY
Riejufixing
PostPosted: 18:58 - 28 Mar 2020    Post subject: Re: yamaha wr125 r 2011 clutch cover oil seals Reply with quote
yamaha wr125r 2011
Do you mean you can't actually find one, or that there are two possibilities? The size of the seal, which is very likely to be a general buy-anywhere off the shelf thing used for lots of things will be moulded into the rubber of the seal.
squbany
PostPosted: 12:09 - 29 Mar 2020    Post subject: neeed exactly this one from picture Reply with quote
Hi any one know from wher i can order or what size it is canot find right one on ebay. thanks
PICTURE WITH ENGINE COVER SHOWS PLACE WITH OIL SEALS WITH NEDED
SQUBANY
Nobby the Bastard
Harley Gaydar
PostPosted: 12:29 - 29 Mar 2020    Post subject: Reply with quote
Looks to be part no 18,
https://www.fowlersparts.co.uk/parts/4235836/wr125r-22b5-2011-060-a/crankcase-cover-1
Triumph Sprint ST 1050
Riejufixing
PostPosted: 12:50 - 29 Mar 2020    Post subject: Re: neeed exactly this one from picture Reply with quote
What's the exact problem? You can't do the search, or the search does not find one?
From your picture, it looks as though you push it out from the outside inwards. Then look at the sizes marked on it. Then order a new one the same.
You could measure the outside diameter of the seal (a steel tape or rule is probably good enough), and the diameter of the shaft, to confirm which to order IF there are a couple of possibilities and you can't decide which.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:54 - 29 Mar 2020    Post subject: Reply with quote
Il cost 5 quid plus delivery from fowlers.
Why are you looking on ebay for something that costs pennies from a main dealer?
Riejufixing
PostPosted: 13:09 - 29 Mar 2020    Post subject: Reply with quote
It can be more expensive on eBay. You probably know that. I don't understand the problem, he posted a picture but didn't give links or say why they didn't fit. If the case is off, he could just measure the poxy thing, or read the size off it to make sure. Google shows various results. It's a pretty standard engine that goes into various things (including Rieju RS3s I think; same as YZF-R125?). May be part#931021222400.
Nobby the Bastard
Harley Gaydar
PostPosted: 13:18 - 29 Mar 2020    Post subject: Reply with quote
He probably jammed it in without showing any mechanical sympathy.
A little oil rubbed round the outside and then gently easing it and it'll fit.
steve the grease
PostPosted: 17:03 - 29 Mar 2020    Post subject: Reply with quote
You have showed us 2 seals , they are both 35mm outside diameter, one has a hole 17mm diameter , one has a hole 24mm diameter. One is 7 and one 8mm thick , irrelevant really .
So it's 17mm OR 24mm
You are in a much better posiition to tell us which one fits. 17/24 it's quite a big difference.
What is the diameter of the shaft that runs in the seal?
squbany
PostPosted: 17:15 - 29 Mar 2020    Post subject: ... Reply with quote
OK so picture witch i show are from google so i canot measure.
i read that this seal its important for crankshaft thats why want to replace , and need to take out clutch cover anyway (dont ask why)
i dont mind its cost 5 or 10 but always when try to find its shows OIL SEAL for GEAR LEVER. dont think thats the right one thats why want to ask.
i order all ready nr18 so will see in few days thanks all. Thumbs Up
ps. i will be ok with replace. Laughing
SQUBANY
Nobby the Bastard
Harley Gaydar
PostPosted: 17:32 - 29 Mar 2020    Post subject: Reply with quote
The one in your picture is the gear lever seal.....
Nobby the Bastard
Harley Gaydar
PostPosted: 21:00 - 29 Mar 2020    Post subject: Reply with quote
It's also not the casing for the clutch side.
squbany
PostPosted: 21:48 - 29 Mar 2020    Post subject: Reply with quote
of course its cover from clutch side! if you dont have nothing smart to say, stay quaiet Rolling Eyes Rolling Eyes Idea
SQUBANY
Nobby the Bastard
Harley Gaydar
PostPosted: 22:25 - 29 Mar 2020    Post subject: Reply with quote
So the clutch is near side. My mistake. I've never come across one on that side. It doesnt alter the fact that the seal is for the gear lever shaft.
The last post was made 6 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 89.26 Kb
