| A100man |
 A100man World Chat Champion
 Posted: 12:40 - 23 Apr 2020 Post subject: Shock assessment |
I have a subscription to Practical Sportsbike it was a Xmas present from my (wealthy-ish)_ brother a couple of years back who has failed to cancel the direct debit.. I really ought to tell him..
Anyway, the point is they often add ride reports and reviews 80s 90s bike that have been restored. and invariably they will say. ' Great bike blah, blah if only Bob/Mike/Terry had replaced the worn out saggy shock(s) it would handle like a dream.. we recommend a new Nitron shock, blah blah custom built to suit ride, should only be 700 quid
.. this perplexes me as I'm pretty sure I'd find it hard to tell. I can bounce the rear end of my FZ lik ethe MOT guy does and the damping seems fine, it never bottoms out (OK so I'm only a lightweight) so is it OK? It has some preload adjustment but you'd be hard pushed to alter it on teh bike witout getting bloodied knuckles. But wtf is 'rebound adjustment'? extra damping?? How would I know when that is needed?,
Saying all that I have noted a shortcoming on my 550/600. It was sporting some of those cheap 'progressive' chinko shock until lately and they might as well have been steel rods as the ride appeared very harsh.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| Riejufixing |
 Riejufixing World Chat Champion
| stinkwheel |
 Posted: 12:55 - 23 Apr 2020 Post subject: |
Static sag is the main thing which is all down to the springs and how much "springiness" is left in them. Too much sag and they are saggy. Always start by setting your static sag.
The damping is the icing on the cake which determines how quickly that springiness comes into play. That's what prevents them "bouncing".
So it's a measurement of how far the shock compresses when you set the bike on its wheels from being supported off its wheels. If the bike is 25-30 years old, the spring will be shorter and less springy than it ought to be. Most of them had too much sag right out of the box anyway because they weren't designed for big heavy Westerners to sit on.
You can adjust static sag to an extent with the preload adjustment.
Then there is rider sag which is how much more they drop when you put the rider on, this is about spring rate/strength. Again, usually way less than it should be.
The normal procedure is to use a spring calculator tool to work out what spring rate you should have, set the static sag with the preload adjuster and the rider sag should be about right.
Then what happens is having fixed the shock, it highlights how shitty the fork springs are, so you replace the springs, sort out the damping and you now notice how crap the brakes are.
I know quite a few people who have had good experiences with chinese shocks. Not uncommon for club racers to use them. They sell them by extended length. Not usually quoting a spring rate but still usually better than the old tired ones that were fitted. I've got a set on my bullet that are going on 4 years old now. No complaints. Adjustable gas damping and a massive improvement on the originals. Cost me £80 delivered so can be worth a punt. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Bhud |
 Bhud World Chat Champion
| chickenstrip |
 chickenstrip Super Spammer
 Posted: 13:37 - 23 Apr 2020 Post subject: |
I'm not great on knowledge of how to set suspension up - I suppose I'm just lazy, and haven't taken the time to learn about it. But I do know that when done properly, it can really transform the enjoyment of riding a bike, to the extent that if you don't know/can't be arsed to do it yourself, it is worth paying someone who knows what they are doing to sort it for you (up to a point!).
You really don't know what a bike's handling potential is until you have decent suspension, properly dialled in on it. And if it isn't, you're really wasting your bike - assuming you like to push things a bit on a nice twisty road. If you just like to bimble around, it's no big deal though, not worth throwing the time and money at - again, assumimg it's not dangerously bad. But when you do sort it properly, you may find yourself pushing it on a ride anyway, simply because it just copes with what you throw at it. I did this because on standard suspension, I was finding fault.
So on my current bike, the philosophy has been to spend a bit and let others who understand it all sort out the adjustment. It may be that things could be better still, but I'm happy with how it performs for my level of ability on a bike. I've had the pegs scraping without feeling on the ragged edge of control, and that's certainly good enough for me, and the ride generally is smooth, goes where I point it without drama. I did the conversion because with the standard suspension, I was finding fault. But if you're not feeling at all limited by how your suspension behaves, probably not worth the effort to play around, especially if you don't really know what you're doing.
Prompted by Bhud's comment - even a cheaper-end replacement shock is worth it if your standard item is knackered, from a performance point of view, though it might not last as well as the higher-end ones, which might also be rebuildable. On one of my last Fazers, I replaced the rear shock with a new Hagon item - it might not be at the level of Nitron and some others, but still better than the tired old standard job that was on there, and didn't break the bank. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
THERE'S MILLIONS OF CHICKENSTRIPS OUT THERE! |
| MarJay |
 MarJay But it's British!
| wr6133 |
 wr6133 World Chat Champion
| chickenstrip |
 Posted: 14:37 - 23 Apr 2020 Post subject: |
| wr6133 wrote: | My prior ZZR around 80k miles, shock just bottomed out while riding and then stuck in position, spitting me down the road. Replaced that with a YSS as well, was like a new bike. |
I had that happen to me on my GSXR750 (slabby), the one time I had the measure of a mate who was always quicker than me. Well, don't think it bottomed then stuck - probably a seal blew or something like that. Went from switching corners happily to wallowing all over the shop on a fast sweeper. Didn't spit me off, thankfully. He came past laughing his head off  ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| A100man |
 Posted: 15:16 - 23 Apr 2020 Post subject: |
| Bhud wrote: | Are you talking about your Yamaha Diversion? |
No FZ750 (even older.) the 'XJ598' btw is actually an early 80s XJ550 with a Radian 600 motor in it. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| A100man |
 Posted: 15:19 - 23 Apr 2020 Post subject: |
Thanks all for the tips _ I'll take a look at 'sag' and see where that leads.
