How much tread is typically on a brand new tyre?
EazyDuz
PostPosted: 17:58 - 12 May 2020    Post subject: How much tread is typically on a brand new tyre? Reply with quote
Just morbid curiosity really. It would be a good way to gauge how long a tyre would last if measured every 1000 miles.
The legal limit for a bike is 1mm across the entire width of the tyre correct? And 1.6 for a car across central 3/4s?
1mm seems like nothing as well, how could that be at all safe in the wet?
PostPosted: 18:08 - 12 May 2020    Post subject: Reply with quote
You have to be going pretty damned fast to aquaplane a motorcycle tyre due to the small contact patch and round profile. Far less likely to happen that on a car. The tread is only there to clear water, it's the compound that grips.
If you think 1mm is bad, you need "visible tread" on vintage mopeds.
I don't think your idea will work though, they seem to wear down faster towards the end of their life- possibly due to heating up more? Be interesting to test though. Do report back with what you find.
Evil Hans
PostPosted: 22:39 - 12 May 2020    Post subject: Reply with quote
stinkwheel wrote:
If you think 1mm is bad, you need "visible tread" on all mopeds..
FTFY
PostPosted: 22:54 - 12 May 2020    Post subject: Reply with quote
All sorts of things happen as a tyre ages/wears. Tyre tread depth and ability to clear water is only one aspect of safety. Take two tyres of the same type on new the other worn, one will have a nice firm feel and stiff carcass, the other will be floppy as a wet rag.
Used to drive my missus mad when I'd buy new tyres to take to the runway if mine were even half-worn. I just didn't fancy running 200mph+ with the tyres at 50psi on worn carcasses. Apart from that the reduction in rolling resistance was very apparent on a new tyre.
JackButler
PostPosted: 00:06 - 13 May 2020    Post subject: Reply with quote
If you need to rely on legislation to tell you when it's come time for new tyres . . . . Then you really do need that job pays slightly above minimum wage & then cost of new tyres isn't as much of a problem.
I clean my guns with the tears of the snivelling, left wing scum.
mentalboy
PostPosted: 02:32 - 13 May 2020    Post subject: Reply with quote
I managed to aquaplane my old Zed1100 at the bottom of Haldon Hill in some vile weather, probably wasn't exceeding a ton. I don't recall my tread being overly grim and the Zed wasn't exactly the lightest of crotch rockets, luckily I was through the puddle in no time and not on a bend. Must say it was a bit of a sphincter clencher feeling the front end go light in that kind of weather.
As for the topic, I was quite surprised at just how little thickness there is on a Pilot 2 between running out of tread, hitting 'canvas' and going through. When you're illegal at 3500 miles and canvassed at 4000 it's not something you want to be ignoring for too long.
Make mine a Corona.
EazyDuz
PostPosted: 08:43 - 13 May 2020    Post subject: Reply with quote
https://thumbs.gfycat.com/TastyScarceConch-size_restricted.gif
PostPosted: 11:09 - 13 May 2020    Post subject: Re: How much tread is typically on a brand new tyre? Reply with quote
When I was playing with spreadsheets for a DIY speedo, I went particularly OCD on the accuracy to the extent of tyre wear affecting the radius for the calculation. It's going to depend on the tyre, but I'd found 7mm when new.
As an aside, I stopped being anal about it and went with 800 pulses per mile, as it was good enough and a nice round number Smile
Freddyfruitba...
PostPosted: 14:14 - 13 May 2020    Post subject: Reply with quote
FWIW, my current tyres (Michelin PR4) had 5mm on the front and 6.5mm on the back, when new.
I've done this myself with reasonable success; just enough to give me a fair idea of whether my tyres have enough tread to last going on tour or not.
blurredman
PostPosted: 14:16 - 13 May 2020    Post subject: Reply with quote
I do find it interesting that the more the tyre wears, the quicker it wears. I though perhaps that less flex in the tread would occur.
That said, I myself have just experienced a tyre that 'will need preparation for replacement soon' (like buying the tyre), has after only 500 miles suddenly become 'that tyre is borderline illegal'.
The last post was made 6 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 67.79 Kb
