Stainless steel plate fabricators
Gazz
PostPosted: 22:46 - 08 May 2020    Post subject: Stainless steel plate fabricators Reply with quote
Any suggestions where I could find a small section of stainless steel metal plate online and have it posted to me?
I'm looking for 22"x6" for a fireplace but the company that supplied the fire, etc want £38 plus an additional £7 postage. I was considering paying it but it's going to be 2 weeks for them to post it out to us, and I'm kinda needing it just now.
I've checked ebay but I can't find the exact size that I'm looking for. Was hoping that someone could cut it for me to avoid myself making a mess of it trying to cut it down to size.
Riejufixing
PostPosted: 22:49 - 08 May 2020    Post subject: Re: Stainless steel plate fabricators Reply with quote
How thick is it (finish required, grade)?
Edit: Oh, and out of curiosity, how will you be using it?
PostPosted: 23:17 - 08 May 2020    Post subject: Reply with quote
The very first ebay result when you search "stainless sheet"? I didn't look at the other 10,000+ auctions.
https://www.ebay.co.uk/itm/Steel-aluminium-stainless-plate-sheet-0-8mm-1mm-1-5mm-2mm-3mm-chequer-plate/223575488268
Which includes 2 free gillotine cuts per sheet.
Or steal it from a phone box. That's where I got a big sheet of stainless. Shifty
Riejufixing
PostPosted: 23:27 - 08 May 2020    Post subject: Reply with quote
He wants plate, possibly pollished 2P, but he'll have to say what. Mind you, only £38 + post from a fireplace shop seems to show it's just sheet.
PostPosted: 23:30 - 08 May 2020    Post subject: Reply with quote
Or have you tried calling your local steel stockholders?
I'm always surprised how tolerant my local one is of selling me relatively short bits of random metal and by how cheap it was.
PostPosted: 23:37 - 08 May 2020    Post subject: Reply with quote
He says he wants plate but for that price it must be sheet.
I'd start by looking for local laser cutters then give them a call. Some will do cash jobs for simple parts.
Bhud
PostPosted: 23:42 - 08 May 2020    Post subject: Reply with quote
I get my sheet metal from Ebay. Cheaper than hardware/DIY stores. There are quite a few sellers who sell nothing but sheet metal, on Ebay. If you send them a message asking for a quote they'll cut the metal and create a listing for you. For the small section you want, it's bound to be cheaper than £38 plus postage.
Riejufixing
PostPosted: 23:43 - 08 May 2020    Post subject: Reply with quote
That's what I'd probably start at (or "blacksmith" or "steel fabricator"). I bought some round and flat bar for window bars last time I was at one near me, and noticed some s/s sheet that they were going to fold up into something, and a lot of UB offcuts in the skip, but no RSJ pieces, which I would have liket to have a bit of to hammer things on.
c_dug
PostPosted: 09:59 - 09 May 2020    Post subject: Reply with quote
0.9mm brushed 304 stainless, cut to 22"x6", £7.19.
https://www.metals4u.co.uk/materials/stainless-steel/stainless-steel-sheet-and-plate/sheet-and-plate-dull-polished/3066-p
PostPosted: 13:11 - 09 May 2020    Post subject: Reply with quote
Riejufixing wrote:
[ no RSJ pieces, which I would have liket to have a bit of to hammer things on.
Be better with a small, solid steel block. I'm pissing about with a bit of forging and you don't need a big one but the more mass you have in it, the better for rebound purposes (forges both sides at once instead of just the side you're hammering). I tried with a big piece of steel plate mounted on a wooden block and it's rubbish.
If you look at the flat area of even a large anvil, it's usually only 4 or 5" across so unless you are working huge pieces of steel, you don't need a large footprint.
I bought a 4x4x4" steel billet offcut off ebay for under £30 delivered. Just need to round the edges off a little, mount it to a base (a log) and I have a really functional striking block. No horn but you don't absolutely need one, you can forge stuff like that off the edge of the block, I may radius one edge for this purpose.
From reading round, this will be more effective than a cheap small anvil or a bit of railway track/RSJ because it has a lot of centered mass under where you are striking. The hammer will rebound when struck.
The one thing it's missing for it to be a proper striking block is a hole for tools/drifting.
Gazz
PostPosted: 13:45 - 09 May 2020    Post subject: Reply with quote
Looking for something around 5mm thick. It's for removing the ash tray at the bottom, to prevent that section of hearth being scratched. I have one at the moment which has the odd scratch on it but I don't know if I am cheaper just to buy a new one instead of buying metal polishes, etc. I currently don't have any metal polishing stuff.
Riejufixing
PostPosted: 13:50 - 09 May 2020    Post subject: Reply with quote
RSJs are good (and offcuts are free...), and have a decently large and flat area, good for cutting metal on (make sure your chisel doesn't dig in Smile ) and folding it, but real RSJs are hard to find, and commonly UBs are now referred to as RSJs which they are not, and UBs are certainly not as good for hammering things on as RJSs..
Yes, were I dealing with anything very meaty, I'd buy a used anvil. You can get reasonable-looking things like these but I have not had the pleasure: https://www.ebay.co.uk/itm/Iron-Anvil-Blacksmith-Single-Beck-Cast-Iron-20KG-Single-Horn-Milling-Metal-Work/143085985879?hash=item215096e057:g:7VgAAOSwoQddxRDZ (or 100kg from China)
Riejufixing
PostPosted: 13:59 - 09 May 2020    Post subject: Reply with quote
5 mil!! If the one from the fireplace shop is 5mm, that seems a good deal! I would enquire of a local steel stockholder or fabricator if not.
Thought: If what you have now has the odd scratch on it, won't a new one end up looking exactly the same? You won't easily polish out scratches on this stuff, and if you have experience of having a new, shiny stainless steel kitchen sink, you will know that when they have been used for a month, they look terrible, but after a year, they're uniformly "re-finished" and look OK.
The last post was made 6 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.19 - MySQL Queries: 13 - Page Size: 80.6 Kb
