Does anyone know anything the flow of gases?
Gazz
PostPosted: 14:55 - 03 May 2020    Post subject: Does anyone know anything the flow of gases? Reply with quote
Does anyone know anything about the science involved where the flow of gases are concerned?
To put things into perspective, I'm ripping out an old open fire at home and replacing it with the same fire but plastering the area around the fire.
The previous occupant had an elaborate stone surround which was build outwards away from the wall which left a considerable hole for the gases to go up.
After my plastering has been done, if I was to put the same surround back in situ it would be closer to the wall; thus reducing the size of the hole for the gases to go up.
The other half is concerned that due to the reduction in the hole size, fumes won't be able to get sucked up the chimney and some would come back into the room.
I however, think that it may flow better than it did before because the chimney would be pulling the fumes upwards because the pressure would be greater than it was before.
We kinda want to get this correct first time, because a lot of money has been spent so far and we really don't want to have to rip it all apart and start again.
** on a side note, I've read a few Wikipedia pages on "Stack effect, flue-gas stacks" and there are a few mathematical equations on them but we are just really looking for a yes or no answer at the whether we are going to get a room filled with smoke the fire time that a fire is lit.
***pics available on request if you cannot understand my description on the situation well enough.
P. S. - the gap before would have been roughly 18"x4", but if we go ahead with original plans will be reduced to 18"x2.5".
Riejufixing
PostPosted: 15:23 - 03 May 2020    Post subject: Reply with quote
Pics. Also, remember what the area of an 8" flue liner is.
Edit: And I suppose it will annoy you if I say "consider a multifuel stove"....
PostPosted: 18:05 - 03 May 2020    Post subject: Reply with quote
Open fires draw better if you obstruct the opening. We used to get ours lit for years by holding a sheet of newspaper across the top half of the fireplace to make it draw.
Pretty sure either your chimney will draw, or it wont. If it wont, it's about the pot, not the hearth.
Nobby the Bastard
Harley Gaydar
PostPosted: 18:22 - 03 May 2020    Post subject: Reply with quote
And throw it onto the fire when it starts to go brown. Yep, been there.
Triumph Sprint ST 1050
PostPosted: 18:34 - 03 May 2020    Post subject: Reply with quote
Done that many times. The hot air goes up the chimney but if the opening is too big it will draw through the opening not the grate.
GettinBetter
PostPosted: 19:25 - 03 May 2020    Post subject: Re: Does anyone know anything the flow of gases? Reply with quote
Gazz wrote:
... the gap before would have been roughly 18"x4", but if we go ahead with original plans will be reduced to 18"x2.5".
Can you give the height to the chimney? Equation needs a height.
GettinBetter
PostPosted: 20:41 - 03 May 2020    Post subject: Reply with quote
Using the flow rate equation:
Q = C*A* √(2*g*h* (Ti-To/Ti)
where:
Q = flow rate in m3/s
A = Flue cross sectional area.
g = acceleration due to gravity (9.81m/s2)
h = Height of the flue.
Ti = Temp inside, initially at room temp rising as flames get hotter.
To = Temp outside, & cooler in winter.
Area for larger flue - 18" x 4" = 0.04645152m2
Area for smaller flue - 18" x 2.5" = 0.02903220m2
Assuming height of 8 mtrs for typical two story building.
Assumed 150 degrees K for inside temp, but I'm sure it would be hotter at times, my flue lazered up at around the 100 degs mark, but was on a low burn.
Gives a flow rate of 0.340m3/s for the original flue,
and a flow rate of 0.212m3/s for the smaller version.
You're thinking of using a flue opening that gives you 63% of the original flow rate.
Would I use it like that, NOPE.
I built my own log burner, and in the early stages of development I thought would be a great idea to get as much heat out of the flue as possible, not realising it is the difference in temperature that creates the lift (hence how hot air balloons work) needless to say it caused issues and a smoky building. I've also noticed on particularly windy days, the flow rate on mine isn't quite enough to overcome the gusts, and makes for a smell building.
Also, worth noting is if the room is airtight, then there won't be any airflow out up the flue, no matter how hot it gets.
I'm hoping one of you guys will run over these numbers to confirm (or not).
Just my tuppence worth.
Gazz
PostPosted: 11:47 - 04 May 2020    Post subject: Reply with quote
So, what you are saying is that: the bigger the hole at the bottom, the better?
