Honda ZB50 Restore / Need Help
Mel_Macallan
PostPosted: 22:53 - 29 Apr 2020    Post subject: Honda ZB50 Restore / Need Help Reply with quote
Hi Guys,
I'm new in this forum and really hoping to find some help here.
Just a little info about myself ; While I was living in Hawaii, I worked on a bunch of scooters (just as a hobby), so I have basic knowledge of that. Besides that, I own a Honda Shadow 750 and a two Sportster 1200, but usually don't have to do more than regular maintenance on them. So that's that 😉
My father recently picked up this 1988 ZB50. For at least past 10 years or so, it was wasting away in some dirty backyard.
After he picked it up, he added some new oil and surprise - it ran. But only for about 2 min then it died. Afterwards he tried again but nothing.
Like mentioned, after 10 years laying around outdoors it was in a miserable condition. The garage in our neighbourhood didn't even consider to touching it. They took one look at it and turned my father away.
So I wanted to help and promised my dad to try 'n fix it, not knowing what I'm getting myself into LOL
Of course my first plan was to do the simple maintenance things, like clean carb etc but that didn't do it. The bike was dead, so I started to look closer and the closer I looked the more I realized in how bad of a shape that poor little bike was.
The must have went through a few crashes. There is no more key switch, and also no kill switch (no switch on right handlebar at all). There was no battery, but its kickstart only, so that's ok I guess. The kickstart was stripped, and engine full dirt, gunk and even tiny metal gravel. I ended up taking the whole thing apart cleaning every single piece and replacing some of them too.
I checked the electrical harness, repaired it as good as I could.
I got a battery for it and now the lights are all working, I checked all the ground wires and got a new Key-switch. Still there is NO Kill-switch, so I bypassed it and now everything runs through the Key-switch.
I put everything back togher yesterday, but still nothing. Engine doesn't to turn over - No spark. 😭
Its been over month now, but can't get it to run.
I went to a garage yesterday and the guy was real nice and gave me some advise. He suggested to take off the plug of ignition coil cable (where spark plug attaches to, and hold it directly to the engine(ground) to check for spark.
I did this today - no spark.
So my conclusion for now is, that it might be faulty stator (attached some photos). I did try to clean it up (so it doesn't look as bad as in the pic, but just cause it looks clean doesn't mean its in better shape I guess 🤓)
Anyone here got any experience with this bike? I would do a test with multimeter on the stator but as I don't have the service manual of the ZB50 I don't know what the correct reading should be.
Any constructive help / advise would be appreciated!
https://i92.photobucket.com/albums/l9/melaniechy/20200316_114413.jpg[img]https://i92.photobucket.com/albums/l9/melaniechy/20200316_114413.jpg
[img][URL=https://s92.photobucket.com/user/melaniechy/media/20200402_150644.jpg.html]https://i92.photobucket.com/albums/l9/melaniechy/20200402_150644.jpg
[img][URL=https://s92.photobucket.com/user/melaniechy/media/20200429_134954.jpg.html]https://i92.photobucket.com/albums/l9/melaniechy/20200429_134954.jpg[img][URL=https://s92.photobucket.com/user/melaniechy/media/20200429_135116-1.jpg.html]https://i92.photobucket.com/albums/l9/melaniechy/20200429_135116-1.jpg[img][URL=https://s92.photobucket.com/user/melaniechy/media/20200429_135125-1.jpg.html]https://i92.photobucket.com/albums/l9/melaniechy/20200429_135125-1.jpg[img][URL=https://s92.photobucket.com/user/melaniechy/media/20200429_135138.jpg.html]https://i92.photobucket.com/albums/l9/melaniechy/20200429_135138.jpg
[/img][img][URL=https://s92.photobucket.com/user/melaniechy/media/20200429_135147.jpg.html]https://i92.photobucket.com/albums/l9/melaniechy/20200429_135147.jpg[URL=https://s92.photobucket.com/user/melaniechy/media/20200403_180455.jpg.html][IMG]https://i92.photobucket.com/albums/l9/melaniechy/20200403_180455.jpg
PostPosted: 22:58 - 29 Apr 2020    Post subject: Reply with quote
Have you fitted a new spark plug? (if not, do this first)
Does it have points or electronic ignition?
If points, file the surface of them, set the gap and consider replacing the condenser.
In any case, they are very simple ignition systems so it shouldn't take a lot of troubleshooting.
