| Robthepiano |
 Robthepiano Derestricted Danger
| Nobby the Bastard |
| Islander |
 Islander World Chat Champion
| wr6133 |
 wr6133 World Chat Champion
| Robthepiano |
| Robthepiano |
| Bhud |
 Bhud World Chat Champion
| Robthepiano |
| stinkwheel |
 Posted: 00:50 - 07 May 2020 Post subject: |
In fairness, it could just be excesive stiction on the seals from being sat meaning the pistons aren't returning.
Might be worth taking the pads off, pumping the pistons out a bit, giving them a fucking good scrub with brake cleaner and a toothbrush, pushing them back in again then reassembling (not forgetting to pump them back out again before riding off).
Be really carefull though because with them binding like that, one of two things will happen. 1) They will eventually bind on all the way and you'll crash. 2) The brake fluid will boil and the brakes will stop working altogether and you'll crash.
So cautious test ride after and check if they are still overheating. Use them a couple of times then ride for a while without touching the front brake, stop without using it and see if it's hot. Don't touch the discs. Not even with gloves on because they can get hot enough to burn you through leather gloves in a fraction of a second. Spit on them and see if it hisses.
Last time I dropped my bike (on the road) it was due to a binding brake (it had a twisted seal on one piston). I felt the steering getting heavy and pulled in to stop. Then hit gravel and the front wheel locked itself just before I stopped. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| wr6133 |
| Easy-X |
 Easy-X Super Spammer
| sickpup |
 sickpup Old Timer
| stinkwheel |
| steve the grease |
 steve the grease Crazy Courier
 Posted: 19:00 - 07 May 2020 Post subject: |
Lets have a look at a quick fix. If it's been stood for 6 months the pistons will have become stiff , probably not yet siezed properly , but part of the way there. There are a number of solutions some better than others , but you could try this:
Get an old butter knife and push it between the disk and the pad , if it will go , then try and twist it ( pliers?) so that the piston(s) slide back in. Then pump the lever until the pad is touching the disk again. Repeat a couple of times and then do the same on the pad on the other side of the disk. This might ...... free it up enough so that it will last until bike shops are open properly . Probably worth a try, costs nowt. ____________________ All the above is my personal opinion, you can see my lips move, but I'm talking out of my arse.
I've been riding, and fixing , bikes for 50 years, in that time the more I learn, the less I am absolutely sure of..... |
| steve the grease |
 Posted: 19:01 - 07 May 2020 Post subject: |
The last post was made 6 years, 126 days ago. Instead of replying here, would creating a new thread be more useful? |