I was thinking that if the hole was too big then it would be like trying to pour oil down a funnel (upside down if you get what I'm saying). And the flow would be restricted.
Regardless, I'll get some photos this afternoon to try and clear this up before I end up making a balls of it.
P. S. The original fire brick surround has been dismantled by one of our Eastern European neighbours so it's kinda guess work on what the fire looked like under the bricks as I wasn't at home at the time that it got dismantled. (pics should make things clearer).
Gazz
PostPosted: 17:40 - 04 May 2020    Post subject: Reply with quote
https://scontent.flhr2-2.fna.fbcdn.net/v/t1.0-0/p480x480/96387756_10158195230337768_6303753401901514752_o.jpg?_nc_cat=108&_nc_sid=0be424&_nc_ohc=dr5rr_PikDAAX_119an&_nc_ht=scontent.flhr2-2.fna&_nc_tp=6&oh=7532cda96343ea632e29e5c7d68f60f3&oe=5ED75FD5
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-0/p480x480/95715875_10158195230527768_8128538435917971456_o.jpg?_nc_cat=107&_nc_sid=0be424&_nc_ohc=gUdaDqe0WNIAX_7huey&_nc_ht=scontent.flhr2-1.fna&_nc_tp=6&oh=a49f4c818808a08761a7edc44b44d6b8&oe=5ED4CBD5
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-0/p480x480/95822264_10158195230707768_5251959122777079808_o.jpg?_nc_cat=101&_nc_sid=0be424&_nc_ohc=WHpTuFgGEzgAX--CLbU&_nc_ht=scontent.flhr2-1.fna&_nc_tp=6&oh=13959efce5a39e6f62c24413cbeeaf76&oe=5ED4DC7A
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-9/96150988_10158195230817768_198564906553835520_n.jpg?_nc_cat=107&_nc_sid=0be424&_nc_ohc=jmrmC6qZESkAX8EzuIJ&_nc_ht=scontent.flhr2-1.fna&oh=f4a24a8892b9029a39d8ec674a893dfa&oe=5ED48F7A
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-9/96066458_10158195231197768_3887287531384864768_n.jpg?_nc_cat=101&_nc_sid=0be424&_nc_ohc=nFauGV6TX-MAX_f2X4J&_nc_ht=scontent.flhr2-1.fna&oh=3c28e0bb69a616074edb391adcfdcde4&oe=5ED7423F
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-9/95901372_10158195231422768_5429434399877758976_n.jpg?_nc_cat=105&_nc_sid=0be424&_nc_ohc=Ul_lW3ODyTkAX_q0DcQ&_nc_ht=scontent.flhr2-1.fna&oh=79d2d75c8f17743fd963380aa3814b16&oe=5ED648DE
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-9/96080954_10158195231632768_4570962663240105984_n.jpg?_nc_cat=103&_nc_sid=0be424&_nc_ohc=6MvdS4vPS54AX9pvU6Y&_nc_ht=scontent.flhr2-1.fna&oh=c96acf5d3634b3950dcab00e4f15f338&oe=5ED717D2
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-9/96012951_10158195231932768_2636307271960756224_n.jpg?_nc_cat=107&_nc_sid=0be424&_nc_ohc=iDQxULinL5IAX_oPTK0&_nc_ht=scontent.flhr2-1.fna&oh=5e9d1001263aed6c98eb5423597eb4eb&oe=5ED578A3
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-9/95718608_10158195232127768_1043916961211219968_n.jpg?_nc_cat=107&_nc_sid=0be424&_nc_ohc=jWd7dmdDMh8AX8Mx3tn&_nc_ht=scontent.flhr2-1.fna&oh=4436d654cdf7fbfc092f54b55d0281b6&oe=5ED58CA6
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-9/95945244_10158195232287768_9165186237995155456_n.jpg?_nc_cat=105&_nc_sid=0be424&_nc_ohc=Z4FRopWAcXkAX9thea7&_nc_ht=scontent.flhr2-1.fna&oh=c958e027d0b30d3684fe8f9ef2f2c599&oe=5ED72E32
https://scontent.flhr2-2.fna.fbcdn.net/v/t1.0-9/96239665_10158195232512768_1557588152095342592_n.jpg?_nc_cat=102&_nc_sid=0be424&_nc_ohc=h2bqNiPZwysAX8Bo3hF&_nc_ht=scontent.flhr2-2.fna&oh=99de527d19a3dbd041f8165f2cabb491&oe=5ED49CBB
https://scontent.flhr2-2.fna.fbcdn.net/v/t1.0-9/96140937_10158195232737768_2255253465607438336_n.jpg?_nc_cat=108&_nc_sid=0be424&_nc_ohc=dkNtMnkSS7cAX-bBXyY&_nc_ht=scontent.flhr2-2.fna&oh=ff442f3f6391ecadaf76bcaf1f6910c4&oe=5ED4F261
https://scontent.flhr2-1.fna.fbcdn.net/v/t1.0-9/95689791_10158195232937768_6613148307441057792_n.jpg?_nc_cat=101&_nc_sid=0be424&_nc_ohc=Osgo9NPCXr8AX8Z45mh&_nc_ht=scontent.flhr2-1.fna&oh=1cca7cdbb635ec2262fbdc352fb6a28c&oe=5ED461E6
GettinBetter
PostPosted: 18:46 - 04 May 2020    Post subject: Reply with quote
Gazz wrote:
So, what you are saying is that: the bigger the hole at the bottom, the better?....