Riejufixing
PostPosted: 23:00 - 29 Apr 2020    Post subject: Re: Honda ZB50 Restore / Need Help Reply with quote
They haven't come out!
Riejufixing
PostPosted: 23:08 - 29 Apr 2020    Post subject: Re: Honda ZB50 Restore / Need Help Reply with quote
So you've unscrewewd the plug cap, and are looking for a spark from the exposed end of the HT wire to the engine? Should work if the otrher end of the cable is OK.... is it?
Mel_Macallan
PostPosted: 09:40 - 30 Apr 2020    Post subject: Reply with quote
Hi, I'm actually not sure about points or electronic ignition. Its kickstart only. There is the stator, rectifier, cdi and ignition coil.
Mel_Macallan
PostPosted: 09:42 - 30 Apr 2020    Post subject: Re: Honda ZB50 Restore / Need Help Reply with quote
Somehow its not letting me upload pics Sad I click on add attachment and then nothing happens
Mel_Macallan
PostPosted: 09:49 - 30 Apr 2020    Post subject: Re: Honda ZB50 Restore / Need Help Reply with quote
yes, that's what I did, held exposed wire directly to ground (engine) but nothing. no spark. so I guess either its the ignition coil or stator problem
PostPosted: 10:40 - 30 Apr 2020    Post subject: Reply with quote
Ok. If it has a CDI, that means it's electronic ignition.
Found a wiring diagram.
Forget about the lights. They are nothing to do with the ignition system. There are 5 wires attached to the CDI and these are what makes the bike run.
So get yourself a multimeter and set it to measure resistance (ohms).
Find the connector block that attaches to the CDI and disconnect it. Connect one probe of the meter to a piece of bare, shiny metal on the engine (the engine is used as an earth connection, a bolt head is fine, you may need to sand any corrosion off so it makes a good electrical contact). With the other proble, check the following wires that are attached to the bike side of that connector block (not the CDI side):
Green: This is the earth. Should read a very low resistance, similar to if you touched the two wires on the meter together.
Black with white stripe: This is the engine kill. Should read a very high (as in no reading, like the meter isn't connected to anything) resistance. With the kill switch pressed, this should change to a very low resistance.
Black with red stripe: This is the ignition power supply coil from the stator. This should read a resistance of between 50-300 ohms.
Blue with yellow stripe: This is the ignition pulse coil. It should read a resistance of 10-100 ohms.
Black with yellow stripe: This is connected to the ignition coil primary winding. It should read a resistance of 0.16-0.2 ohms.
One further test is the igintion coil secondary winding. Measure between the metal inside the sparkplug cap and bare metal on the frame. Should be 3700 to 4500 ohms.
If any of these are incorrect, it means there is either a fault with the componant you are testing or the wiring between where you are testing and the componant. Report back with your findings. If they are all correct, it should make a spark.
If they are all correct and you have a new plug fitted but it still isn't making a spark, I'd suspect the CDI may be faulty. These are trickier to test.
PostPosted: 10:43 - 30 Apr 2020    Post subject: Re: Honda ZB50 Restore / Need Help Reply with quote
That wont make a spark. There would need to be a gap for a spark to jump across. To check for a spark, you need a known to work sparkplug attached to the plug cap with the metal end of the plug touching shiny-clean bare metal on the frame. A spark will jump the plug electrodes. In bright sunshine it's hard to see but you can often hear it "snap".
Mel_Macallan
PostPosted: 10:48 - 30 Apr 2020    Post subject: Reply with quote
Wow cool!! thank you for all the tips. I will do that asap.
One thing is, that there is NO KILL SWITCH. It was missing when I received the bike. At the time I figured it not important and that I could just wire it through the key switch. so not the black / white wire connects straight from key switch to CDI.
Does that create a problem? Do I have to install a kill switch?
Riejufixing
PostPosted: 10:49 - 30 Apr 2020    Post subject: Re: Honda ZB50 Restore / Need Help Reply with quote
I strongly suspect that having worked on stuff before he's holding it to, not on.
Riejufixing
PostPosted: 10:51 - 30 Apr 2020    Post subject: Reply with quote
Coo! That's good! You must have an extensive library! Is there a resource here that people can upload such things to? If not, "suggestion"!
Mel_Macallan
PostPosted: 10:59 - 30 Apr 2020    Post subject: Reply with quote
yes!! that would be great! I don't have service manual at all, the once I saw online are totally overpriced Neutral
I have wiring diagram from CT70 I been told it is as close as it gets to Zb50
PostPosted: 11:03 - 30 Apr 2020    Post subject: Reply with quote
I found it online but it's the same as this CT70 diagram. Pretty much all small hondas of this age have the same wire colours and setup. It's the same as my H100 one too which is where I got the readings.
