Radiator sealant
Streaky100
PostPosted: 08:04 - 03 Apr 2020    Post subject: Radiator sealant Reply with quote
I have just noticed a leak from my radiator, which is the best radiator sealer for use on bikes?
redeem ouzzer
PostPosted: 08:42 - 03 Apr 2020    Post subject: Reply with quote
Just stick another radiator on it.
Be a REAL MAN!
Streaky100
PostPosted: 09:02 - 03 Apr 2020    Post subject: Reply with quote
Had a quick look and can only find one in America... Postage charges are way more than the item itself!!!!
xX-Alex-Xx
PostPosted: 09:13 - 03 Apr 2020    Post subject: Reply with quote
If you want to clog your internal coolant passageways, throw some sealant into the coolant.
If you want to do it properly, get the radiator repaired or replaced.
DILLIGAF
Riejufixing
PostPosted: 09:47 - 03 Apr 2020    Post subject: Re: Radiator sealant Reply with quote
Got a pic/pics? What bike?
I wouldn't use a "dog turd" or whatever they call them now unless it's an emergency, AFAIK they are said to be temporary anyway.
Streaky100
PostPosted: 09:52 - 03 Apr 2020    Post subject: Reply with quote
96 kawasaki gpz1100e
Riejufixing
PostPosted: 10:29 - 03 Apr 2020    Post subject: Reply with quote
Mmm, about £600. Ebay has some used for 1/6 of that.... https://www.ebay.co.uk/p/1423735122 (or in eu, one here has been "wiped" but is cheap).
Tankie
PostPosted: 10:46 - 03 Apr 2020    Post subject: Reply with quote
K seal does work,
but why is it leaking, physical damage or internal / external corrosion ?
Streaky100
PostPosted: 11:19 - 03 Apr 2020    Post subject: Reply with quote
Looks like damage as the guard looks like it has took a hit near where it is leaking from
Tankie
PostPosted: 11:26 - 03 Apr 2020    Post subject: Reply with quote
That's ok ,the reason i ask is that if corrosion was the issue i think you would be up a creak without a paddle, so i think you may stand a chance with the K seal, it will probably buy you some time to sort out a replacement
Confusion
PostPosted: 11:34 - 03 Apr 2020    Post subject: Re: Radiator sealant Reply with quote
The best radiator sealant I have seen is Novastop. It will stop
leaks, but it won't clog up your rad or other parts of your cooling
system.
https://www.novatio.be/en/products/novastop-radiator
My old ZZR 11 blew up in a cloud of steam when I was
130 miles from home. Luckily, I was able to pull in to
a petrol station, let the bike cool for a while, borrow a
screwdriver from a friendly van driver and fill up with
tap water. This got me the next mile to the local motor
factors in Tuam, County Galway. They had Radweld
and Novastop in stock. The guy behind the counter
said Radweld would probably be enough to get me
home, but Novastop works a lot better and would be
a more permanent fix. The local farmers use it for
leaky tractor rads and even for cracks in cylinder blocks.
The bottle is suitable for cooling systems up to 25 litres,
so a quarter bottle was more than enough for the bike.
The rad went from pissing out water to a trickle in
30 seconds and a complete stop in 1-2 minutes. I was
able to continue my journey to Sligo, do 100 miles of
spinning around over the weekend and a 200 mile
return journey back to Cork without losing a drop.
Six months later, I had to remove the rad to fit new
exhaust headers. I took the opportunity to bring it to
a rad specialist for a 'proper' repair.
The problem on the ZZR is caused by corrosion on
the bottom support for the cooling fan cowling. Once
the support breaks, the sharp edge of the cowling eats
a hole in rad. Maybe the GPZ has a similar arrangement?
Bandit 650SA, ZZ-R1100
kramdra
PostPosted: 13:02 - 03 Apr 2020    Post subject: Reply with quote
I have not looked, but radiators are uaually pretty similar in function. You'll get a new cbr6 radiator for about 50 quid delivered on ebay and just need to make up some mount adaptors. In summer the fan may be on more than normal in slow traffic, but it wont be leaking. Other common bike radiators, fireblade or similar might be more suitable.
steve the grease
PostPosted: 15:25 - 03 Apr 2020    Post subject: Reply with quote
£600 notes is a lot , you could have it re-cored , indeed a custom one made from scratch for that...
However.
I have had good results with some radiators using araldite or other epoxy to repair the hole. Works on holes not cracks. Clean the area around the hole. Actually enlarge the hole using a pick tool or similar.
work mixed up epoxy into the hole as much as possible. when its gone off , mix up some more and splodge it on. Once it has gone off refit, fill and run, leave the rad cap off so there is no pressure. until the epoxy is well cured with the heat of the coolant. Once well cured fit rad cap. Worked for me.
The last post was made 6 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 83.33 Kb
