Pilot jet /main jet size - hornet 600 (Cb 600 f3)
rehmh05
PostPosted: 19:02 - 27 Apr 2020    Post subject: Pilot jet /main jet size - hornet 600 (Cb 600 f3) Reply with quote
Symptoms ; difficulty starting without choke ... running rich smell - also doesn’t go past 85 mph (about 8k rpm in every gear- almost full rpm in neutral - coughs and splutters around this rpm like it’s choking / out of fuel / too much fuel ?) this issue was from the time I bought the bike
I’ve opened up my float bowls of my carbs to clean out suspected jets blocked And I found completely different sizes and am completely confused where to go next / what to do
1) the pilot jets are 40s - Haynes manual says 40
2) main jets are 105 and 108 - Haynes says 100 and 102
My question :
1) After cleaning them out will they be ok to use in the configuration they are in? Or are they the cause of lack of top speed / acceleration / hard starting / limited rpm
2) do I need to also check the jet needles ? The bolts look seized and I already had a lot of trouble opening the float screws
Anything else I should know / do?
Ps. Spark plugs been changed about 2 months ago by myself and it’s running better but still not right
- CBT 31/10/12 - CBR 125 bought 01/11/12
- Theory: 07/11/12 - Mod 1: 19/11/12 - Mod 2: 28/11/12
- 24/08/13 - Bandit 600
PostPosted: 19:34 - 27 Apr 2020    Post subject: Reply with quote
I'd say if it has been running properly on them at some point, leave it at that for the time being.
Does it have a standard airbox/air filter/exhaust? I wonder if it's had a dynojet kit fitted.?
Looking at the hornet instructions, a dynojet kitted bike will have an extra washer above the E-clip on the throttle needle.
rehmh05
PostPosted: 19:54 - 27 Apr 2020    Post subject: Reply with quote
Air filter and box looks daily standard - exhaust is a scorpion . Which is a bit rattly sometime .
The jets and float bowl etc looked fairly clean
The bike is apart so I rather get the parts needed if these won’t do ... as for a dyno jet kit - I’m not sure - where is the throttle needle please ?
PostPosted: 20:24 - 27 Apr 2020    Post subject: Reply with quote
It's in the top part of the carb attached to the diaphragm. May be worth giving these a visual inspection and checking which notch the needles are on. Look carefully for any tears or pinholes in the diaphragm.
NB: Carb diaphragms are delicate. Take care. If you aren't happy messing with these, leave the lids on or get someone else to have a look. At a minimum, familiarise yourself with the parts of a CV carb.
rehmh05
PostPosted: 21:28 - 27 Apr 2020    Post subject: Reply with quote
Oh - the needle jet. Yes I’m aware of parts of the carbs . Sorry it just said a different name in Haynes “ needle jet” or something to that effect . I was avoiding opening it but ok I’ll give that a go tomorrow.
As for the jets : will I have to get original ones ? Or is my problem elsewhere ?
jaffa90
PostPosted: 23:03 - 27 Apr 2020    Post subject: Reply with quote
"""Ps. Spark plugs been changed about 2 months ago by myself and it’s running better but still not right"""
What did the old spark plugs tell you?
PostPosted: 00:14 - 28 Apr 2020    Post subject: Reply with quote
Hang on though. I just went to check a parts list and it looks like a CB600F3 (2009/10) is fuel injected?
What year bike is this?
jaffa90
PostPosted: 00:29 - 28 Apr 2020    Post subject: Reply with quote
Hopefully 2003?
PostPosted: 00:51 - 28 Apr 2020    Post subject: Reply with quote
jaffa90 wrote:
Hopefully 2003?
In which case CMSNL list a 115 main jet for a 2003 hornet 600
It lists 100/102 for earlier models.
It lists 105/108 for 2002 models.
jaffa90
PostPosted: 01:02 - 28 Apr 2020    Post subject: Reply with quote
Why not choke /seal the air intake by 75% and test again.
PostPosted: 01:16 - 28 Apr 2020    Post subject: Reply with quote
In fairness. A 600 hornet topping out at 8,000rpm/85mph. I'd be querying if it's running on all 4 cylinders.
