| dangdididang |
 dangdididang L Plate Warrior
 Posted: 19:36 - 23 Apr 2020 Post subject: |
Is it oily, like mayonaise?
If there is oil getting into the coolant, it's usually either the head gasket or the water pump oil seal.
For cleaning mayo out, scrape out what you can reach, remove the hoses and flush them through, flush everything else with hot (boiling) water and detergent, then lots of flushing (hosepipe).
Don't just refill unless you know and have dealt with the source of the problem. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| dangdididang |
 Posted: 20:50 - 23 Apr 2020 Post subject: |
With head gaskets, I think it depends where the leak is, stuff moves from high to low pressure so if it's between a high pressure oilway and the water jacket, I can't see how coolant could get into the oil. If it's between a low pressure oilway and the water jacket, you're going to get coolant in the oil.
That said, I'd check water pump first because it's simpler. You may want to strip it anyway if it's choked with mayo.
No idea how big a job a water pump oil seal is on a Hornet but it looks like it may be a bolt-on unit, which seems promising.
Another option is that an idiot has put oil in the radiator/expansion bottle at some point. Stuff like that happens. There is a famous thread on one forum where someone put NOS branded energy drink in their engine thinking it was a fuel additive. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| dangdididang |
 Posted: 21:27 - 23 Apr 2020 Post subject: |
Can you post a pic of the sludge?
Do you still have the old coolant bottle?
There is another possability. If you mix OAT and silicone based coolants, you can get a solid forming. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| dangdididang |
| Easy-X |
 Easy-X Super Spammer
 Posted: 00:58 - 24 Apr 2020 Post subject: |
I read the title and thought: "sack your barista!"  ____________________ Royal Enfield Continental GT 535, Husqvarna Vitpilen 401, Yamaha XSR700, Honda Rebel, Yamaha DT175, Suzuki SV650 (loan) Fazer 600, Keeway Superlight 125, 50cc turd scooter |
| Kentol750 |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
 Kentol750 World Chat Champion
| davebike |
 davebike World Chat Champion
 Posted: 07:48 - 24 Apr 2020 Post subject: |
Honda hornet well know in the trade fro blown head gaskets issue is caused by engine designed for cradle frame being used as a stressed member
Best cure is often a used engine as head is often distorted ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| droog |
 droog Spanner Monkey
| dangdididang |
| Easy-X |
The last post was made 6 years, 134 days ago. Instead of replying here, would creating a new thread be more useful? |
