| pepperami |
 pepperami Super Spammer
 Posted: 22:10 - 04 May 2020 Post subject: Grinding/drilling out exhaust bolts |
Not long ago I had a nice shiny aftermarket exhaust put on my bike.
I’m trying to rescue the old pipes as a backup/spare.
The bolts that hold the silencer onto the downpipe protrude from the silencer.
Even though I was super careful when I tried to separate the down pipes from the silencer, the nuts sheared.
I used penetrating oil left for a couple of days and used heat when trying to turn the nuts.
They still sheared.
So now I have two broken studs that need to come out.
I started off by trying to pilot drill a small hole in each.
Ordinary drill bits had little to no effect
After getting through 3 bits , I have made some headway.
I’ve been keeping my drill bit cool with frequent dipping in water.
How can I soften the stud metal.
Is it a case of prolonged heat on the studs?
I was thinking of using an old bit and a dash of grinding paste, what do you think on mighty BCF? ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
 Posted: 22:22 - 04 May 2020 Post subject: |
Stainless or mild steel?
Stainless, you're screwed, it's hard and will just get harder. Mild steel should be able to be annealed by heating to just below red heat for a while.
Lubricate and cool the bit. I've used antifreeze for this before, or dribbled a shaken up mix of water/oil onto the drilling site. Even WD40.
Sometimes there is just a hardened surface your bit is skating on and you can break through it a bit with a punch to allow the bit to bite again.
Try a masonry bit. Tungsten carbide is super hard and should chew through pretty much anything. Brittle though.
You can get tungsten carbide drill steel drilling bits. £££ though.
EDIT: A tungsten carbide centree drill isn't a bad investment. I keep meaning to get one. Harder to break and less prone to wandering. Drill the centre with that then chew in with the normal bit. Rinse and repeat. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| pepperami |
| Riejufixing |
 Posted: 22:51 - 04 May 2020 Post subject: |
| pepperami wrote: |
I seek your wisdom? Why will it get harder? |
It work hardens as you cold work it. The more you drill at it, the harder it gets.
Why?... It's complicated but the iron effectively forms martensite which is very aligned iron-carbon lattice. hard but not flexible. Also, interestingly (if you're interested inthat kind of thing) becomes more magnetic. So the harder your stainless gets, the more magnetic it will become.
Oddly, if you heat it to a critical temperature then rapidly quench, it will soften it (opposite to normal catbon steel). However, to get it to critical temperature, you'll need to have it up to >1000 degrees then rapidly cool which could make a real mess of the rest of your piece... Hmm. I suppose you could use an arc welder with carbon electrode for really focal super-heating.  ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| pepperami |
| kramdra |
 kramdra World Chat Champion
| pepperami |
 Posted: 00:16 - 05 May 2020 Post subject: |
Thank you for your wisdom  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| mentalboy |
 mentalboy World Chat Champion
| stirlinggaz |
| pepperami |
| martin734 |
 martin734 Spanner Monkey
| Riejufixing |
| kramdra |
| martin734 |
 Posted: 18:49 - 05 May 2020 Post subject: |
| kramdra wrote: | | martin734 wrote: | I have noticed one of the problems many people have when drilling metal is that they use too high a drill speed. For a 1-5mm drill you should drill at a max of 3000 rpm and for 6-10mm a max drill speed of 1000 rpm. Remember, the faster you drill the hotter your drill bit will get and as it gets hotter it will get softer and blunter. |
Very wrong. A 1mm drill should be up in the 6000-30,000 rpm range, if you have the correct tool. 3mm should be 2000 -10000rpm. 6mm 1000-5000rpm.
Cordless is a compromise, but generally below 4mm youd have fast gear max speed. Above 4mm it will not have enough torque so low gear max speed.
