Try-tension monkey chain things
Gazz
PostPosted: 10:16 - 15 May 2020    Post subject: Try-tension monkey chain things Reply with quote
What's your opinion of these?
Worth the money or a worthless gimmick?
ThunderGuts
PostPosted: 10:30 - 15 May 2020    Post subject: Reply with quote
I've looked at them but I can't justify it for something that's so simple to measure with a rule. I like the concept, but I also like simple things and a bit of metal with markings on it is even simpler . . .
TG.
I've never had the problem that they purport to solve. Nice work if you can find it, making crap that people don't need but will buy anyway. Much like Funko Pops.
wr6133
PostPosted: 10:56 - 15 May 2020    Post subject: Reply with quote
I had to google that Laughing
https://www.emp.co.uk/p/ice-cube-with-impala-%28pop-rides%29-vinyl-figur-81/456385.html £36 Shocked I know places you can get blown for a fair bit less than that.
ThatDippyTwat
PostPosted: 12:36 - 15 May 2020    Post subject: Reply with quote
This is something anyone with a clue can set by eye/feel pretty soon after they get the bike. I don't see the need to be honest.
PostPosted: 13:03 - 15 May 2020    Post subject: Reply with quote
It's not the MOST pointless thing I've ever seen but it certainly up there near the top.
Lets be honest, if you need that to set your chain tension you shouldn't be doing it yourself anyway. It's probably the simplest job in motorcycle maintenance.
PostPosted: 13:06 - 15 May 2020    Post subject: Reply with quote
Oh FFS. Laughing
https://www.emp.co.uk/dw/image/v2/BBQV_PRD/on/demandware.static/-/Sites-master-emp/default/dwc0c99c43/images/4/5/6/3/456385a2.jpg?sw=1000&sh=800&sm=fit&sfrm=png
c_dug
PostPosted: 13:08 - 15 May 2020    Post subject: Reply with quote
I have neighbours and friends that could use it, so I wouldn't say it's the biggest waste of money, it just depends who for.
Personally, I find wheel alignment the bigger struggle when adjusting chains. If they made a really simple widget for that I'd probably go for it.
That said, I pretty much solely go for shafties these days, so problem solved for me!
ThunderGuts
PostPosted: 13:49 - 15 May 2020    Post subject: Reply with quote
They did; single-sided swingarms. Smile
TG.
c_dug
PostPosted: 13:54 - 15 May 2020    Post subject: Reply with quote
Funnily enough, the only single sided chain driven bike I've ever owned basically never needed it's chain adjusting. Maybe once in the entire time I owned it!
yen_powell
PostPosted: 20:47 - 15 May 2020    Post subject: Reply with quote
It's like every bike I've ever had that you could get at the headlight bulbs easily never blew a bulb, the others of course............
XT1200Z and a DR350 in bits
PostPosted: 21:45 - 15 May 2020    Post subject: Reply with quote
I've got one. It's still in its packaging.
notbike
PostPosted: 22:17 - 15 May 2020    Post subject: Reply with quote
Their chain cleaner is really shit by the way.
It evaporates very quickly, quicker than you can wipe the cunting road shit off, so unless you are constantly spraying and using bottles and bottles of the shit, it literally just relocates the gunk to another location that then immediately dries on in the new location.
It's just fucking terrible.
The orange muc off shit is decent.
The best is that WD-40 brand chain cleaner though (not actual WD-40), it's the best. It rips everything off the chain, and then dries in a decent time frame.
So anyway fuck their chain tool whatever it is.
Anyway, going to continue eating pizza.
Easy-X
PostPosted: 22:55 - 15 May 2020    Post subject: Reply with quote
I think I saw these at Halfords once. "Really?" ...and on I walked. I suppose if you're a pro mechanical chewing through jobs at a rate of knots it's something to give the apprentices if you can't be bothered to train them.
Rulers? Are they that hard to use?
davebike
PostPosted: 08:43 - 16 May 2020    Post subject: Reply with quote
I adjust lots of chains well it is part of my work!
If you need one of those you need a little training on how to look after you bike !
Dave
NC750Xdct + others at work !
[email protected]
kolu
PostPosted: 10:44 - 16 May 2020    Post subject: Reply with quote
made for monkeys
1198
PostPosted: 14:27 - 16 May 2020    Post subject: Reply with quote
I’d agree with this - neither my 1198 (10k miles in 4 years) nor my 1299 (10,500 miles in three years) have needed their chains adjusting, despite both having quickshifters which are / were regularly used. It’s not that I don’t check them either, they just seem ok. The chain is well looked after though I’d say, lubricated regularly.
ThatDippyTwat
PostPosted: 15:32 - 16 May 2020    Post subject: Reply with quote
My Viffer came fitted with a cheap, non O-ring chain, presumably because of the cost of 530 chains - needed adjusting every other week. Chucked an RK O-ring one on there with a JT front and Renthal rear sprockets that came with the bikes, and after the initial bedding in, it's not needed adjusting much at all. I do give it a tweak back and forth when I oil it and do tyre pressures as unsticking a stuck eccentric is decidedly not fun and not something I wish to repeat. It only takes maybe a minute to undo the pinch bolt, move eccentric back and forth, and do the pinch bolt back up.
The last post was made 6 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 98.86 Kb
