| claudineskile... |
 claudineskile... L Plate Warrior
 Posted: 04:59 - 31 Mar 2020 Post subject: How to choose the proper skateboarding pads |
Apart from the helmet and footwear, skateboarding pads for elbow and knee are one of the most crucial safety accessories.
Like the other risky sports, equipping safety stuff including skateboarding pads is compulsory for every skateboarding player. Skateboarding safety equipment features the solid pads to protect the players’ elbow and knee which is always at the top of the requirement of safety equipment.
Safekeeping equipment is always of utmost importance that all players care about, whether they are amateurish or professional as they protect you while riding to securely performing various tricks like doing the ollies or the kickflips.
Therefore, in this article, we are gonna provide you with some useful basic information in order for you to get the right skateboarding pads. If you want to have a better choice when shopping for other skateboarding safety accessories, you can try visiting "category skateboard purpose"
The material of the pads
The solid pads for elbow and knew should be made from synthetic rubber or softer material that can allow air to pass through and is secured on your knee and elbow. It also includes a casing made from a firm ABS plastic and Velcro ties to make it be tightened.
The pads made from soft material or even a more rigid one will take effect to protect you from the harmful pains. However, some of the pads such as the POC joint VPD knee guard may cause the sufferings to your hand when you hit it.
A thin garment covering it will be torn and then scuff your elbow or knee. The firm covering made from plastic will be a perfect solution since when you are riding with its support. If you wear it tight enough, it will not hurt your knee cap even under the strain and your bodily heaviness that might break the covering.
The major material of the knee pad with hard shell caps is ABS plastic that is not too big but seems to be ergonomic. This the most favorite type of pads that skateboarders prefer to purchase. It sometimes might hamper some of your movements or gestures but it definitely has an edge of the safety characteristic due to its ability to endure the bump and graze.
On account of its sturdiness, it will be uncomfortable for you if you wear it inside your outfits. Or in case your outfits are oversized type, it is possible that your outfits will be damaged once you topple over.
Other information relating to skateboarding pads.
The thickness of the pads
The skateboarding knee and elbow guards include soft foam wadding to protect more effectively from the bumps. The thicker the pad is, the more protective it becomes. Bur, you have to notice that the thicker pad also brings an adverse result which is the subsidiary weight and the constraint of motions.
https://skateadvisors.com/wp-content/uploads/2020/04/How-to-choose-the-proper-skateboarding-pads.jpg
Form and size
Skateboarding pads for knee and elbow are interchangeable to some extent. They both consist of the shell that flexibly embraces and protect and not be caught. The thickness and largeness of the pad would commensurate with its price.
In order to own a pad with good quality, you will have to spend a bit more money and then get a thicker and bigger shell whereas if you just want to spend a little money to buy a pad, it will just big enough to embrace your elbow or knee.
Additional knee and elbow safekeeping gear.
If you prefer the pad having a squashy, you can try to use the gasket brace for knee and elbow. They are thin and tublike covering which can decrease the risk of your bones being hurt. There is a well-known brand for your preference like Pro-Tec.
How about the price of the skateboarding pads?
Of course, when deciding to purchase a skateboarding pad, you will take both the quality and the price into consideration. However, you do not need to force yourself to buy a high-end product and should pay more attention to your demands.
If you feel uncertain about splashing out a big money on the famous pads pf a well-known brand, you can just go ahead to pick a local brand but its product’s quality is acknowledged by a large number of people like AllSportProtection's. You can see more skateboard articles at skateadvisors to get your own knowledge about skateboarding brands and products.
Here are some outstanding characteristics of a pad that we recommend according to the range of price
For pads of $20 - $45:
Mostly be suitable for the newbies with a standard safekeeping degree
Big EVA foam
Firm covering cap made from ABS plastic
Medium size
For pads of $50 - $120+
Suitable for the pro skateboarders with a high safekeeping degree.
+ Big and double thickness of the foam
+ Ergonomical coverings
+ Modern, squashy, and supple pad but also solid enough to protect from bumps.
+ Give you some fresh.
In addition to the parts of a skateboard, you can view many other articles related to skateboards at: https://gab.com/skateadvisors
| Evil Hans |
 Evil Hans World Chat Champion
| Nash GT |
 Nash GT World Chat Champion
| linuxyeti |
 linuxyeti World Chat Champion
| Evil Hans |
| seeyalater |
 seeyalater Trackday Trickster
| SDFarsight |
 SDFarsight Nova Slayer
| ThunderGuts |
 ThunderGuts World Chat Champion
The last post was made 6 years, 174 days ago. Instead of replying here, would creating a new thread be more useful? |