I'm built more like Jorge Lorenzo* than Michael Dunlop so bottoming out hasn't happened and I'd say I'm much more bimbler than racer.
* or how he might be in another 20 years ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| Bhud |
| chickenstrip |
 Posted: 15:30 - 23 Apr 2020 Post subject: |
| A100man wrote: | I'd say I'm much more bimbler than racer.
Thing is, you're talking 'Practical Sportsbike' magazine. If you're a bimbler, or ride to commute, or to take in the countryside, less reason to be concerned about having the very best suspension - just want something that's adequate. If there's nothing that is annoying you about the handling of your bike, and it's not in a dangerous condition, why fiddle with it? But a sports bike needs good suspension because of the very nature of the type. ____________________ Chickenystripgeezer's Biking Life (Latest update 19/10/18) Belgium, France, Italy, Austria tour 2016 Picos de Europa, Pyrenees and French Alps tour 2017 Scotland Trip 1, now with BONUS FEATURE edit, 5/10/19, on page 2 Scotland Trip 2 Luxembourg, Black Forest, Switzerland, Vosges Trip 2017
| wr6133 |
| A100man |
 Posted: 16:23 - 23 Apr 2020 Post subject: |
| Bhud wrote: | | A100man wrote: |
No FZ750 (even older.) the 'XJ598' btw is actually an early 80s XJ550 with a Radian 600 motor in it. |
Oh, so it's an XJ600 then. Always liked the look of those.
Almost - here it is part way through assembly- tyres were just to get it rolling but you can see the tragic chinko shocks.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| wr6133 |
| stinkwheel |
| A100man |
 Posted: 11:36 - 24 Apr 2020 Post subject: |
| wr6133 wrote: |
Thought it was a monoshock guess I should read properly
I'd do as stinkwheel suggests get on Fleabay or similar and buy by extended length. |
No sorry it was me confusing the issue, two bikes
a) FZ750 monoshock - seems OK but am I skilled enough to tell
b) XJ550/600 dualshock (pictured) - chinko shocks are awful even to me. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| wr6133 |
| stinkwheel |
| Kawasaki Jimbo |
 Kawasaki Jimbo World Chat Champion
 Posted: 18:18 - 24 Apr 2020 Post subject: |
You need to think about what the front and rear are doing on bends, rather than how the suspension bounces or shields you from bumps. The summary in the link below has a nice little graphic.
https://www.gostar-racing.com/club/motorcycle_suspension_set-up.htm
Think about how the bike steers: tipping in, holding a line, exiting. Try to work out what front and rear are doing; are they diving/rising too fast or too slow, or not working together.
Find a half-mile stretch of road with a roundabout at each end and a parking spot along it to fiddle with suspension settings. I did this with the ZX6R and although there was no eureka sweet spot moment I do think it was improved. I was lucky insofar as the front seemed to be spot on. It can even be hard to work out whether it's the front or rear that needs a tweak, and any adjustment might well influence how the other end behaves. Record your starting settings.
My R1 could do with some adjustment to combat a tendency to run wide but I've ridden around the issue. The Kawasaki and the Yamaha have stock fronts but I've fitted Ohlins rears, eBayed and professionally rebuilt.
It's a bloody complicated topic! Interesting though. |
| Bhud |
| stinkwheel |
| Pigeon |
 Pigeon World Chat Champion
 Posted: 23:54 - 24 Apr 2020 Post subject: |
| stinkwheel wrote: | Then what happens is having fixed the shock, it highlights how shitty the fork springs are, so you replace the springs, sort out the damping and you now notice how crap the brakes are.
Funny because so true.
| stinkwheel wrote: |
I know quite a few people who have had good experiences with chinese shocks. Not uncommon for club racers to use them. Adjustable gas damping and a massive improvement on the originals. Cost me £80 delivered so can be worth a punt.
Don't suppose you have you got any internet links to hand / share?
I found KYB and Showa do about 20k miles before the gas partially escaped / oil was passed its best.
So have bought very low mileage (claimed) units for £80-100 and kept them. Then I replace the oil/gas in the originals, but once the seals / bushes have gone, will swap to the second hand units.
Simply because at that price, you almost never lose. And it doesn't take many years before the quality of secondhand shocks has fallen off while the price has gone up.
Example, I bought a zero mile '18 GSXR1000 shock for £80.
But trying to find a late 90's XR250 shock that isn't rusted to hell / pitted etc is tricky. For example, currently ebay has a decent one from Canada for £195
YSS is £225 and doesn't have compression adjustment.
So to get near original and new (Nitron with Comp/Rebound damping), its nearer £400. Half the value of the bike.
EDIT:
Doh! Just seen the link above, apologies.
Generally. My 2p. I think of suspension; its simply how far and how fast shocks move to affect bike geometry, tyre connection to the road and rider comfort based on weight, speed and road conditions.
It's a constant compromise.
But if you don't stray too far from the standard rider, ie circa 12st rider, progressive throttle, max speed 90mph, A/B-Roads, then bikes are setup for that (and the rest of the components are based on the same premise; a price point aimed at a particular band of consumers).
At 17st you fall out that bracket (and most things without decent support lol). And as soon as one thing is changed, it exposes everything else.
Springs and Oil are a relatively slow PITA job. Compression and rebound are quick and easy fine tuning.
So you want to aim for a situation where springs and oil get you as close to where you want to be.
Compression and rebound damping should just be fine tuning. |
| A100man |
 Posted: 10:28 - 25 Apr 2020 Post subject: |
| stinkwheel wrote: |
Alfa pipe tho. Mate had one on his CB750. Growly.
Yessum! Had one on my 'original' red XJ550 in 1984. Spotted this one on ebay and had to have it for my 2015 reboot ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
The last post was made 6 years, 152 days ago. Instead of replying here, would creating a new thread be more useful? |
