Replaced battery, 60mA parasitic draw when off,Cant localise
NutsyUk
PostPosted: 14:07 - 06 May 2020    Post subject: Replaced battery, 60mA parasitic draw when off,Cant localise Reply with quote
So was about to go out on the Er6f, to have a little ride before some shopping.... I REALLY need to get out the house.
Anyway turn it on and...... nothing. not ridden it for about a week and a half.... But nothing not even a whimper....
Got the my tester out and the battery is reading 2.8v :/ the charger doesnt even want to trickle charge the thing. So deader than a really dead thing thats rotted away and turned to dust.
I dont want to be spending money.... but i just found a cheap battery...
https://www.tayna.co.uk/motorcycle-batteries/enduroline/ytx12-bs/
Any known horror stories on this battery? Probably a rebadge of some oem?
Anyone think it would do?
I noticed there was another er6f dead battery thread. And there was mention of maybe the rectifier was cooking the battery... Obviously at this stage I cant test that.
But wanted to be sure, when i get this battery and warm up the bike. What do i need to look for? the voltage on the battery terminal? if that goes over 14.5 v while running?
Yamaha FZ8/Fazer800 (split headlight one) 2014, gingerly getting used to the massive increase in HP and not killing myself in the process! That was easy to get used to.
Kawasaki ER6F 2007 650 Gonna sell as a project bike!
Lexmoto XTR S 125 Sold!
Minty
PostPosted: 14:47 - 06 May 2020    Post subject: Reply with quote
Can you not just bump start the bike?
My fingers smell of your mum.
NutsyUk
PostPosted: 15:03 - 06 May 2020    Post subject: Reply with quote
Dont think bump starting a bike with a 2v battery is possible...
Though one charger refused to try and charge it, the other charging seems to be recharging the battery so might not be totally dead.... Its up to 11v now so might be able to recover this without having to get a new battery.
WD Forte
PostPosted: 15:10 - 06 May 2020    Post subject: Reply with quote
Whatever you buy will be better than what you have
When running you want to see between 13.8-14.5V at the battery terminals, no more no less. so check this with lights on and off.
It may be wise to check for parasitic drain when the bike is switched off
as even a clock, alarm, immobiliser etc will pull it down over time if its left standing for long periods
bikers smell of wee
NutsyUk
PostPosted: 15:31 - 06 May 2020    Post subject: Reply with quote
Yeah thats prolly true, I some how feel even if i do get this charged back up the batteries going to be damaged... So I will likely have to get a new one anyway... Hopefully i can put it off a few weeks :/
I have a USB power socket attached to the bike for the phone/maps but that runs off the little starter light that only gets power when the bikes turned on so I dont think its that. The clock might drain some battery but I cant think that would drain a lead acid this quick..... Bike doesnt have an immobiliser so cant be there either...
Though again id have thought there be some kind of over discharge protection somewhere in the system/maybe not....
Maybe my short 5 mile runs to town and back for shopping has drained the battery without giving it a good charge from a nice long ride....
You can sometimes "jump start" a battery charger. There is such a low voltage, it doesn't see there being a battery attached.
If you attach the charger to the battery then get another battery which has 12v, attach wires to it and touch them to the terminals, it might click the internal relay and start charging.
Be aware, it might just be totally dead and that they can gas like hell when you try to charge them so supervise it but I have recovered batteries that flat before using this method.
EDIT: I've even used a square 9v smoke-alarm battery to "jump start" a charger before.
NutsyUk
PostPosted: 11:39 - 07 May 2020    Post subject: Reply with quote
Good news battery managed to charge up and bikes runnign again. Even was a super easy start too... Ill check battery voltage shortly, its just warming up now
doggone
PostPosted: 11:51 - 07 May 2020    Post subject: Reply with quote
The odd time you might get away with it, Lead acid does suffer a permanent reduction in capacity after being let get really low, but a few days is less bad than weeks.
wr6133
PostPosted: 11:59 - 07 May 2020    Post subject: Reply with quote
If you do replace it for the sake of less than a tenner get a known make https://www.ebay.co.uk/itm/MBT12B4-MOTOBATT-Quadflex-AGM-Bike-Battery-12V-11Ah/312599424178?epid=2037796960&hash=item48c860acb2:g:mTAAAOSwtEleeGS0
Never thought of that, I've got a pair that sit around 8v I'm going to try tonight.
NutsyUk
PostPosted: 12:08 - 07 May 2020    Post subject: Reply with quote
And other good news BTW, after warm up the circuit tester read 14.48 given resistance in the wires I'd say the rectifier is perfectly on the dot 14.5.... So no need to change that.
Riejufixing
PostPosted: 12:11 - 07 May 2020    Post subject: Re: Dead battery, found a replacement is it ok? Reply with quote
After all that, IF you find you still nbeed a battery, that looks good. I have had a few Enduroline ones before without problem.
I look at:
1) Guarantee. That's got a 2-year guarantee, the others have 1-year.
2) CCA. That one's 190A, others have less or a bit more (not price dependent), so that seems reasonable.
