MobyAV87 throttle
Marley
PostPosted: 10:25 - 01 Apr 2020    Post subject: MobyAV87 throttle Reply with quote
Hi all,
could any member tell me if there is a generic throttle/decompresser which will fit my bike as the one fitted i quite worn making it difficult to acheive full throttle.
If i could get a new/old stock part that would be better?
Any suggestions please
Pete
Riejufixing
PostPosted: 10:29 - 01 Apr 2020    Post subject: Re: MobyAV87 throttle Reply with quote
Marley wrote:
Hi all,
Pete
What's one o' they there (you're not Cap'n Ahab, are you)?
Easy-X
PostPosted: 10:46 - 01 Apr 2020    Post subject: Reply with quote
It's one of those mopeds that run on garlic and red wine Razz
Bit obscure even for these forums!
Marley
PostPosted: 11:46 - 01 Apr 2020    Post subject: Reply with quote
Hi all,
How much more info do you need it’s a mobylette AV87
Pete
Riejufixing
PostPosted: 12:08 - 01 Apr 2020    Post subject: Reply with quote
Marley wrote:
Hi all, How much more info do you need it’s a mobylette AV87 Pete
Christ on a Mobylette!
Have you got a pic? Does it look like this: https://www.ebay.co.uk/itm/Piece-moteur-diverse-Generique-Mobylette-MBK-50-51-moteur-AV7-AV10-Neuf/352874520152?hash=item5228f5de58:g:ejEAAOSwHu9ckJBn ? Is this any use: https://vintagemopeds.files.wordpress.com/2013/01/motobecane-mobylette-repair-manual.pdf ?
Another interesting machine turns up in BCF!
steve the grease
PostPosted: 13:21 - 01 Apr 2020    Post subject: Reply with quote
The simple answer is no. The Mobylette uses a double cable twistgrip, but not like a regular one used on many bikes, where one cable pulls the other pushes ( depending which way you twist). The cables sit on a stop , so that when one is pulled ( throttle or decompressor) the other one stays on its stop and doesn't move . There are a few moped forums , Mopedland is one that springs to mind . Have a look on there and you will soon find something suitable.
From mopedland :
Moby throttle body castings—selection. New—£4. Used—£2.
Moby throttle twistgrip tubes—selection. New—£2. Used—£1.
How do I know all this.
I had one back in 1972.
WD Forte
PostPosted: 14:00 - 01 Apr 2020    Post subject: Reply with quote
The 1976 Moby I was fiddling about with last year had one of those
https://www.bikechatforums.com/viewtopic.php?t=324407
Push forward to decompress for starting and stopping
Pull back to ride like the wind!
As I recall there were plenty of parts available on sites like Stevethegrease mentioned
bikers smell of wee
The last post was made 6 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.93 - MySQL Queries: 13 - Page Size: 51.69 Kb
