Ybr engine troubleshooting
Adampotter
PostPosted: 18:55 - 08 May 2020    Post subject: Ybr engine troubleshooting Reply with quote
Hi everyone I have a 2011 ybr 125 that won't start the engine has been rebuilt but won't start in cranks over the timing is correct, it has compression, spark and fuel but it just won't kick over does anyone know what could possibly be wrong any help is appreciated thank you
Riejufixing
PostPosted: 21:27 - 08 May 2020    Post subject: Re: Ybr engine troubleshooting Reply with quote
"It won't kick over" implies that it's seized, but that can't be, because you say it "cranks". You said: " the timing is correct", do you mean the ignition timing, or the valve timing, or both? Are you sure the sparking-plug's good?
Adampotter
PostPosted: 21:29 - 08 May 2020    Post subject: Reply with quote
The ignition timing and valve timing are both spot on and the spark plug is in good condition there's no reason it shouldn't run
spottedtango
PostPosted: 22:42 - 08 May 2020    Post subject: Reply with quote
Engine needs 4 things to run fuel/air, spark and compression.
So ones at fault.
Have you tried spraying easystart into the intake? If it starts it’s fuel related
How did you check the spark/compression/fuel?
Adampotter
PostPosted: 22:49 - 08 May 2020    Post subject: Reply with quote
So ones at fault.
I took the spark plug out and it had a good strong spark, the compression was checked by putting my thumb over the spark plug hole as I don't have a tool to check it while cranking and the compression was good and its getting fuel because you can smell it when the engine has cranked over without the spark plug in
jeffyjeff
PostPosted: 22:55 - 08 May 2020    Post subject: Reply with quote
Your YBR is fuel injected, right? You have fuel in the tank, but since you are sure of spark, ignition timing and valve timing, the next thing to check is fueling. Two thoughts:
1. Make sure you can hear the fuel pump turn on when you switch on your ignition. Maybe you can remove the fuel injector and observe the fuel delivery while cranking.
2. Also, your bike has a tip-over sensor under the seat. It's there to stop the engine and fuel pump when the bike is dropped. Make sure it is not loose or installed improperly. The Haynes manual says voltage between the yellow/green terminal and black/blue terminal (with the sensor connected and ignition ON) should be 0.4-1.4V with the sensor upright, and 3.7-4.4V when the sensor is tilted 65 degrees.
Hope these ideas are useful to you. good luck
jeffyjeff
PostPosted: 10:05 - 09 May 2020    Post subject: Reply with quote
Your post said you can smell fuel, so that rules out the tip over sensor. But you still don't know if you are getting a burnable Air/Fuel mix. Check for an air restriction, and see if you can determine if the injector is delivering an atomized spray. Also, double check that the spark plug is delivering a solid spark. A weak spark cannot withstand the turbulence of compression. just a few ideas that might help.
The last post was made 6 years, 128 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.5 - MySQL Queries: 13 - Page Size: 51.16 Kb
