Regal raptor 125 mounting dilema
chaza
PostPosted: 14:37 - 20 Apr 2020    Post subject: Regal raptor 125 mounting dilema Reply with quote
Hi guys
I have this dd125e bike, the front engine mounting needed replacement. The frame lugs are about 20 mm or so out of alignment. Given what butchering the previous owner has done, I can't seem to trust what parts actually belong to it. He even tried to weld the exhaust pipe to the alloy head, that what kind of a dick had it. Its a 14 plate and it's in a sorry full state.[/img]
I've posted a pic of the offender, the question is....The bracket seems to be correct, I'm starting to question is the frame correct, but the vineyard no says yes.. so how is it that far out of alignment.
Any suggestions..
Thanks guys
Riejufixing
PostPosted: 14:54 - 20 Apr 2020    Post subject: Reply with quote
I can't work out what's going on from that photo. I assume the two lugs pointing up and to the right are supposed to be bolted onto the engine. What's the big hole for?
Can you find any online photos or pictures of parts (eBay) that would help? Can you upload further pictures?
Nobby the Bastard
Harley Gaydar
PostPosted: 14:55 - 20 Apr 2020    Post subject: Re: Regal raptor 125 mounting dilema Reply with quote
chaza wrote:
Hi guys
Any suggestions..
Thanks guys
Any chance of a photo that doesnt look like it was taken by a 1970s Polaroid?
Triumph Sprint ST 1050
chaza
PostPosted: 15:03 - 20 Apr 2020    Post subject: Reply with quote
What your looking at is the old bracket. I have the new one but the problem is the same.
The bracket is notbyet bolted on. But you can see The two lugs where a bolt fixes it to the frame. Given that there is zero movement from the other mountings. How is it going to fit..i cant be sure anything is whatbit should be.
I am considering cutying the lugs off anc rewelding them back on.
Open to suggestions
chaza
PostPosted: 15:05 - 20 Apr 2020    Post subject: Reply with quote
The big hole is where the rubber and bolt sleeve are.
Riejufixing
PostPosted: 16:38 - 20 Apr 2020    Post subject: Reply with quote
So the two lugs pointing up/right bolt to the engine, so the whole thing turns on the other engine bolt, and the engine drops down so that the bolt/rubber sleeve (?) can go through and hold the thing onto the frame, is that it?
Edit: It would be nice to have another couple of snaps.
chaza
PostPosted: 17:04 - 20 Apr 2020    Post subject: Reply with quote
I ride a 12 plate dd125e8. And my bike dies not havevthe same mounting. So i dont know what this nob has done.
Chaza
chaza
PostPosted: 17:09 - 20 Apr 2020    Post subject: Reply with quote
Yes the big hole holds the rubber and bolt sleeve. The four holes bolt to the engine.
Riejufixing
PostPosted: 17:27 - 20 Apr 2020    Post subject: Reply with quote
So is the problem elsewhere? Is there a stay ataching the engine to top frame tube, for instance, that is wrong and holding the whole engine in the wrong place? Are the rear mounts correct?
Look at this frame, it looks as if there may be a top stay:
https://www.ebay.co.uk/itm/ajs-dd-125-e-regal-raptor-2012-frame-with-log-boog-v5-/164037204881?hash=item2631611b91%3Ag%3AiR0AAOSwV6heIwFe&nma=true&si=iJktX44NOqh2ZkuqTBKsTOS1WHg%253D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
chaza
PostPosted: 17:41 - 20 Apr 2020    Post subject: Reply with quote
That frame is similar.where my lugs are they sit on a complete bar across left to rught as in pic.
Right now i dont know how to solve this...if the engine is wrong for the frame......maybe he blew up the engine.....until i can identify the engine...my only solution is reweld the lugs....it wont pass mot likebit is
Ill send some pics of the engine.
Chaza
chaza
PostPosted: 17:15 - 22 Apr 2020    Post subject: Reply with quote
Hi guys
Hers an update, ...its confirmed I have an early engine in a late frame the mounting lugs have to be moved,,,,ajs said it's maybe a mk1, but that can't be as I have just fitted a twin carb to her, the mk1only has one. But the problem I have now is where do I take the vacuum from,,,,,mk has an egr valve,, so I'm guessing it's mk2 engine, but the head appears to be mk1, I guess they are compatabLe I don't know.
I could be wasting my time and money on this heinz 57, what do you think
Chaza
WD Forte
PostPosted: 20:30 - 22 Apr 2020    Post subject: Reply with quote
egr valve? we don need no stinkin egr valve!
bikers smell of wee
chaza
PostPosted: 21:09 - 22 Apr 2020    Post subject: Reply with quote
Its certainly turning out to be a mission.
Chaza
The last post was made 6 years, 135 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 77.08 Kb
