Suzuki Van Van 125cc - Bike not starting
Mashona
PostPosted: 17:55 - 03 May 2020    Post subject: Suzuki Van Van 125cc - Bike not starting Reply with quote
Hi All
Can anyone help?
I tried starting the bike today, light comes on and engine wants to start but lacks charge. I tried once again but the power drains quicker. Light remains on.
Is it worth buying a charger or simply a new battery?
Many thanks
M
kramdra
PostPosted: 18:26 - 03 May 2020    Post subject: Reply with quote
For a one off, just find a neighbour with a car and jump leads. Connect up for a couple minutes and try again, no need to start the car.
If you get a charger, RC hobby chargers are excellent, far better than automotive types and much cheaper. Look at hobbyking.com
I assume it has had little use recently. Even so, any battery problem, is likely not the battery. Have a look at the wiring from the stator to the regulator, the connectors are often burnt.
Riejufixing
PostPosted: 21:41 - 03 May 2020    Post subject: Re: Suzuki Van Van 125cc - Bike not starting Reply with quote
What are the other circumstances?
How often have you been using it?
How long since you last used it (time and miles, about)?
If you know, how old is the battery?
jeffyjeff
PostPosted: 23:33 - 03 May 2020    Post subject: Reply with quote
Does the battery appear serviceable, no bulges or cracks in the casing? Are the terminals tight with no corrosion? Are the cells filled to the proper level? These are some checks you can make right away.
Unfortunately, you must fully charge the battery before you can test it. Otherwise, the test results won't be reliable.
The last post was made 6 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 39.54 Kb
