YBR 125 Custom front brake freeplay
DexterKane
PostPosted: 19:33 - 28 Mar 2020    Post subject: YBR 125 Custom front brake freeplay Reply with quote
Doing a few last bits to this before I sell it now I have some time on my hands.
Front brake is pretty flappy. Have to pull it back a long way to get it to engage. Had a new disc and pads at the last MOT. Brake fluid looks pretty fresh although is filled up quite far beyond the line. Tried tying the brake lever back overnight to get rid of any air in the system but didn't any difference.
Any ideas how I can get it to sharpen up?
Thank you!
Nobby the Bastard
Harley Gaydar
PostPosted: 20:13 - 28 Mar 2020    Post subject: Reply with quote
If bleeding it doesnt solve the problem your master seaks are fucked.
Triumph Sprint ST 1050
Easy-X
PostPosted: 21:16 - 28 Mar 2020    Post subject: Reply with quote
Brake pipe attempting to do an impression of a balloon animal?
PostPosted: 21:18 - 28 Mar 2020    Post subject: Reply with quote
How many miles have you done on the new disk/pads?
xX-Alex-Xx
PostPosted: 22:29 - 28 Mar 2020    Post subject: Reply with quote
+1 for installing a set of braided lines, followed by new seals.
DILLIGAF
DexterKane
PostPosted: 22:49 - 28 Mar 2020    Post subject: Reply with quote
Thanks for all the replies everyone. Just be clear are we talking about a master cylinder overhaul?
DexterKane
PostPosted: 22:50 - 28 Mar 2020    Post subject: Reply with quote
About 1500. It's always been a bit loose though.
Riejufixing
PostPosted: 23:00 - 28 Mar 2020    Post subject: Reply with quote
If it's spongy, first do what Nobby said, and bleed it.
DexterKane
PostPosted: 23:16 - 28 Mar 2020    Post subject: Reply with quote
Cool will try that first. Master cylinder looks quite fiddly.
DexterKane
PostPosted: 18:43 - 17 Apr 2020    Post subject: Reply with quote
Hi all,
Just bled this front brake and the fluid leaked out of the seal that sits just before bleed nipple.
Pumped some fluid through nonetheless but as expected it's the same as before. I guess this would point to the seals on the caliper needing replacing right?
Thanks!
Riejufixing
PostPosted: 19:59 - 17 Apr 2020    Post subject: Reply with quote
What is that?
DexterKane
PostPosted: 20:30 - 17 Apr 2020    Post subject: Reply with quote
Riejufixing wrote:
What is that?
Half the fluid came out the bleed nipple, the other half seemed to leak out the base of it.
Should I upload a pic or does make sense?
Thanks!
Riejufixing
PostPosted: 20:57 - 17 Apr 2020    Post subject: Reply with quote
The bleed nipple is basically just a screw-in hollow needle valve. Have you bled brakes before? Here is a short video of an annoying person bleeding a front brake. He mentions the issue with "seepage" you are having.
https://youtu.be/fUWO0SQX6-U
Here's a pictire of a bleed nipple. You can see the hole where the brake fluid runs into the central hole of the nipple, and also the sloped seat of the needle valve.
https://www.merlinmotorsport.co.uk/p/goodridge-speed-bleeder-bleed-nipple-g-bn
Note: You should not do these things up very very tight. Nipping them up so that they don't leak and won't come loose is enough, lest you damage the seat that the nipple meets.
DexterKane
PostPosted: 22:54 - 17 Apr 2020    Post subject: Reply with quote
Yeah I've already watched that one actually! I cracked it about a quarter to half a turn and it still seeped everywhere.
jaffa90
PostPosted: 00:23 - 18 Apr 2020    Post subject: Reply with quote
"""Yeah I've already watched that one actually! I cracked it about a quarter to half a turn and it still seeped everywhere."""
Sounds like worn threads, you may have to use heavy grease or non setting silicone around that area so you have less chance of air going back in.
Also you may have to crack open and shut the banjo bolts a little whilst under pressure to release any trapped air.
DexterKane
PostPosted: 09:10 - 18 Apr 2020    Post subject: Reply with quote
Hmmmm. So basically the caliper is pretty knackered then? That sounds like a messy job that's got a pretty small chance of going right if I attempt it Mr. Green
DexterKane
PostPosted: 10:49 - 18 Apr 2020    Post subject: Reply with quote
- wrote:
I take it the YBR doesn't have adjustable levers?
Can you see the pads move as soon as you press the lever, then just take a lot more of a press to firm them up on the disc?
How old is the standard rubber brake hose? Are both banjo bolts tight?
Nope, non adjustable.
Brakes do work, just the lever needs to be pulled right in to do so. Perhaps even slightly worse since I mucked about with them yesterday.
Hose has probably never been replaced - it's a 2011 bike. As far as I'm aware the bolts are tight. There are no leaks or anything, just very spongy.
Thanks!
pepperami
PostPosted: 11:11 - 18 Apr 2020    Post subject: Reply with quote
Thanks!
Braided hose line now Thumbs Up
DexterKane
Just doubled checked and the calliper mechanism does start to move when the lever is engaged.
DexterKane
PostPosted: 11:13 - 18 Apr 2020    Post subject: Reply with quote
pepperami wrote:
Thanks!
I'm selling it, so unless there's anything to indicate there's anything wrong with the hose I won't bother replacing it Smile
Easy-X
PostPosted: 11:26 - 18 Apr 2020    Post subject: Reply with quote
>8yo hose on low end bike.... no, move along nothing to see here Smile
After sorting your nipple problem (ooo-errr!) maybe try a reverse flush. Then admit defeat and buy a new brake pipe.
DexterKane
PostPosted: 11:28 - 18 Apr 2020    Post subject: Reply with quote
"Then you either have air in the system, a leaking seal or expanding brake hose"
Might get a new caliper for it then. Doesn't seem much point rebuilding it if the bleed nipple thread might be knackered.
Is there any way to check if the hose is knackered before replacing it?
Thanks!
DexterKane
PostPosted: 11:30 - 18 Apr 2020    Post subject: Reply with quote
OK fair enough looks like it's time!
The last post was made 6 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 130.27 Kb
