83' KZ400 Engine Block Repair.....
Ace Rimmer
PostPosted: 13:20 - 25 Apr 2020    Post subject: 83' KZ400 Engine Block Repair..... Reply with quote
HELLO!
First post on (or in I'm not sure which) this forum and well basically, I'm really hoping that there's something that I can do with this love of mine! It's a gifted 1983 KZ400E thats been half chopped and just needs the finishing touches applied. It's from a dear friend and the bike represents quite a sicknificint part of my life from back in the good ol days so it'll be fooking wicked to get the mini beast back on the road or at least close to mot ready!
SO FAR -
It's been dormant for about 7 years, Now i find some time on my hands out it comes and (Cilla black) surprise surprise its actually turning over! Good testings from the starter motor, everything works all the way to the coils so have just received new ones of them when
DEVASTATING NEWS
On the front right lower engine mount, upon the engine side there a whooping great crack that looks as though its either been over tightened or the bike has been dropped on this side in the past. It passes right the way through to the other side i'm pretty sure it'll fall off when I take he engine out.
I kinda feel that its far away enough from the block itself that it may be repairable? What are your thoughts? Am I mad to think this may be possible?
Failing a fix, what other engines could I mount into the frame of my potentially prestigious ride. An upgrade in power would be nice but we shall see what comes up!
Thanks
Greg.
Riejufixing
PostPosted: 13:40 - 25 Apr 2020    Post subject: Reply with quote
Are these both the same mounting, one from in front, one from underneath?
You'll have to get the thing out, but it looks weldable. You want an artiste with a high frequency set. I'd guess that the damage has occurred due to incorrect mounting bolts allowing the whole engine to chatter and vibrate in the frame.
Easy-X
PostPosted: 13:45 - 25 Apr 2020    Post subject: Reply with quote
Dab of JB Weld... no, maybe not!
Just to put it in perspective here's (I think I have the right bike) a better view:
https://livedoor.blogimg.jp/mccraft/imgs/7/1/71510a03.jpg
So lower offside mount?
Ace Rimmer
PostPosted: 14:15 - 25 Apr 2020    Post subject: Reply with quote
Easy-X - Yep pretty sure thats the same - the lower offside mount - on the engine side not so much the frame welded mounting bracket but the casting on the block itself.
Riejufixing - yep the same mounting, from underneath in pic2Glad to hear it sound fixable, thanks for the tip with the high frequency set there. was thinking this also, I notice there are different nuts on the end of some of these engine mounting bolts so was thinking
Going to get it out now and clean/inspect all the other mounting points both bike and engine. FINGERS CROSSED EH!!
Nice one thanks for the hasty reply, this is all the push I required! Thumbs Up Thumbs Up
Bhud
PostPosted: 14:19 - 25 Apr 2020    Post subject: Reply with quote
EDIT: removed link to crankcase that wouldn't fit
Riejufixing
PostPosted: 14:20 - 25 Apr 2020    Post subject: Reply with quote
That thing has a through bolt, you see. The hacking about that's happened to the rest of the frame reinforces my thought that the alloy has been stressed in directions it's not designed to be stressed in.
Ace Rimmer
PostPosted: 14:30 - 25 Apr 2020    Post subject: Reply with quote
RIIIIIIIIIIGHT!
I see, without the whole bold passing through to the other side of the engine and out the other side of frame the engine has moved about and cracked where unsupported. Gotcha.
I'll be back in a few hours when the engine is out and cleaner fingers crossed this is the only one I find!
Thanks again!
PostPosted: 17:58 - 25 Apr 2020    Post subject: Reply with quote
You sir, have your work cut out if that and the hatchet job that's been done on the frame are anything to go by.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:20 - 25 Apr 2020    Post subject: Reply with quote
I'm with stinkwheel.
Look at how much money you are prepared to throw at this pile of shit and see if you can buy a 50cc scooter instead.
Triumph Sprint ST 1050
Tdibs
PostPosted: 18:54 - 25 Apr 2020    Post subject: Reply with quote
''finishing touches'' seems a bit optimistic mate...
Sorry to say, but if that was in my shed, I would be parting out what I could. You have a chopped to scrap frame, a engine with a broken mount, whats are the other parts like!?!
Such a shame as it seems like a original 400/4 kawa would bee a awesome little bike Sad
PostPosted: 19:20 - 25 Apr 2020    Post subject: Reply with quote
It's not unsaveable but it's going to take a lot of work. Considerably more than it's eventual monetary value. That doesn't mean it's not worth doing.
PostPosted: 19:46 - 25 Apr 2020    Post subject: Reply with quote
Could be that the bolt has rusted in the hole and the rust has burst the casing.
Anyway, it's a welding job to repair. Engine-out to do it even half right.
Riejufixing
PostPosted: 20:11 - 25 Apr 2020    Post subject: Reply with quote
("but it's not profitable") See OP.
Ace Rimmer
PostPosted: 12:19 - 26 Apr 2020    Post subject: Reply with quote
Optimism is ripe at the moment! Yes quite a bit of work todo on the frame but with the engine out it should be a whole lot easier to work on + a well made placed heavy duty bracket somewhere on the subframe should do the trick. I'm open to suggestions on that one!
As for the monetary value I'm not so fussed as Im able to fabricate most of the brackets/mounts/farings myself so really as I know the engine is sound I'll not be giving up on it quite yet! (+ that metallic green finish on the tank is to die for!)[/quote]
steve the grease
PostPosted: 13:36 - 26 Apr 2020    Post subject: Reply with quote
Pete you got there whilst I was typing.
My opinion is that what you have is a corrosion based crack , water has got in between the bolt and has sat there , lots of that shitty white powder aluminium corrosion has been the result and that has expanded and cracked the boss.
I don't think its a big deal, the mount is under compression in that one face of the alloy boss sits against a plate of the engine mounting, as long as it's welded up and has the joint face between the engine and the frame reasonably flat and you can get a nut and bolt through I think it will be fine.
Lots more places are doing ally welding nowadays as the price of TIG gear has come down.
Go for it.
Anyone can buy a new bike , a bike that represents a ' significant part of your past' is unique to you.
Ace Rimmer
PostPosted: 18:03 - 26 Apr 2020    Post subject: Reply with quote
More bits.... Shocked
steve the grease
PostPosted: 18:14 - 26 Apr 2020    Post subject: Reply with quote
Yeah , that is looking a bit sad, are those other pictures the exhaust ports?
A few cases on Ebay for 50.00 ish up. something will turn up.
Riejufixing
PostPosted: 18:59 - 26 Apr 2020    Post subject: Reply with quote
Can we have one thread, as the two existing are so similar?
Ace Rimmer
PostPosted: 22:22 - 26 Apr 2020    Post subject: Reply with quote
yep!
https://www.bikechatforums.com/viewtopic.php?t=330288&start=0&postdays=0&postorder=asc&highlight=&sid=5e716c0b5e6da91e20e4771c3fd8eea4
The last post was made 6 years, 124 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 0.41 - MySQL Queries: 15 - Page Size: 102.64 Kb
