| andscoot |
 andscoot L Plate Warrior
 Posted: 08:00 - 30 Mar 2020 Post subject: 2006 Peugeout Vivacity won't start.. |
Hi, I have a vivacity with some problems. It won't start and I can't figure out why. What I have done:
- Checked the spark, it is good.
- Used motorstarter inside the spark plug hole: starts, but stops after a few secounds.
- Disconnected the fuel hose to the carburetor: when I crank the engine, gasoline flows.
- Checked the compression: 150psi.
- Checked for bad air hoses: only found 1 hose, looked in good condition.
- Cleaned the carburetor, and replaced it with one from a 2005 vivacity: nothing happend.
- Replaced the engine with one from 2005: had one laying around, did not change anything, still same problems.
- Sprayed some water around the carburetor area to see if the engine rews, nothing happens.
- Checked the autochoke, get's a reading of around 50ohms or more, don't quite remembe - at least not an open circuit.
- I have mostly only tested by using the kickstart, but most recently I fixed the electric starter so I try with that aswell: nothing.. (and ofc I pull the brake lever).
- I have sucked the vacuum hose for the control valve: gasoline flows.
Anything more I can try? |
| jaffa90 |
 jaffa90 World Chat Champion
| Easy-X |
 Easy-X Super Spammer
 - Super Spammer
| Riejufixing |
| andscoot |
| andscoot |
| andscoot |
| andscoot |
| bypass2 |
 bypass2 Spanner Monkey
| Easy-X |
 Posted: 15:30 - 31 Mar 2020 Post subject: |
If the plug's not very wet after 50 goes then fuel isn't getting through.
This should be all points on that chain:
Fuel cap (air inlet to stop vaccum lock)
Petcock filter(s)
Petcock tap (vacuum tap in your case, when testing is it a good flow or just a dribble?)
Fuel pipe to carb (ties in with above test)
Carb inlet to float valve (decent carb cleaner spray with one of those pipe attachments, make sure it squirts all the way through*)
Float valve (rubber bit at the top could perish, might not be sliding in and out smoothly**)
Floats (the ones that ride up and down on shafts*** can get stuck, throw floats into a jug of water, check they actually float)
Float/valve arm (is this moving smoothly)
Pilot/idle jet blocked (main source of fuel for starting)
The above plus a can of "Start ya bastard" should be all you need to get something out of it. Obviously a working choke would be a help but a choke's no use without the above working.
*as the actress said to the bishop
**well, that's what she said
***you'll have to make your own up, I'm done! ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Riejufixing |
The last post was made 6 years, 186 days ago. Instead of replying here, would creating a new thread be more useful? |