Mel_Macallan
PostPosted: 12:06 - 30 Apr 2020    Post subject: Photos Added :-) Reply with quote
just added some photos of the bike to my post 👍😃
PostPosted: 13:53 - 30 Apr 2020    Post subject: Reply with quote
That white on black wire kills the ignition when connected to earth. It should not be making contact with anything (open circuit) when the bike is supposed to be running.
Mel_Macallan
PostPosted: 18:36 - 30 Apr 2020    Post subject: Reply with quote
Hi Smile
So I made the test with multimeter.
BLACK / WHITE
with ignition off switch : 0.5 ohms
with ignition switch on : the meter stayed on OL (I tried with different settings 200, 2000. 20k ohms, ut nothing changed)
BLACK / RED
540 ohms
BLUE / YELLOW
116 ohms
GREEN
0.3 ohms
I forgot to measure the black / yellow 🤦🏻‍♀️
From this readings I assume the stator is gone?
I also checked the BLACK / WHITE with light probe (just out of curiosity) but there was no juice on any of the wires going to the CDI.
I also checked the ignition coil . I took the plug off then touched the prop to ground and the other end to the end of the cable this showed 6.2 (multimeter on 20k ohms setting)
the plug alone shows 9.8
but when they are connected I get no reading, eg the meter shows OL.
What do you think this means? the plug is fried? the the coil and cable ok?
PostPosted: 19:46 - 30 Apr 2020    Post subject: Reply with quote
I wouldn't necessarily call that fried to be fair. Ignition power coil resistance is on the high side but not out of the ballpark.
Usually if a winding has gone you get either internal shorts and so a reduced resistance or a broken wire and open circuit.
It's all very "agricultural" in there and your extra resistance may well be down to increased resistance in old, mucky connectors and earthing.
There is never any power in the ignition circuit unless the engine is spinning, it "self excites" by taking power direct from a seperate coil on the stator (which is the one you just tested). The battery is only working the lighting and has nothing at all to do with the ignition. It's possible you may get a voltage reading if you test between the black/red wire and the green wire and kick the bike over. It'll be a "dirty" and very short reading so I'd set the meter to measure AC volts. May not react quickly enough to show up on a digital meter though. I'd expect needle deflection on an analogue one.
Ignition switch is working.
Pulse coil resistance seems a tad on the high side, But again, a similar mode of failure as with a stator coil. It's probably worth checking the connectors for corrosion.
The pulse coil does need to send a pulse too, maybe worth checking the gap between the pulse coil and the rotor is reasonable (although from memory, it's non-adjustable).
Just noticed there is a coil earth connection, make sure this is in good order too.
Odd you are getting an open circuit with the plug in. Are you testing through the central electrode? If that reading is "real" it suggests either the plug is duff OR it's not making proper contact in the plug cap. it may be worth replacing the plug cap anyway (or as a temporary measure, just connecting the HT lead directly to the plug with a ring terminal).
Umm. You might be looking at a CDI failure. Don't panic though, they are common to lots of small hondas and you can get cheap pattern ones.
Riejufixing
PostPosted: 19:54 - 30 Apr 2020    Post subject: Reply with quote
You can check the coil. Disconnect the low tension lead from it. Connect up your HT & plug and let the plug rest on the engine/frame where you can see it. Take a wire from the non-earth side of the battery, and quickly brush it against the coil's LT connector (you don't want to just connect it, you want momentary contact only!). The plug should spark.
Mel_Macallan
PostPosted: 20:47 - 30 Apr 2020    Post subject: Reply with quote
First of all, I can't say thank you enough for taking time trying to help me out !!
Are you saying you think that the stator seems to be ok?? isnt the Black / red too high with 549ohms?
"It's probably worth checking the connectors for corrosion."
Do you mean on the stator itself or the plug that goes to/ from the CDI?
I actually already replaced the original CDI with a cheap Chinese model last week. it came in a wiring harness set that I ordered. maybe it is not actually compatible or it's just a faulty part (considering the price)? I could put the original CDI back in tomorrow. but that'll put me back to square on.
"Are you testing through the central electrode?"
Central electrode, isnt that part of the actual spark plug? Sorry, I'm really reaching my limits with the motorcycle part terms 🙈
I tested the ignition coil off the bike and without spark plug. I followed this video https://www.youtube.com/watch?v=ahKB3c4Zhis&t=83s
"HT lead directly to the plug with a ring terminal"
don't really understand that...
