| kolu |
 kolu Nova Slayer
| recman |
 recman World Chat Champion
| Howling TerrorOutOfOffice |
| MarJay |
 MarJay But it's British!
| davebike |
 davebike World Chat Champion
 Posted: 08:10 - 18 Apr 2020 Post subject: |
Yes that is almost exactly what we use and have done fro 20 years or more !
Oh I think the one we have is Sealey used several times a day I am professional
ain stand or abba stand + jack works well fro font end work ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| droog |
 droog Spanner Monkey
 Posted: 09:13 - 18 Apr 2020 Post subject: |
I've got one of these scissor stands - they are very good - I used mine
to lower the engine out of a 600cc 4 cylinder Honda - just make sure you set up on a nice flat surface.
Main issue is keeping everything stable while you are working on the bike - loosen (but don't remove ) the necessary nuts/bolts before the bike is up on the lift - because you don't want it swaying about on a stand while you are attempting to crack open a torqued up nut or bolt. |
 - Super Spammer
| MarJay |
| Polarbear |
 Polarbear Super Spammer
| MarJay |
| kolu |
 kolu Nova Slayer
| droog |
| davebike |
 Posted: 09:26 - 20 Apr 2020 Post subject: |
It is like the first one kozesluk but rather more and supplied with the bench I use like 20 years ago full kit with several options for different lifting options
For a custom I put the bike on an Abba stand then use the jack to lift front all strapped down on the bench ! ____________________ Dave
[email protected] |
| kolu |
 kolu Nova Slayer
| wr6133 |
 wr6133 World Chat Champion
 Posted: 09:59 - 08 May 2020 Post subject: |
You could have done the exact same with a scissor jack off eBay for a tenner and a bit of old wood flytipped at the roadside. If it worked and you are happy though, who am I to pontificate.
Nice to see mechanical work being carried out in a warehouse of what appears to be food products  |
| kolu |
 kolu Nova Slayer
| Robby |
 Robby Dirty Old Man
 Posted: 10:49 - 08 May 2020 Post subject: |
I use a cruiser stand like this for anything that needs the wheels off the ground: https://www.amazon.co.uk/Biketek-Hydraulic-Heavyweight-Motorbike-Davidson/dp/B018XZEEJQ
You can use the frame adaptors like on your scissor lift to make sure you lift off something solid. The main advantage is that it's easier to lift/lower. You can sit on the bike to hold it level, and pump the lever with your foot.
Although for most jobs I just use a car jack under something solid, less faffing around to get a wheel in the air.
Also for doing any bearings, I have found out that proper bearing drivers are now cheap enough to not both with makeshift tools. £30 gets you a set that will do any bearing you will have on a bike. It cost me more for a set of brass drifts, which are preferable to continually knackering screwdrivers to knock out bearings.
Now that you have done the job, and probably found it a bit of a pain in the arse, two things to remember if you don't want to do it again any time soon:
1. Set the bearings to the right torque. Don't set them a little tight and hope that they will bed in - a "little tight" on bearings translates into tonnes more pressure and kills them.
2. If you didn't lube the fuck out of them on installation, do it now. I am always surprised by just how much grease a headstock bearing will absorb, they're like miniature black holes. |
The last post was made 6 years, 129 days ago. Instead of replying here, would creating a new thread be more useful? |
