Odd Indicator Problem
PostPosted: 00:58 - 07 Nov 2002    Post subject: Odd Indicator Problem Reply with quote
Ok, now this is not bull shit, as G, Luke and Craig have all seen it.
I have nice mini indicators fitted to my bike, and the flasher unit has also been changed. I think it did it before, with the brick indicators on. When i rev the engine, it flashes faster, and faster, till its almost constant. What could cause this, and how could i fix it?
Its really odd, and it might well be illegal, and i dont want it to happen in my test!
thanks
Wingchunal
PostPosted: 01:04 - 07 Nov 2002    Post subject: Reply with quote
I need to change my indicators badly, im sure the standard bricks loose you about 10mph for wind drag!
What bulbs you got in your minis?
drunkstudent
PostPosted: 01:05 - 07 Nov 2002    Post subject: Reply with quote
have you checked the regulater/rectifier? there always packing up, could be part of the prob?
PostPosted: 01:12 - 07 Nov 2002    Post subject: Reply with quote
Nope, cos i dont actually know what it is Confused Is that the same as the flasher unit?
/me blames it all on TiN Razz (joke mate!)
zaknafien
PostPosted: 06:48 - 07 Nov 2002    Post subject: Reply with quote
Tin wont mind, i blame everything bad that happens to me on him. usually his fault Razz
02 Firestorm.
PostPosted: 09:42 - 07 Nov 2002    Post subject: Reply with quote
The regualtor / rectifier unit takes the AC voltage from the alternator and converts it to DC voltage of about 14 volts. Put a voltmeter over the battery, and it should be around (just under) 13V, rising to 14~14.5 with the engine running with some revs on.
To be honest I doubt this is the problem as when you rev the engine the indicators are fine. Sounds more like low battery power to me. You dont have a higher wattage headlight bulb in do you? If so try turning the headlight off and see if that fixes the problem. If the battery is marginal then the headlight drain will be noticable
PostPosted: 13:07 - 07 Nov 2002    Post subject: Reply with quote
No, the headlight is standard.
I will try turning it off etc.
Its an odd problem!
moonym20
PostPosted: 14:37 - 09 Nov 2002    Post subject: Reply with quote
it kinda does that on mine, i had trouble finding orange bulbs with the correct wattage so i got a new flasher unit and some 21W bulbs, when my engine is above 6k they flash rather quick then gradually slow down, mabyee as keith said you may have the wrong bulbs or wrong flasher unit fitted
hope it helps
Joe
PostPosted: 18:53 - 09 Nov 2002    Post subject: Reply with quote
Nope, lights off doesnt help Sad
It has the standard bulbs in there etc etc
And the Flasher unit is right? I think (TiN?!)
Will they let me do my test on thursday with it like this? ie, not being roadworthy or some other shit
bikerboy1
PostPosted: 22:03 - 09 Nov 2002    Post subject: Reply with quote
i have a problem with these things on the side of me bike as well.
i got new ones and i fitted them and they worked UNTIL......i started the bike then turned the front light on then turned them on, and they would stick on, not flashing just sticking!!!!! but when i turn the front light off they start flashing!!!
whats the problem here??? anyone help
when you see something like a bullet going past you, don't worry it's only me!!!!
PostPosted: 23:47 - 09 Nov 2002    Post subject: Reply with quote
For both of you I would suggest taking the battery off and charging it up and then try again. If that doesnt fix it make sure the electrical connections to the indicators, indicator relay and the battery are all clean.
The relays are always very sensitive to voltage.
PostPosted: 00:10 - 10 Nov 2002    Post subject: Reply with quote
Battery is fully charged, or at least the indicators were still doing it after it was fully charged, and then volt checked.
I will checkout the indicator relay tomorrow.
What do people think they will say on my test if they notice it?? Confused
PostPosted: 12:25 - 10 Nov 2002    Post subject: Reply with quote
Well, keep the revs to sensible levels so it isnt obvious. Also remember that the test has to take account of bikes with 6 volt electrics where the indicator speeds tend to be very slow at idle.
Rereading your original post you say the indicators get faster until they are almost constant. Sorry I read this as being that at high revs they are OK (sort of flash at a constant rate). If you mean (as I think you do) that they are on almost constantly then it does sound like a regulator / rectifier problem so check out the voltage over the battery as the revs go up
kev
I Hump Things
PostPosted: 13:45 - 10 Nov 2002    Post subject: Reply with quote
why dont you just do it the simple way and rewire the indicators yourself
20:02:36 Jammy-R6: any holes a goal
20:02:48 kev: even if its a hairy mans arse
20:02:56 Jammy-R6: hell yes
The last post was made 23 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 81.62 Kb