The mistake is not adequate feed pressure. Without the feed pressure, the bit will rub instead of cut, the chips will be thin . You can tell if it is correct by the chip, powdery dust is no good, you want strings or curls. Decent sized chips remove the heat. |
30,000 rpm for a HSS bit on steel? Anything above 4000 rpm and you will seriously struggle to keep the bit cool, at 10,000 rpm you will start to melt the bit after a few seconds, plus the material you are trying do drill will start to harden. These are a couple of good guides.
https://www.sserc.org.uk/wp-content/uploads/2011/12/drill-speed-chart.pdf
https://www.ultimatehandyman.co.uk/how-to/metalworking/drilling-techniques-and-speed-charts ____________________ Current bike: ST1100 "Big Red" |
 Posted: 20:18 - 05 May 2020 Post subject: |
I drilled out all 8 broken studs on a Bandit cylinder head. If you're drilling stainless you want to keep the speed down and drill with quite a lot of pressure. The lower speed will stop the drill tip from cooking and the heavy weight will avoid work-hardening the stud. If it stops cutting, stop immediately and sharpen the drill. ____________________ a.k.a 'Geri'
| kramdra |
No, lower value for stainless, higher value for aluminium. Suggest you look at some of the manufacturers technical spec rather than some pdf written by a school teacher for classroom use, and anyway the ideal numbers you'll find in references are irrelevant if other conditions are not met. The main one, as I said, is the feed rate. The best way to judge this is the resulting chip, if the chip and feed are wrong, you will ruin the bit at any speed.
www.vikingdrill.com/viking-Drill-FeedandSpeed.php
As I said above, stainless hardens as it is worked. It does not harden if it is cut, hard stainless is avoidable.
And I disagree, those are rubbish guides. THIS is a proper guide, tho I admit the numbers are somewhat less than the generally accepted SFM in other references.
www.presto-tools.co.uk/file.php?filename=PrestoCounsellor2016.pdf |
| pepperami |
 Posted: 21:50 - 05 May 2020 Post subject: |
Well back to the job in hand.
Taking Mr Stinky’s advice/wisdom, I did some heating/quenching on the bolt stubs, getting them up to a bright orange before quenching.
The studs were a bit softer I think, but they still put up a fight against a drill bit.
Progress was being made but very slowly.
After a rummage through my junk tools and bits & pieces I found the worlds smallest tungsten carbide burr.
Three studs down and one to go
Still a lot of work to do but slowly getting there.
Once the last stud is drilled out, I will need to slightly enlarge the holes and cut a new thread to match some new bolts. ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| mentalboy |
 Posted: 22:51 - 05 May 2020 Post subject: |
| pepperami wrote: | Well back to the job in hand.
Once the last stud is drilled out, I will need to slightly enlarge the holes and cut a new thread to match some new bolts. |
Nice one.
I always tried to make sure that any replacement bolts or nuts on exhaust systems were bronze (easy said and done when you're in the marine industry). Not cheap but it saves all the fucking around with wankered steel fastenings. ____________________ Make mine a Corona. |
| pepperami |
 Posted: 10:27 - 06 May 2020 Post subject: |
Well thanks to the wonderful little tungsten carbide burr, I now have got through all four bolts.
The next step is widening the holes !.
One thing at a time, but after I have the holes the right size, I will need to cut threads to match some new bolts.
If cutting new threads is as hard as drilling out the old bolts, I’m in for a motherfugger of a bitch of a job.
The things we do to save a few quid . ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
| kramdra |
 Posted: 14:13 - 06 May 2020 Post subject: |
Taps are usually super-hard. Harder than drill bits which need to retain a certain amount of flex. It's why they snap so easily. Lots of lube, go slow don't force it and remember to back-off frequently.
Drillng once you have a pilot hole is usually straightforwards because you don't have that "skin" of really hardened material for the bit tip to skate about on. Move up drill size in stages, then you're curling off less material at once, generating less heat and mechanical stress. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| kramdra |
| pepperami |
 Posted: 19:47 - 06 May 2020 Post subject: |
Tungsten carbide burrs rule even small ones!
A combination of drill bits and burrs means all four holes are now ready for a new thread.
The holes are a mildly lose 6mm/HSS6 and there is plenty of metal to cut a new thread into.
The four bolts will be holding the silencer onto the down pipes, but the silencer is also held in place by hanging onto the passenger foot peg via another bolt like most modern bikes.
They are sort of load bearing as the original silencer is fffking heavy.
The world is my oyster when it comes to choosing bolts and threads because I will buy bolts & taps at the same time to ensure I buy the right taps for the bolts I put on the counter.
Mr Stinky : I seek your wisdom again, any pointers?  ____________________ I am the sum total of my own existence, what went before makes me who I am now! |
The last post was made 6 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
