Two stroke experts please? KR1S nastiness inside
PostPosted: 13:36 - 10 May 2020    Post subject: Two stroke experts please? KR1S nastiness inside Reply with quote
So. Can this be repaired? Second hand barrels cost a fortune.
https://cdn.bcf.44bytes.net/files/img_4745_small.jpg
https://cdn.bcf.44bytes.net/files/img_4744_small.jpg
Riejufixing
PostPosted: 13:47 - 10 May 2020    Post subject: Re: Two stroke experts please? KR1S nastiness inside Reply with quote
I cannot see the image you psoted.
PostPosted: 13:58 - 10 May 2020    Post subject: Reply with quote
Two stroke experts?
Sounds like you need Chris AKA Bullet to help you. Mr. Green
A100man
PostPosted: 14:36 - 10 May 2020    Post subject: Re: Two stroke experts please? KR1S nastiness inside Reply with quote
Yup same as - summary says 0 bytes in size Confused
PostPosted: 18:01 - 10 May 2020    Post subject: Reply with quote
Apologies, my phone wouldn't allow me to attach files...
sickpup
Old Timer
PostPosted: 18:27 - 10 May 2020    Post subject: Reply with quote
Yes that's repairable, talk to these people.
Why does it need a 2 stroke expert?
PostPosted: 18:38 - 10 May 2020    Post subject: Reply with quote
Because it's a two stroke? I don't recall many four strokes damaging their exhaust ports by spitting out the ring pegs?
sickpup
Old Timer
PostPosted: 19:17 - 10 May 2020    Post subject: Reply with quote
Damage to a cylinder is damage to a cylinder regardless of engine type. Pretty much the same method to fix anyway.
Riejufixing
PostPosted: 19:57 - 10 May 2020    Post subject: Reply with quote
I wondered, looking at the port damage, whether it might need sleeving, but as said, they will say. From the website for reference:
"Piston or ring failure while the engine is operating often results in severe damage to the cylinder. A major advantage of using Apticote 2000 coating technology for treating aluminium engine cylinders is the ability to rework these damaged components. Our process will remove the existing coating, weld repair the damaged cylinder, recoat and finish hone to precisely match your new replacement piston"
Edit: Oh, no, it does look like coated alloy, I thought the metal looked different in the pic. "Cancel directive" Smile
PostPosted: 18:38 - 11 May 2020    Post subject: Reply with quote
I emailed Aptec and Langcourt. Aptec have not yet responded, but Langcourt said that it can be done and both barrels ca be returned to standard bore, so I assume both processes are similar.
However, neither seem to offer a head repair service from their respective websites (I haven't asked yet) so anyone got any ideas as to who I could get to do that?
redeem ouzzer
PostPosted: 07:40 - 12 May 2020    Post subject: Reply with quote
You’ll need to get the chambers machined and then the barrels decked to reset the squish and chamber volume.
Be a REAL MAN!
The last post was made 6 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.61 - MySQL Queries: 15 - Page Size: 71.65 Kb