To come to a conclusion; Would be best to get another spark plug (I also already tried with some cheap chinese one I had laying around, also didn't get any spark ), replace ignition coil (or just plug?) and keep trying ?
Should I take a look again at the wiring harness? The ground cables connectors were super bad so I tried to fix that. I did some soldering, I checked them all (with light probe, not multimeter) and they are fine, but now I'm starting to doubt myself 😭😬
Mel_Macallan
PostPosted: 21:09 - 30 Apr 2020    Post subject: Reply with quote
"Connect up your HT & plug and let the plug rest on the engine/frame where you can see it."
Do you mean connect the spark plug and then brush the "hot" wire against the tip of the spark plug?
Riejufixing
PostPosted: 21:49 - 30 Apr 2020    Post subject: Reply with quote
No. Your coil is earthed to the frame. The HT lead goes from the coil's HT contact to the plug cap connected to the plug top thence to the plug tip, and the plug rests on the frame or engine, so that when the coil fires, the spark jumps the plug gap (25 thou or whatever) making the HT circuit back to the coil's earth.
The low tension side of the coil is also earthed to the frame, and the "hot" wire brushes the LT contact on the coil. This is the (momentary) LT circuit.
So your LT current flows, very briefly, through the LT coil in the coil, and when it disconnects, the magnetic field it created in the coil's core collapses, which fires the HT side and you should the able to see a spark at the sparking plug tip as normal, where you'd expect to see it.
PostPosted: 22:02 - 30 Apr 2020    Post subject: Reply with quote
I like the bike. I'd love you to get it up and running.
That bit of the stator (concerned with the ignition) is PROBABLY ok. The resistance is higher than expected but just think about what that stator winding is. It's a really (really!) long piece of copper wire wrapped round and round a bobbin. Only two real ways it can fail. 1) It can break, you would get an open circuit (very high resistance, OL on your meter). 2) The insulation can become damaged, it would make contact with another bit of the same wire or earth and you would get a reduction in resistance.
So, I can't think of an obvious failure mechanism that would slightly increase the resistance in a coil. You'd need to add in more wore for that to happen.
Both/all. Pull apart one at a time, inspect, sand off any visible corrosion, spray with WD40, reassemble.
But the original one DID work? In fairness, they tend not to break. I'd take the pepsi challenge with an original 80's honda CDI over a used chinese one of unknown provenance any day.
Yes, good. That seems correct. You went on to say you checked it with the plug in and goit an open circuit. Not something I've ever doneto be honest but I'd expect a reading of some sort. Anyway, don't worry about that for now.
HT = High tension. It's another term for the high voltage plug lead. I was suggesting you could potentially connect it directly to the top of the sparkplug as a temporary test. it would rule out a poor plug cap connection.
Try it with a new, out of the box plug or one off something else that is known to work (steal one from the lawnmower). It doesn't actually matter what grade of plug if all you're looking for is a spark with it outside the engine. ALWAYS suspect the plug first when your spark disappears. It's the very first thing I suggested you check Wink
It's not wrong.
However. Plug first. Then other stuff. I've spent days fault finding only to discover it was the plug. What really boils my piss is when you get a faulty plug new out of the box. There was a period in the mid 90's when NGK plugs could have a worse than 1 in 10 fail rate from new. There are a lot of fake sparkplugs floating about out there too, but them from a trusted source, not internet auction sites.
Mel_Macallan
PostPosted: 09:28 - 01 May 2020    Post subject: Reply with quote
Do you mean connect the spark plug and then brush the "hot" wire against the tip of the spark plug?[/quote]
No. Your coil is earthed to the frame. The HT lead goes from the coil's HT contact to the plug cap connected to the plug top thence to the plug tip, and the plug rests on the frame or engine, so that when the coil fires, the spark jumps the plug gap (25 thou or whatever) making the HT circuit back to the coil's earth...[/quote]
Great advise! Will give it a go! Hopefully won't electrocute myself LOL
Mel_Macallan
PostPosted: 09:46 - 01 May 2020    Post subject: Reply with quote
Fingers crossed!
I don't know if original worked, since I have the bike it never started. I been trouble shooting for a while now, so I was trying different things. I'll try more today and will put back the original and see.
I'll report back to you once I'm done, hopefully with a success story Very Happy
The last post was made 6 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 152.89 Kb