PostPosted: 12:34 - 07 May 2020    Post subject: Reply with quote
Not a bad plan to see if it's holding the charge once recovered. They sometimes charge up but then slowly discharge over a few days.
Note down the resting voltage and check it every few hours to see if it's staying at a decent level.
I keep discharging batteries totally flat because I kill the engine on my bullet with the decompressor then forget to turn off the ignition. If it stops with the points closed, it discharges the battery. They usually recover but to a lower resting voltage each time. After 3 or 4 times, they start to really go downhill. Presumably because the plates sulphate.
NutsyUk
PostPosted: 16:59 - 09 May 2020    Post subject: Reply with quote
Well that answers that then.... Battery died on me while I was out in town :/
So dead dead dead dead dead battery...
i started up fine and ran fine for the 5 mile trip in... did a little shopping and then got on the bike powered up, FI light flashed a moment and then dead.... nothing.
Tried bump starting it... but no hills here gave my self an asthma attack trying to push it... didnt work...
Had to get dad to come out with a jumper cable... he brought the trailer just in case.... and good thing to, the bike would start under the car battery but as soon as i took the jumpers off the bike died... Which worries me tbh. I thought even with a dead battery the engine should keep cycling under its own power?
So back home now with a stinking headache from being stuck out in the sun and being a little dehydrated... and cooked in bike boots Sad
And now have to spend money I dont want to spend Sad oh joy Sad
Riejufixing
PostPosted: 18:59 - 09 May 2020    Post subject: Reply with quote
Might have a dead short. Off to Tayna then, and to the Offie for some beer fer y'dad.
NutsyUk
PostPosted: 19:03 - 09 May 2020    Post subject: Reply with quote
sounds like a good idea. I offered to do a BBQ for him... he didnt want it Sad i should have thought of beer!
NutsyUk
PostPosted: 13:22 - 21 May 2020    Post subject: Reply with quote
well this isnt good news :/
just went to bike to go do some shopping... ok its been a week? two? since i last ridden... the new battery is down to 11v and wont start :/
I think theres now something seriously wrong with my bikes electrics :/
Any idea? What the hell can be discharging a battery when the bikes turned off :/
NutsyUk
PostPosted: 13:40 - 21 May 2020    Post subject: Reply with quote
theres a 60mA parasitic drain on the battery when turned off :/ this is not good :/
wr6133
PostPosted: 13:50 - 21 May 2020    Post subject: Reply with quote
12V socket/USB? I have one that sucks power, I bought the version of it with no LED, turns out there is an LED, inside it. Same as the LED one just without a hole to see it through! Little shit was on as soon as the wires were connected to the battery.
NutsyUk
PostPosted: 13:53 - 21 May 2020    Post subject: Reply with quote
yeah got a usb socket, but its attached to the mini bulb in the headlight, that only gets power when the bike is turned on... so it shouldn't be that thats causing it.
and even if there was a hidden led, 60mA is a bloody bright led :p
doggone
PostPosted: 17:53 - 21 May 2020    Post subject: Reply with quote
A simple trick, in a dark shed or something open the fuse box and pull the fuses one by oe.
Lightly touch the blades on to the terminals.
The one taking a slight current you might see a tiny spark.
What if anything is live when ignition is off.
On cars the hazard light switch is not unusual to need replacing because that is live with no key in.
If you do find the problem fuse you could pull it when bike is not in use pending further investigation.
Anything added aftermarket is first place to look.
NutsyUk
PostPosted: 19:41 - 21 May 2020    Post subject: Reply with quote
Tomorrow i was going to do something similar. Attach the meter to the battery, and pull the fuses till i find the one thats drawing, then i can focus on that circuit to see what the heck is going on.
NutsyUk
PostPosted: 14:25 - 22 May 2020    Post subject: Reply with quote
This is fun :/
Soooooo multi metre out sensing the 60mA draw when off... pulled each main fuse to try and localise where its coming from and still drawing 60mA.
Im really struggling to localise what could be causing this drain.
Any ideas? Could a dirty plug be internally shorting some how?
PostPosted: 14:59 - 22 May 2020    Post subject: Reply with quote
NutsyUk wrote:
This is fun :/
So a sucessful test. If it didn't drop away after pulling any fuses it's somewhere between the battery and the fuse box. Maybe add the starter solenoid to that list.
Not a long list. Maybe 3 wires?
Oh. Also check if the headlamp "flash" button actually goes through the fusebox. I think it doesn't on some kawasakis for some unknown reason.
NutsyUk
PostPosted: 15:24 - 22 May 2020    Post subject: Reply with quote
ohh thats good , though i was going to have to check every single plug and wire on the entire loom... might have to be a tomorrow thing now as int he middle of making a mould... but thanks will check
PostPosted: 16:03 - 22 May 2020    Post subject: Reply with quote
Taking a wild guess at a 12ah battery (partly based on easy maths) 60ma drain will kill the battery in 200 hours, so about 8 days. So that’s about right
Looking at a wiring diagram for an er6, there are a couple of extra separate fuses if it has abs.
If you check over the main fuse in the starter relay, is there a current drain there?
Katy
The last post was made 6 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 131.72 Kb
