HONDA CG125 - Diagnosis for no running lights?
wulfprints15
PostPosted: 14:34 - 13 May 2020    Post subject: HONDA CG125 - Diagnosis for no running lights? Reply with quote
Hi all,
Almost got my CG all back together. Have fixed the ignition and indicator faults I was having when I last posted here.
I've learnt a bit about wiring doing this but I've come up against a problem I just can't figure out.
I've lost headlight, tail light, side light. I understand the power for these comes from a dedicated AC circuit coming straight from the reg/rec. I've tested the battery voltage when running and it rises and falls with revs showing that this works.
So it charges the battery just fine but I've got no running lights.
Does anybody have any clue on a good route to diagnose and eventually fix this issue? I've looked in my Haynes manual but it doesn't seem to have much info on the matter.
I'm running tests with the headlight and side light out of their housings. Will this cause an issue with earthing? I would've thought not because they've got earth wires going to the bike but thought to check.
PS. It's a 1995 BR-S/T
PostPosted: 15:22 - 13 May 2020    Post subject: Reply with quote
Are all the bulbs blown? They can have cascade bulb failures.
Check the ballast resistor is intact and making contact with earth (not sure where it is, on the end of the pink wire).
As I recall, they have a split charging coil so if the battery is charging, the stator coil is probably ok. That leaves you with a wiring/switch problem. Do you have a multimeter?
The tail light and the headlight are on two different circuits from the switch and use different frame earths so if they are all gone, I'd suggest it probably isn't the wiring beyond the switch, it's likely either the switch itself or the wiring between the generator and the switch.
Specifically the yellow wire.
First double check you are getting an output. Find the yellow wire coming up from the generrator (left side of engine), measure AC volts between the yellow and earth with the engine running. You'll probably get a wildly fluctuating AC voltage. If no output, you may have an issue witht he coil or its wiring.
Now find where it attaches to the headlamp switch. Should have the same reading there. If not, the wire's broken/detached somewhere en-route.
Now check the brown wire from the switch with the switch on. Again, should be the same reading. If there's nothing there, it's the switch. If there is, the light should be coming on.
EDIT: For others, decent wiring diagram here: https://i.pinimg.com/originals/72/fe/53/72fe537b391e99e7ebb15e3ef83c071b.jpg
wulfprints15
PostPosted: 17:02 - 13 May 2020    Post subject: Reply with quote
Thanks for message.
I will double-check the resistor. On my bike it's under the seat, not sure if this is stock as my bike has been heavily modified by previous owner.
I do have a multimeter yes. I've just checked the yellow wire.
The voltages coming from it are interesting:
V when yellow wire disconnected from wire going to lighting switch: 11.5V
V when connected but lighting switch off: 9V
V when connected and lighting switch on any position other than off: 0.5/0.6V
This would suggest there is a short or incorrectly plugged-in wire somewhere, would it not?
I've double and triple checked the wires coming from the headlight and sidelight and they seem fine to me other than the grounds not going quite where the diagram suggests (like I said, heavily modified), but still going to a presumably suitable ground.
I'm hesitant to start troubleshooting the switch itself because I've not touched it at all and the bike has been sat in the garage doing nothing. Seems unlikely the switch would just fail but then I suppose I've seen cars/bikes do stranger things.
I'm looking at wires specifically because this problem seemed to start when I started trying to cram the wires back in the headlight unit, so I'm guessing I've just cracked a wire there or maybe plugged one into the wrong terminal.
God, I hate wiring.
PostPosted: 17:41 - 13 May 2020    Post subject: Reply with quote
That does seem like a short somewhere.
Take the bulbs out and check for continuity (resistance) between the blue, white and brown wires coming out of the switch and earth, they should all be an open circuit with the bulb out. If there is low resistance, that's the wire you need to check.
Bulb holders for instrument back lights can short out to the backing plate if they are connected up the wrong way round (so the outside of the holder is live).
wulfprints15
PostPosted: 19:18 - 13 May 2020    Post subject: Reply with quote
Having checked the continuity of those wires I've found them all to be correct. They're all open when the switch is in their position and closed when otherwise.
I checked the tail/brake light though and it was a different story. No continuity or voltage from brown wire at all (which I believe is for the tail light). Brake light wire though spikes up to 25/28V when pressing down either brake, is this normal?
