Speedfight 3 wiring
Pug2011
PostPosted: 07:22 - 09 May 2020    Post subject: Speedfight 3 wiring Reply with quote
Hi I'm stripping down a speedfight 3..I have a blue wire with what looks like a 10amp fuse attached. I think this has come from ignition wiring block but not sure . Iv looked in manual and can only see 7.5 amp and 5 amp fuses which I have in correct place .The blue wire runs outside the loom ...any ideas as to were to reconnect? Thanks[
1198
PostPosted: 07:43 - 09 May 2020    Post subject: Reply with quote
Can you do it by the process of elimination - that is to say you can work out the rest so therefore that one must be XXX?
Bear in mind also that just because it has a 10A fuse in now doesn't mean that's what it should be fitted with... It's not inconceivable that a different (larger) fuse has be used due to either the correct size blowing too often as a bodge or perhaps a 10A one was the only type a previous owner could get hold of?
Pug2011
PostPosted: 09:10 - 09 May 2020    Post subject: Reply with quote
Thanks for the input.. this is what's confusing me,the terminal block wires all match I.e 4 in 4 out and the fact the blue wire is situated outside the loom and i have both fuses mentioned in the manual leads me to believe this may of been a temp repair or something...just in the process of gathering as much info at the min ..electrics isn't my strong point lol
jeffyjeff
PostPosted: 12:57 - 09 May 2020    Post subject: Reply with quote
the blue wire could have powered some aftermarket addition that has since been removed. a cell phone cradle or GPS perhaps?
Pug2011
PostPosted: 06:07 - 10 May 2020    Post subject: Reply with quote
Thanks guys come to the conclusion this is a extra wire
The last post was made 6 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 42.12 Kb
