Running rough and now won't start
glennsr77
PostPosted: 16:01 - 10 May 2020    Post subject: Running rough and now won't start Reply with quote
Aprilia 650 pegaso 2000 cube model.
Has been running rough after working fine. Found a youtube video with possible cause https://www.youtube.com/watch?v=D_52AaLCHRE ( blanking plug missing from carb allowing air in).
So I blanked plug off again - went to start to test - no power to anything. Checked fuses, battery 12.6v , no obvious wires disconnected, earths good, so where else can I look to get the power back to the system???
jaffa90
PostPosted: 17:12 - 10 May 2020    Post subject: Reply with quote
Have you power to the fuse box when switching on?
glennsr77
PostPosted: 17:26 - 10 May 2020    Post subject: Reply with quote
Not an electrical genius so sorry if i sound thick. Where should i put the leads from my multimeter to test this?
glennsr77
PostPosted: 20:42 - 10 May 2020    Post subject: Reply with quote
OK - I took each fuse out in turn and put the -ve from the multimeter to the battery and the +ve from the meter to the fuse terminal. Results- no voltage at two of the fuses but 12.4 v at one on both sides of the terminal.
Says in manual - A) 20 A fuse (yellow colour) - from battery to: key switch, voltage regulator, cooling electrofan. B) 15 A fuse (light blue colour) - from key switch to: all light loads. C) 7.5 A fuse (red colour) - from key switch to: ignition, starting safety logic.
The only one with voltage showing is fuse C.
jaffa90
PostPosted: 21:13 - 10 May 2020    Post subject: Reply with quote
Have you upset any connector blocks around where you was playing?
glennsr77
PostPosted: 21:18 - 10 May 2020    Post subject: Reply with quote
Don't think so - everything still seems connected - just bike is completely dead.
sickpup
Old Timer
PostPosted: 21:24 - 10 May 2020    Post subject: Reply with quote
I'm amused that that video was uploaded the day I said on here that a Pegaso misfire was caused by a missing carb balance point cap.
Search sickpup and Pegaso if you dont believe me, BCF has a very wide reach.
The last post was made 6 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 49.86 Kb
