| Bhud |
 Bhud World Chat Champion
 Posted: 16:17 - 03 Apr 2020 Post subject: Gun Gum (edit: not JB Weld) around cylinder head (exhaust) |
https://i.ibb.co/YN94QNY/cbf-headers.jpg
More just for curiosity's sake, any idea why someone would do this, and would you bother fixing it (would need a new cylinder head and possibly exhaust system) or is it safe to assume it was just owned by a complete chimp and is probably full of similar secrets so best left alone?
What you're looking at is the exhaust side of a CBF500 (mid 2000s) cylinder head. JB Weld appears to have been lavishly smeared all around the exhaust outlets, and to have made removal of the exhaust impossible as it covers up exhaust header bolts on both sides. There is a huge amount of the stuff. Never seen anything like it before. As you can see, it's even in between the exhaust pipes and outlets.
The bike as a whole runs and works well - although the cooling system will need looking at and a few bits and pieces renewing. What it looks like to me is, someone tried to maintain the bike as best they could, but when the exhaust needed work, they couldn't get it off as the header bolts are covered in JB Weld.
| stinkwheel |
| Bhud |
| stinkwheel |
| Bhud |
| Riejufixing |
 Riejufixing World Chat Champion
| Bhud |
| steve the grease |
 steve the grease Crazy Courier
| Bhud |
| ThatDippyTwat |
 ThatDippyTwat World Chat Champion
| Bhud |
| Riejufixing |
| Scotsrick |
 Scotsrick Two Stroke Sniffer
| ThatDippyTwat |
 Posted: 09:05 - 04 Apr 2020 Post subject: |
| Bhud wrote: | Interesting! Any ideas on how to remove a refactory cement? |
Heat cycle it a few times, prod it with stuff. It'll flake off. Think extra thick, sticky gungum. We use a Needler on it, but we also get it way hotter than your exhaust will (Molten steel), let alone your cylinder head. You want it good and hot. More vibration is better. Ask any woman about those two things.
If it doesn't flake off, then fuck knows what it is. As said, most epoxies will get gooey and reek, if not ignite at the temps on exhaust headers.
Reiju - Generic term.
If you know about the stuff, you know there's a fuckton of variations on it, depending on application. Some have binders that make it more resistant to vibration, some is single use. ____________________ '98 VFR800 (touring) - '12 VFR800 Crosrunner (Commuting) - '01 KDX220 (Big Green Antisocial Machine) |
| Bhud |
 Posted: 13:18 - 04 Apr 2020 Post subject: |
| Scotsrick wrote: | On the bright side cylinder heads for that engine can be bought for peanuts . |
The bike itself is priced otherwise (seller is not willing to let it go for project/nonrunner money). If I make it mine, I will be down the cost of the bike plus a new cylinder head, new cyl head gasket, set of valve stem oil seals, budgeting as well for new valve shims, plus (probably) new exhaust header bolts and threaded studs. The sum total for the bike and all these parts would be excessive for what it is.
| Quote: | Even if the studs are borked it’s probably going to be easier swapping heads. |
Well, there may be another way. That is, just ignoring the problem, riding the bike around as per normal once we're past the corona virus thing, and just waiting for the stuff to flake away with repeated heat cycles. However, I really don't like the mechanical inelegance of doing it this way. |
| Easy-X |
 Easy-X Super Spammer
 Posted: 17:08 - 04 Apr 2020 Post subject: |
If someone has done this to a bike then what other shortcuts have they taken? "Oh yeah, I ran out of motor oil but I had some leftover chip fat..."
I don't know what they're asking but I'd start the conversation with "It's a great bike but I'll have to get a new barrel, studs, gasket... maybe new downpipes. Taking that off the bill would leave the price at £xxxx and that's me doing the work for free!" No movement? Just walk away. ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Bhud |
 Posted: 17:21 - 04 Apr 2020 Post subject: |
| Easy-X wrote: | If someone has done this to a bike then what other shortcuts have they taken? "Oh yeah, I ran out of motor oil but I had some leftover chip fat..."
I don't know what they're asking but I'd start the conversation with "It's a great bike but I'll have to get a new barrel, studs, gasket... maybe new downpipes. Taking that off the bill would leave the price at £xxxx and that's me doing the work for free!" No movement? Just walk away. |
Yes, that's my worry. I've looked over the bike and it's a lot different from a Kawasaki (e.g. ER5). The thoughtfulness of the design (e.g. everything packed away in a logical place for ease of access) and quality of fit and finish and all the parts is really impressive. Nothing cheap or crap about any of it.
It seems that someone wasn't impressed with any of this, and, I agree, if they weren't willing to shell out a fiver for exhaust gaskets and instead did this to an obviously good quality bike, it doesn't reflect well on their attitude to maintenance and upkeep. There may be lots more gremlins under the surface. What surprises me is the way the carbs are in perfect sync and don't need my touch at all. Someone could be bothered to do that. Cosmetically, it's also very good. It has brand new tyres, the chain and sprockets are good (though the chain is slack). The bike as a whole is a mass of inconsistencies. |
The last post was made 6 years, 178 days ago. Instead of replying here, would creating a new thread be more useful? |