PostPosted: 19:33 - 13 May 2020    Post subject: Reply with quote
I wonder if you misunderstood. I was suggesting you set your meter to measure resistance in ohms. When there is an open circuit, it will read very high and when there is a short circuit it will read very low (as if you touched the probes together).
If the bulbs are removed, engine is off and the switch is off, measuring resistance between the brown, white and blue wires at the first connector after the switch and earth (any bare metal on the frame and engine) should be open circuits. If you get a low resistance, there is a short in that wire.
PostPosted: 20:20 - 13 May 2020    Post subject: Reply with quote
The brake light should have battery voltage (so 6v-ish) measured in volts DC, not AC.
wulfprints15
PostPosted: 21:33 - 13 May 2020    Post subject: Reply with quote
Okay yeah, I think I understand now. So because there's continuity with ground that means that all the voltage that should be going to the bulbs is just going to the ground?
So the tail light is DC, are any of the other lights DC? I'm just confused because the tail light comes off the same connector as the pilot light (which I thought was AC) and it's even connected to the headlight too in the lighting switch.
PostPosted: 22:28 - 13 May 2020    Post subject: Reply with quote
Brake, flasher, horn and neutral are DC. Tail, head, pilot and speedo lights are AC.
Easy-X
PostPosted: 00:36 - 14 May 2020    Post subject: Reply with quote
Seems to be a lot of this sort of thing lately. Everyone in a rush to get on the road now the rules are changing?
wulfprints15
PostPosted: 00:37 - 14 May 2020    Post subject: Reply with quote
I've been working on the bike since before lockdown was imposed, unfortunately
wulfprints15
PostPosted: 01:23 - 14 May 2020    Post subject: Reply with quote
Okay, thanks. I must have my speedo lights plugged into a DC battery source as they come on when the ignition is on but the engine is off.
I think I've got a bit to go on for tomorrow, thanks so far
PostPosted: 01:50 - 14 May 2020    Post subject: Reply with quote
Speedo lights, pilot light and tail light should all be connected to a brown and a green wire. If they are coming on with the ignition, they are probably plugged into the black multi-socket by mistake. Given what you're seeing, I'd check this first. There should be a multi connector with 4 brown wires and another one with 4 black wires.
Actually. None of the connectors in the back of the headlamp should have mixed wire colours attached. Honda are good this way. Connect the same colours together.
wulfprints15
PostPosted: 15:55 - 14 May 2020    Post subject: Reply with quote
Okay, I've managed to make a bit of a breakthrough after much irritation today.
Discovered that the yellow wire coming from regulator is connected to the brown wire terminal coming from light switch and going to pilot/tail/speedo even when the yellow wire is disconnected from the light switch.
Turns out the wire coming from the tail light is grounding somewhere on the frame. This explains a lot. I'll take the tank off and figure out where it's doing this and hopefully it'll be relatively easy to fix.
With the tail light unplugged every other light functions perfectly as it should.
wulfprints15
PostPosted: 17:40 - 14 May 2020    Post subject: Reply with quote
Fuel tank locating tongue was clamping down on the loom. Surprised it didn't do more damage to be honest.
I knew it'd be something silly but I never would have thought of that!
Waiting on a new brake light unit (arriving tomorrow), can post pics of bike then.
Last question, any tips on cramming all these wires back in the headlight unit?
PostPosted: 18:45 - 14 May 2020    Post subject: Reply with quote
Round in circles towards the outside of the shell. Leave space in the middle for the bulb holder. Like a birds nest.
wulfprints15
PostPosted: 20:54 - 15 May 2020    Post subject: Reply with quote
All fixed and back together! Thanks very much stinkwheel for your help.
I'm still waiting on a new seat (brown and without a hump which makes it too small for me) but other than that it's all finished.
Here are some photos as promised.
wulfprints15
PostPosted: 20:55 - 15 May 2020    Post subject: Reply with quote
https://imgur.com/a/Jq7QLxm
wulfprints15
PostPosted: 20:56 - 15 May 2020    Post subject: Reply with quote
I don't know if attaching images is working or not so here's the link
The last post was made 6 years, 167 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 112.22 Kb
