Kawasaki GPZ500R suspension issue
Camelot
PostPosted: 16:02 - 23 Apr 2020    Post subject: Kawasaki GPZ500R suspension issue Reply with quote
Hello,
I have just finished my '85 GPZ500R restoration project.
The bike is now very nice, but not good Confused . At lest not good enough.
On straight cruising, somewhere around 90 kmh it becomes instabile. Not realy head-shake, just all sudden it gets very-very sensitive. It is hard to keep it in straight line. The better the road, the worse the problem.
When leaned the problem is not that bad, but I think it can get better in the corners also. When braking hard, the bike stayes stabile.
What we have done:
- new wheel bearings
- new steering bearings
- new tyres
- rebuilt front shocks
- reconditioned, regreased rear suspension
- rebuilt AVDS system
What we checked so far:
- no play in the front or rear suspension
- the steering is neither tight nor loose
- the frame looks straight, no obvious damage or welding
- the front fork oil levels are right to specs
- the fork oil is new, and correct type (7.5W)
- wheels are straight and balanced, checked for runout (0.1mms)
- suspension geometry is good
- tyre pressure is ok (the lower I set, the better the problem gets, but cant eliminate it)
- pressure in the forks is in specs
And we are now out of steam... please give us a hand...
jaffa90
PostPosted: 17:00 - 23 Apr 2020    Post subject: Reply with quote
Which side of the road do you ride?
Are left hand bends easier than the right or the other way round?
Are the tyres hot or rasping after a run?
How old are tyres?
PostPosted: 17:06 - 23 Apr 2020    Post subject: Reply with quote
Presume that's the same as a GPZ500s?
You got the belly pan on? They weave at high speeds without it and the belly pans are commonly either broken going over a kerb or melted on an aftermarket 2-1 exhaust.
They can get sketchy on a worn front tyre (not worn out, just worn down) with a tendancy to track along linear obstacles in the road.
What tyres do you have fitted? I'd personally only use BT45 or roadriders. I once fitted contis to my GPZ and took them off again after 500 miles, it was all over the shop.
You regreased the rear suspension and say you checked it for play but just have a look at the unitrak bushings for vertical play. With it on the mainstand and the rear wheel in the air, get a pry bar under the back wheel and see how far you can lift it before you come up against the shock spring, you might get a shock. They are plastic, mine had to be replaced every year to pass the MOT on both my GPZ500s until I got a machinist to make me new sleeves and bronze bushes for it. A tiny amount of play here translates to a significant amount of play on the swingarm.
Have you checked the sprocket carrier bearing? It can be totally fucked (like smashed into little bits like gravel) with little obvious external sign.
Camelot
PostPosted: 20:33 - 23 Apr 2020    Post subject: Reply with quote
How old are tyres?
We ride on the right side.
I hardly feel any difference.
Not checked the tyre temperature, but I will tomorow.
Tyres are new (made 2019, fitted 200kms/1 month ago.
Camelot
PostPosted: 20:43 - 23 Apr 2020    Post subject: Reply with quote
stinkwheel wrote:
Presume that's the same as a GPZ500s?"
No. It is a GPZ500R, wirtualy the same bike as the GPZ600R, but with smaller bores.
stinkwheel wrote:
"You got the belly pan on? They weave at high speeds without it and the belly pans are commonly either broken going over a kerb or melted on an aftermarket 2-1 exhaust."
The belly pan is on the bike.
stinkwheel wrote:
"They can get sketchy on a worn front tyre (not worn out, just worn down) with a tendancy to track along linear obstacles in the road."
We have brand new tyres (Bridgestone Battlax bt45, matching pair, factory size.
stinkwheel wrote:
"You regreased the rear suspension and say you checked it for play but just have a look at the unitrak bushings for vertical play. With it on the mainstand and the rear wheel in the air, get a pry bar under the back wheel and see how far you can lift it before you come up against the shock spring, you might get a shock. They are plastic, mine had to be replaced every year to pass the MOT on both my GPZ500s until I got a machinist to make me new sleeves and bronze bushes for it. A tiny amount of play here translates to a significant amount of play on the swingarm."
I have checked the trailing arm vertical movement: zero.
stinkwheel wrote:
"Have you checked the sprocket carrier bearing? It can be totally fucked (like smashed into little bits like gravel) with little obvious external sign.
Brand new.
PostPosted: 20:52 - 23 Apr 2020    Post subject: Reply with quote
So an inline four?
Camelot
PostPosted: 20:56 - 23 Apr 2020    Post subject: Reply with quote
stinkwheel wrote:
So an inline four?
Yes. Same bike as the 600r. It was only done for some countries, like Austria.
sickpup
Old Timer
PostPosted: 08:54 - 24 Apr 2020    Post subject: Reply with quote
If your bike is the same spec as the 600r it uses 16" wheels which were a bit of an odd tyre size which is no longer used on sports bikes as they are prone to being sensitive anyway.
The one thing you haven't mentioned is the rear shock or ride heights.
A rear shock that is shot, has low high preload or the forks raised through the yokes will cause the bike to become more sensitive but then most bikes have a sensitive spot in a 10 mile range anywhere between about 40-60mph and this could just be that.
Camelot
PostPosted: 10:10 - 24 Apr 2020    Post subject: Reply with quote
The rear shock is a bit of a dark horse for me. It is a pressurized system. No obvious sings of any problem. I have tried it with no, minimal, modest and maximum factory advised pressures. The lower the pressure the better it gets, but still far from good. How can I test the rear shock?
Camelot
PostPosted: 10:12 - 24 Apr 2020    Post subject: Reply with quote
- wrote:
I'd have normally gone for worn steering bearings or worn bushing of bearings in the swing arm, although the OP says these are OK.
Maybe time to get it off the ground and check again for movement both ways?
The bike is now on stand, with wheels removed. No or realyrealy minimal horizontal movement is present on the trailing arm. Minimal vertical play on the top suspension link bushes. Steering/front struts are ok.
Easy-X
PostPosted: 13:00 - 24 Apr 2020    Post subject: Reply with quote
Total n00b observation... if it were off the deck so both wheels spin freely could you use something like a drill (with fuck knows what attachment) to spin up one wheel and see if a wobble appears?
Alternatively could the "rolling road" of a dyno help?
redeem ouzzer
PostPosted: 13:12 - 24 Apr 2020    Post subject: Reply with quote
No. Stop being a complete desk.
Be a REAL MAN!
PostPosted: 13:43 - 24 Apr 2020    Post subject: Reply with quote
It was very common back in the day to disconnect and blank off the anti dive system on the forks. May have been because people simply didn't like it but I wonder if there is more to it than that?
I dimly recall it not being as straightforward as simply removing it and covering the hole, something needed to be pushed in and held there by the blanking plate.
Camelot
PostPosted: 15:44 - 24 Apr 2020    Post subject: Reply with quote
I dont think that the AVDS has anything to do with the straight line ability of the bike. By the way, I like the system. I had a GPX with an electric unit. It was also working well with my driving style. This full mechanical unit can even be better.
The last post was made 6 years, 132 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.55 - MySQL Queries: 13 - Page Size: 89 Kb
