| iridium |
 iridium L Plate Warrior
| jaffa90 |
 jaffa90 World Chat Champion
 Posted: 00:00 - 06 May 2020 Post subject: |
| iridium |
| jaffa90 |
| iridium |
 - Super Spammer
| stinkwheel |
 Posted: 08:45 - 07 May 2020 Post subject: |
If the red wire under the seat is connected to the ignition switch at the other end and has nothing attached at that end, that's the one you want.
In fairness, all red wires on that bike SHOULD be connected to the battery positive somewhere along their length but you shouldn't need to "tap into" one. That's assuming it hasn't been messed about with. The black tape on the rectifier makes me a tad worried it may have been.
As above, there should be an inline fuse in the wire coming off the battery positive.
So if unmessed with and you have an unattached red wire under the seat, fit a (?15A) inline fuse holder and fuse to the end of that wire, then attach the other side of the fuse holder to the battery positive. I would use an automotive blade fuse holder because they are easy to buy fuses for in any filling station.
It does not have a fuse box so don't worry about looking for one. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| A100man |
 A100man World Chat Champion
 Posted: 10:46 - 07 May 2020 Post subject: |
These old bikes tend to have an in-lne fuse holder on the battery positive, Maybe you can find the remnants of one somewhere.. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
Then: Fizz, RS200, KL250, XJ550, Laverda Alpina, XJ600, FZS600, Skorpion, GT 250 |
| stinkwheel |
| iridium |
| stinkwheel |
 Posted: 16:45 - 07 May 2020 Post subject: |
| iridium wrote: |
Once it's connected, should i see a brighter headlight or will it still vary with the RPMs? |
It will have no effect on the headlight.
| Quote: | Wondering how to confirm that I've got the batter hooked up correctly. |
First-off, the neutral light, brake light, horn and flashers ought to work.
For a dynamic test, connect a multimeter across the battery terminals and start the engine. The voltage should increase with revs up to about 8.5V or so. or connect an ammeter (on the 10A setting) in series with the battery positive. Should be getting somewhere between 1 and 3 amps with the engine running.
A dirty test is to try the horn which will most likely sound like a dying asthmatic frog and should get louder and more horn-like as you rev the engine up. This woudl indicate the battery is charging.
If the accessory lights are working but the battery doesn't seem to be charging, change that rectifier, they break for fun.
If the headlight is working, the charging coil is intact The lights use half of it. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| iridium |
The last post was made 6 years, 128 days ago. Instead of replying here, would creating a new thread be more useful? |