Ok, Just to be clear, old chap, I'm never going to tell you what to use, I'm not qualified to do so. I'm just chucking ideas out there.
IMO, seeing as the main channel of the flue hasn't changed and I assume you've only pinched it in at the bottom, then the main body of rising air is still rising and accelerating as per the equation. As the main body rises it will cause the pressure to reduce just above the pinch point and therefore suck the air through the pinch point faster.
Sorry I can't be more helpful.
Whatever you decide to do, make sure you get a carbon-monoxide alarm. They're pretty cheap these days. Better safe than sorry.
Riejufixing
PostPosted: 18:59 - 04 May 2020    Post subject: Reply with quote
Gazz wrote:
Hope this works. Sorry they are not in any order. And the place I uploaded them wouldn't do them all.
I can see those only by rtclick->view image.
When you say you've moved the fire and there's a smaller throat, how so? It looks as though the previous owner built up a fireplace *over* the trom surrounding the fire itself (!), so I'm trying to visualise gow you've actually moved the fire, especially since it seems to be connected to a back boiler.
What is the attraction of keeping the fire? The back boiler? the ££ it would cost to replace?
EDIT: This is probably what you want (wiith installation instructions, if yours is different find it on that website):
https://grantengineering.ie/media/1175/grant-back-boiler-instruction.pdf
Islander
PostPosted: 19:06 - 04 May 2020    Post subject: Reply with quote
If you want to find out if it draws, put a smoke pellet in the base and light it. If it draws well cold then it'll be even better hot. Thumbs Up
Generally speaking, chimneys are designed to have two air columns inside them which is why they have a sloping ledge at the rear. Hot gases from the fire ascend at the front, cooler air descends at the rear and 'spills' off of the sloping ledge. You don't need a huge open front to get a decent draw.
For illustration, I have an inglenook fireplace in my living room which is huge. In the middle I have a small 5kW multi-fuel stove. The throat of the chimney is closed off with a register plate and the hot gases go up a flue pipe and through a 6" liner. The remaining space in the flue is filled with vermiculite for insulation. All of the air for the stove comes through three slots at the front approx 2 x 1 cm each and those are controlled by a sliding damper. My chimney draws extremely well and to get a roaring fire in the stove I hardly have to have the damper open at all.
In short, it's all about the flue Smile
Gazz
PostPosted: 19:33 - 04 May 2020    Post subject: Reply with quote
Just looking for ideas at the moment or at least to gain a better understanding of how this kind of stuff works.
We've got a Carbon Monoxide alarm and it has never went off with the old fire that was in place, so I'm assuming that the flow was correct beforehand.
Gazz
PostPosted: 19:41 - 04 May 2020    Post subject: Reply with quote
I've fixed the pictures.
When I said that I moved the fire, what I actually meant is that I moved the surround into a position where I believe that it was meant to be placed which reduces the gap in size by the thickness of the chrome surround.
We quite like the fire. You cant beat it on a cold winter's day. Just decided to replace it now since the decent weather is here at the moment. It has been debated for years on whether we should remove it completely or not and there is no gas in our village so we thought that we'd just replace it when getting the place plastered.
Riejufixing
PostPosted: 19:49 - 04 May 2020    Post subject: Reply with quote
I see you've fixed the pics!
Can you indicate on a pic where the "gap" was reduced, and by how much?
