| trevoriv |
 trevoriv World Chat Champion
| Nobby the Bastard |
| colink98 |
 colink98 Could Be A Chat Bot
| Evil Hans |
 Evil Hans World Chat Champion
 Posted: 12:43 - 31 Mar 2020 Post subject: |
I remove sprocket nuts by sitting on top of the wheel and using a breaker-bar and socket. The wheel is stable like this and you can get both hands on the bar and push down with the nut you're working on at the 6 o' clock position.
You can use a set of mole grips and an M6 nut to push the keeper plate over the pins on a softlink. Just incrementally increase the tension on the grips by a fraction of a turn each time. Use the nut over the end of the pin so it can push through.
Once it's on, you just need a way of deforming the ends of the pin enough that they can't come out. I've done it before today using a ball bearing in the mole grips in a similar way to that described above or by placing a heavy hammer on the back of the pin to act as an anvil and smacking the end of the pin with a second hammer (true rivetting). If the end is visibly mushroomed, it's not coming off again. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| FretGrinder |
 FretGrinder World Chat Champion
| Nobby the Bastard |
| Easy-X |
 Easy-X Super Spammer
 Posted: 14:38 - 31 Mar 2020 Post subject: |
An impact wrench makes the job trivial... go on, you know you want one  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| trevoriv |
| Confusion |
 Confusion Scooby Slapper
 Posted: 12:19 - 01 Apr 2020 Post subject: |
| trevoriv wrote: | Cheers all. I was just going to dremel the chain off. |
Cut it off any way you like once you are sure it won't be needed again.
| Quote: | I'll try and get everything off this weekend then I'll get a cheap riveting tool and give that ago. |
Do it slowly and measure carefully at each stage.
Make sure the pins, bushes and O-rings are well
lubricated before you assemble the link.
Take care with pressing on the side plates. Use a fraction of
a turn on the pressing tool, measure again and again
until the width of the link is the same as the adjacent links.
Measure the rivet ends before and after flaring. Follow the
manufacturers spec. Typical flaring spec for a soft rivet link
is +0.2 to 0.4mm. For a DID 530 with a pin diameter of 5.5mm,
the flared rivet will be 5.7 to 5.9mm. Once you get to the middle
of the required range, you must resist the urge to give it another
push for good measure.
If you don't have a local source of rivet links, you should consider
ordering an extra one as a spare, just in case things go wrong on
the first attempt.
| Quote: | And I do want an impact wrench but I cant think of much that I would use it for |
In most cases, a six-sided socket and a long breaker bar will
shift it. You may even find that it is quite loose. Based on my
experience, there is a less than 1-in-10 chance that it will be
so tight you will need a large impact wrench to get it off.
Plan for this possibility. As others have said, don't cut the chain
until the sprocket nut is off. Be prepared to abandon the job,
refit the sprocket cover and bring the bike to your local
truck tyre shop to get the nut off. ____________________ Bandit 650SA, ZZ-R1100 |
| trevoriv |
 Posted: 23:48 - 13 Apr 2020 Post subject: |
Be sure to bend the tab washer down first. Might not seem obvious to a novice mechanic but the big washer behind the nut will be folded up one edge to keep the nut from coming loose. Pry it away from the nut with a flat bladed tool then use a hammer and socket to flatten it right back.
27mm is the right socket I think. ____________________ a.k.a 'Geri'
| trevoriv |
| trevoriv |
 Posted: 11:54 - 18 Apr 2020 Post subject: |
Anyone need a rear sprocket, one careful none engine breaking owner, 43 teeth (at one point!)
https://i.imgur.com/5EQYC1V.jpg ____________________ Past: '96 Thundercat, '02 ZX636R (A1P), '58 KTM 690 SM LC4 Current: '06 ZX636R (C6F)
Mudskipper wrote: Someone just has to sig that... |
| Fisty |
 Fisty Super Spammer
 Posted: 12:00 - 18 Apr 2020 Post subject: |
Wow that looks like bodyguards mouth. ____________________ Quietly and consistently taking the piss.
Fatter and faster than Fret |
| trevoriv |
| martin734 |
 martin734 Spanner Monkey
 Posted: 14:14 - 18 Apr 2020 Post subject: |
Bllody hell, my gran's got better teeth than that.  ____________________ Current bike: ST1100 "Big Red" |
 Posted: 14:21 - 18 Apr 2020 Post subject: |
If that's all the gunk you got there's no wonder your sprocket's knackered. Normal chain greasing would make it much worse.
Anyway, WD40 will clean it, or some petrol in a pot, and an old 1.5" paint brush with the bristles cut down to half length. Put something down to protect the floor as it'll stain everything. ____________________ a.k.a 'Geri'
| trevoriv |
| Gazza M |
 Gazza M Crazy Courier
 Posted: 16:04 - 18 Apr 2020 Post subject: |
Paraffin's your friend there. WD40/petrol does work but will evaporate quickly, paraffin stays around til the job's done. Most forecourts have it
Might be too late, but have you gone for another ally sprocket? Once the hard anodising has worn the teeth disappear pretty quickly ____________________ Past: '07 YBR125, '00 GPZ500S, '99 ZRX1100, '98 CBR600 track bike, '97 ZX9R
Present: '05 R6 track bike, 140 pit bike |
| Mr Hammers |
 Mr Hammers World Chat Champion
 Posted: 16:35 - 18 Apr 2020 Post subject: |
I've been using Gunk for cleaning greasy/oily for decades. Perfect for this sort of thing. Doesn't leave an oily residue like paraffin.
5 litres usually lasts me 9-12 months. ____________________ A Guide To Powerbands |
| trevoriv |
| Tdibs |
 Tdibs Traffic Copper
 Posted: 20:44 - 18 Apr 2020 Post subject: |
Although its a bit late now, cleaning the fuck out of it with a hose/pressure washer before doing jobs like this makes it all a bit easier  ____________________ Previous : 09 Vanvan 125| 02' Sv650s || Current: 1999 Xj600n | 1992 DR650 RSE | 2005 Fazer 1000 |
The last post was made 6 years, 141 days ago. Instead of replying here, would creating a new thread be more useful? |
