Brake line - options!
PostPosted: 12:03 - 05 Apr 2020    Post subject: Brake line - options! Reply with quote
I’m considering (due to this new time I find myself with!) replacing the front brake lines. There’s currently three, a short one from the master cylinder to a block behind the headlight and then two medium ones, obviously one to each calliper. I could replace like for like or equally just go for two long hoses from the master cylinder to each calliper.
What’s the pros and cons?
I’d imagine the two lines is cheaper as there’s less unions to be fitted, and maybe easier to bleed?
It’s a road bike, never used on the track for what it’s worth.
Thanks!
PostPosted: 12:07 - 05 Apr 2020    Post subject: Reply with quote
I think they are easier to bleed and give better performance all round.
Cons are all about routing of the hoses and clearance for the longer top banjo bolt.
I used Hel lines on mine which are pretty skinny, probably take up as much room as one rubber hose.
EDIT: The way I see it, the fewer joints, the less potential for trouble. You might want to keep the current setup if it's tight for space round the bars/top yoke.
Nobby the Bastard
Harley Gaydar
PostPosted: 12:15 - 05 Apr 2020    Post subject: Reply with quote
My sprint has as standard one long pipe going to one caliper and then a second short pipe over the mud guard to the other caliper.
This is an option if space is at a premium.
Triumph Sprint ST 1050
PostPosted: 15:13 - 05 Apr 2020    Post subject: Reply with quote
I would guess probably the easiest to bleed as well.
PostPosted: 15:23 - 05 Apr 2020    Post subject: Reply with quote
Not necessarily, because you have an uphill bend in the hose.
Nobby the Bastard
Harley Gaydar
PostPosted: 15:28 - 05 Apr 2020    Post subject: Reply with quote
I'll find out in a week or so when I get round to rebuilding the offside calliper which is attached to both pipes.
The last post was made 6 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 48.27 Kb