Is the back boiler operational?
Did you look in the posted installation instructions?
Lots of questions. Sorry.
Gazz
PostPosted: 20:24 - 04 May 2020    Post subject: Reply with quote
The problem that I am having at the moment is that by the looks of things the previous owner has built that old fire further away from the wall than it needed to be (the thickness of the chrome surround) which was placed in front of the back boiler. We did not know this until the fire was dismantled.
We also never knew that half of the actual fire (the metal reddish coloured bit) was hidden behind the surround.
And if you look at the top picture, it looks like the hole that we now have was covered in bricks before.
____________
I've bought the exact same fire (in matt black) but I dont know if I'm going to have to build the surrounding bits away from the wall to replicate the previous owners set-up exactly to keep the hole the same size.
It is possible to fit the fire surround (chrome bit) around the back boiler with a little bit of modification (hammering the top out a few mms and cutting away the inner lips) but once you do this, the damper comes in contact with the chrome surround and basically closes off the opening coming at the front. Whereas beforehand, there was a small gap (same size as chrome surround) even when it was pulled out.
______
In addition to this, I don't know exactly how the hole in the wall at the front (if looking directly from the front) was covered by bricks (if it was completely bricked over or the bricks left a gap behind them for the smoke to go up behind them or not) because I wasn't there at the time it was dismantled.
Surely if the hole is there with no bricks in there, the original designers of the house/chimney intended it that way and should be left as free-flowing as possible: so basically if brick need to cover it, then its best to leave a gap behind them.
________
Ideally I want everything to be pushed back, (smaller hearth, etc) but I don't want to reduce gaps that need to be large enough for the volume of smoke to pass through.
**One final note:
It wasn't just the fire that was the deciding factor in changing all of this. Although you cannot see it in the first photo I'll try and describe it the best I can: but basically that whole wall was covered in those large bricks, both alcoves were covered in it. We couldn't buy any bigger tv than what we have because it wouldn't fit on the section of marble that was left.
There was a triangular hole which looked like it had been made with a hammer to allow the tv aerial through.
There was pump under the marble which thankfully we have never needed to gain access to.
And there was a rectangular hole made out of the brickwork which I'm assuming had a VHS player in it at one time, but was now left empty and caused draughts.
Riejufixing
PostPosted: 20:37 - 04 May 2020    Post subject: Reply with quote
Ping! I am enlightened. Smile You are going to be using your b(l)ack boiler. I will have another look after dinner.
Gazz
PostPosted: 20:43 - 04 May 2020    Post subject: Reply with quote
Thank you so much for posting those instructions. That has cleared so much up. I have just read them, so I haven't had a chance to measure anything yet to see where we can build or not yet, but I cant thank you enough.
Coincidentally, I had been looking for information on the back boiler the other day and couldnt find much.
Yes, the back boiler is operational. It heats up the stairs radiators and then when you press a switch on the wall it pumps the water around and heats down the stairs as well (but we seldom use it because down the stairs is always warm anyway because the fire is on).
(above) With the chrome surround in its original place (old fire).
If the chrome surround is pushed in, it closes the gap.
EDIT:
I've just been reading that instructions that you posted and it looks like there is supposed to be a 110-115mm gap left at the front.
This MAY have been the reason that the previous owner decided to buil it away from the wall.
EDIT AGAIN:
The surround is roughly 50mm and the gap left was roughly 40mm so by the looks of things the old fire wasn't meeting regulations.
Now we are getting somewhere. Looks like I might need to build away from the wall after all.
P.S. Thanks again for posting that.
Need to let the other half know now.
Riejufixing
PostPosted: 23:59 - 04 May 2020    Post subject: Reply with quote
I am a little worried about your nice new plasterwork. If you are going to remove the old fire, and fit a new one of the same sort, how are you going to access the pipework?
Gazz
PostPosted: 16:40 - 05 May 2020    Post subject: Reply with quote
The fire that we are replacing just bolts onto the boiler (or welds on). The boiler seems fixed into the brickwork and won't come out without serious demolition.
Its only this part that we are replacing.
https://www.gratefireplaceaccessories.co.uk/18-star-all-night-burner-open-fire-burns-coals-and-logs-matt-black
Riejufixing
PostPosted: 16:47 - 05 May 2020    Post subject: Reply with quote
OK I see, that explains it!
The last post was made 6 years, 44 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.21 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 127.57 Kb
