Bike Lift
GettinBetter
PostPosted: 11:05 - 10 May 2020    Post subject: Bike Lift Reply with quote
So... I scoured the internet for a piece of equipment to lift my bike or support it while I took the back wheel off and such like jobs. saw some nice looking crap bits of kit with crap pictures and no dimensions no weights, etc.
Then there's the storage, i could do without another bit of kit to find a space for.
I came up with this, I already had the jack for my camper, and raises to just under a metre, so made a few new additional tools to adapt it... and viola. There stabiliser on the front bolts on, and the frame the bike sits on just drops into the existing hole on top of the jack. It's amazingly stable, and I can even move it around with confidence.
PostPosted: 11:14 - 10 May 2020    Post subject: Reply with quote
All good fun until the hydraulics start to creep. I wouldn't take the wheels out etc with it up on there. I'd lift the bike then lower it onto axle stands, just like you would with a car.
You can put stands under the swingarm legs or flip the footpegs and put them under there.
Even my proper hyraulic bike lift has a bar you put through and lower the thing down onto after it's lifted, it's not held up by the jack itself.
Or, your fabrication skills are clearly up to it, you could lower the lifting frame onto a table of some sort after lifting it with the jack.
I do wonder if it could be used to stack bikes 2-high in a garage Thinking Twisted Evil
GettinBetter
PostPosted: 11:35 - 10 May 2020    Post subject: Reply with quote
stinkwheel wrote:
....Even my proper hyraulic bike lift has a bar you put through and lower the thing down onto after it's lifted, it's not held up by the jack itself....
Good call, I'll add that. Those pics were taken while tentatively testing, I wanted to prove concept. I did wonder about hydraulic creep while making it, but the thought came and went. Very Happy
I'm working on a more robust method of clamping the bike to the top platform, if I removed all the front end it would be back heavy, and needs a study connection, I'm happy to trust. Same with removing all the back end.
PostPosted: 12:41 - 10 May 2020    Post subject: Reply with quote
Thinking about it further. You could sleeve the ram.
Piece of channel steel the length of the ram when it's extended. Slot it over the ram and put a couple of pins through underneath so it can't come off then release the ram so it's resting on the sleeve. That's what they do with tipper trailers when they want to work under the bed.
GettinBetter
PostPosted: 16:06 - 10 May 2020    Post subject: Reply with quote
Perfect, that'll do nicely...nice & simple to make. easy to store, plus quick to apply and remove. Appreciate your input Thumbs Up .
PostPosted: 18:14 - 10 May 2020    Post subject: Reply with quote
Found a pic of one on a mini-digger bucket.
https://i.imgur.com/P9LvCFW.jpg
The last post was made 6 years, 185 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 50.32 Kb
