| TCFA |
 TCFA Trackday Trickster
 Posted: 13:34 - 10 May 2020 Post subject: Help with hose change, and botched screw in airbox |
Hi everyone
CBR600F is the bike. 2002 FI model (sometimes called F2, or F4i).
Trying to change the coolant hoses to a sparkly new silicon set. All drained and flushed without any problem. Some of the hoses easy enough. But trying to get to the hoses on the back of the engine block, man that is HARD on this bike!! Any tips??
Got them all off bar one, short fat pipe runs from low down back of block to water pump. Doesn't help that the jubilee clip is spun round so even harder to reach to get a screwdriver to. And getting everything back on will be hideous!
I had the tank right up but will remove it to try again (as am changing it anyway) so maybe getting those hoses out the way will give me a bit of room at the top. I tried to take airbox out (more below on that cockup .......) but realised it wouldn't give me much more room anyway. Unless I go further and take the injectors out too?? Is that the answer?
Any advice would be greatly appreciated.
Airbox - now I really botched this. What a muppet. Was unscrewing the funnels, one last screw would not budge, and I chomped the head up with my screw driver. The I tried to get it out with one of those drill bits that you set to anticlockwise and is supposed to grab the screw and extract it, but all I ended up with was a drilled out screw head and no way to undo it as the bit would bite and thread in.
Any tips on getting this out?? I really don't want to have to cart the bike to a garage (it's off the road, SORN, project/track bike) just to get a screw out, but it's not something I'm very good at it seems.
Thanks for your help as always
T ____________________ Then: Kawasaki ZZR250 > Suzuki Across 250 > Suzuki SV650 > Honda CB750
Now: Honda CBR600F and Triumph Tiger 800 XRT |
| stinkwheel |
 Posted: 13:48 - 10 May 2020 Post subject: |
The screw will probably undo now if you remove the part and get mole grips on the stump. They aren't in tight.
You need JIS screwdrivers to undo them without burring the heads. There's one in the bike toolkit. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| TCFA |
| stinkwheel |
| 1198 |
 1198 World Chat Champion
| droog |
 droog Spanner Monkey
| droog |
| sickpup |
 sickpup Old Timer
| TCFA |
| TCFA |
| TCFA |
| Pete. |
 Pete. Super Spammer
 Posted: 23:40 - 10 May 2020 Post subject: |
7mm is the most popular size for hose clip worms. Bikes sometimes have 6mm. Over-size clips might be 8mm and you get the odd round head with a screwdriver slot. 1/4" I haven't seen one for a long, long time. ____________________ a.k.a 'Geri'
| TCFA |
| TCFA |
| Easy-X |
 Easy-X Super Spammer
| stinkwheel |
| droog |
| TCFA |
The last post was made 6 years, 166 days ago. Instead of replying here, would creating a new thread be more useful? |