Are all 4 exhausts getting hot? (don't touch them, put a drop of oil on the header pipes and see if it burns off).
rehmh05
PostPosted: 01:37 - 28 Apr 2020    Post subject: Reply with quote
Even if I hear the swoosh from moving them up and down: does that still mean that they could be damaged ?
rehmh05
PostPosted: 13:08 - 28 Apr 2020    Post subject: Reply with quote
Sorry guys not received any message (updates) until this morning .but I could send my message . Not sure if it’s a forum issue or my internet (because I posted my message and could see it )
anyway I Opened the diaphragms up: they all contain a washer at top of needle - needle number is B97A (which is for cb600f-5 onward models ? model number of carbs is: 49 FA
I can’t really check the cylinder temperature without putting it all back together (something I should have at the start Sad )
Model is 2003 Cb 600 f2 . Haynes showing cb600f w- 4 models as 100 and 102 ?
pictures of sparks coming up... also note: spark plugs that were instlled were cr8ehix-9 - whereas cr9eh -9 were supposed to be in there. i put CR9EHIX-9
https://ibb.co/vB23KMj
https://ibb.co/MC1qgjp
PostPosted: 13:50 - 28 Apr 2020    Post subject: Reply with quote
105/108 appears to be correct for a 2002 CB600 (2) according to the Honda parts list. Maybe the dealer had previous years stock still in and registered it on an '03 plate.
EDIT: Same list also shows CR9EH9 plugs as standard.
rehmh05
PostPosted: 13:58 - 28 Apr 2020    Post subject: Reply with quote
Ive attached the picture of old spark plugs; can you see them ? unfortunately theyre not in order of the cylinders
rehmh05
PostPosted: 14:03 - 28 Apr 2020    Post subject: Reply with quote
So the carbs are fine ? i can put everything back?
Note: i found some bits of foam in top under the diaphragm and a chunk in the hole between the carbs (top of carbs) . i believe its from the disintegrated sub air cleaner hose (filter). these were between 2-3 - where the air comes in from the sub air cleaner hose. Partially blocking the way of carbs 2-3.
Also the colour is golden for middle two carbs in the top and one seems really really clean and one is slightly golden. Could these indicate a problem?
jaffa90
PostPosted: 14:21 - 28 Apr 2020    Post subject: Reply with quote
Them plugs are sooty rich. If the carbs are standard with the choke working what about this you say.
"""" exhaust is a scorpion . Which is a bit rattly sometime """
Check for loose baffles restricting exhaust flow.
rehmh05
PostPosted: 14:22 - 28 Apr 2020    Post subject: Reply with quote
So does that mean haynes manual is wrong ? or do i have a wrong manual? It doesnt show 105/108 for any of the models?
https://ibb.co/MckW4Ks
https://ibb.co/WFDQ6MM
rehmh05
PostPosted: 14:35 - 28 Apr 2020    Post subject: Reply with quote
Exhaust baffle looks / feels intact.There looks like some mod on the exhaust pipe - can that be causing restricted flow?
https://ibb.co/gZ00Jbc
As for running rich - i can smell it running rich and my clothes have a burnt fuel kind of smell after a ride. Choke has to be used to start it then its run without choke.
PostPosted: 17:07 - 28 Apr 2020    Post subject: Reply with quote
https://www.cmsnl.com/honda-cb600f-hornet-2002-2-england-mkh_model1636/partslist/E__1801.html#.XqhUhKZ7nRY
Parts 32 and 33.
Assuming yours is a 2002 model.
rehmh05
PostPosted: 04:39 - 29 Apr 2020    Post subject: Reply with quote
I put it all back together and sprayed water onto all 4 exhausts -
Outer exhaust had a slightly longer evaporation Time (like a second / some milliseconds ) inner 2 exhausts evaporated water immediately - (note ; it’s a very small difference in evaporation but certainly outer ones take slightly longer )
Have a bit of a sticky throttle now . Will take for a run tomorrow and see if it’s still at 8 k rpm. Also have changed air filter ....
rehmh05
PostPosted: 21:14 - 29 Apr 2020    Post subject: Reply with quote
Hi guys -
It has been sorted now ! Thank you to every single person who replied!!!!
For the benefit of other people : the sub air filter was disintegrated. When I opened the top end of the carbs - it had foam bit stuck in the tube between carb 2 and 3 . This was really gunked up and was probably restricting airflow from the sub air filter . I don’t know the purpose of the sub air filter but maybe it was stopping the diaphragms from moving or something ?! Can someone confirm this ?
But now it’s full power and I’m in love with it !!!
Thank you everyone
PostPosted: 21:29 - 29 Apr 2020    Post subject: Reply with quote
There are several little auxillay jets located behind the bellmouths, perhaps it was blocking one or more of these.
The last post was made 6 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 127.72 Kb
