ZX10R 2004 misfires low RPM
Calumh96
PostPosted: 10:12 - 17 May 2020    Post subject: ZX10R 2004 misfires low RPM Reply with quote
Im looking at checking out a fairly cheap ZX10R over the next few days.
The owner says he recently have a crank speed sensor fitted and it hasn't been set up with the power commander.
He says below 4k revs the bike misfires but past that runs as it should up to redline.
He says it wasn't like this before he fitted the sensor. Could be plugs coil or over fuelling.
Thoughts? what am i really looking at here?
Current - K1 GSXR 600
Previous - K5 SV 650, ZR750, Lexmoto Adrenaline, HondaCBR125R, Lexmoto Arizona, Senke x6, Yamaha YZF125R, AJS DD125e, Hyosung Gv125, Jinlun JL125
PostPosted: 10:32 - 17 May 2020    Post subject: Reply with quote
...has he tried going back to before he fitted the sensor.
"It worked before I changed this sensor, must be the wheels."
Calumh96
PostPosted: 10:41 - 17 May 2020    Post subject: Reply with quote
My first thoughts though I'm not sure if the sensor is a must?
The question is why was the sensor fitted normally a mechanical part is fitted to rectify an original problem.
PostPosted: 14:14 - 17 May 2020    Post subject: Reply with quote
Maybe the new sensor is faulty. But yes, you'd need that to start the bike.
Me, I'd swerve that.
sickpup
Old Timer
PostPosted: 09:21 - 18 May 2020    Post subject: Reply with quote
A crank position sensor (CPS)on a modern bike is normally fixed i.e non-adjustable and I'm pretty certain you don't need to set them up with a Power Commander unless they now have variable timing maps for the spark.
The only reason to replace one is if the bike doesn't start and it definitely needs one as otherwise the bike won't spark so won't start.
If it is the CPS it it will show as a fault if you put it into dealer mode or will at least show as a previous fault.
Calumh96
PostPosted: 15:19 - 18 May 2020    Post subject: Reply with quote
Update as i viewed the bike today
The bike runs perfectly as soon as you go above 4.5k RPM
Below 4.5k the bike pops and bangs and is quite boggy and underpowered
The owner says the bike was sat and then wouldn't start. The garage replaced the battery and crank speed sensor and the bike has been like this since.
The bike does have a quick shifter, aftermarket can and a power commander. The power commander has not been set up since the new can was fitted but ran fine with the can before this problem started
Yes the owner could take the bike back to the garage after lockdown but then the bike would be worth a lot more and currently I'm looking at getting the bike for at least 1k less than they value at.
sickpup
Old Timer
PostPosted: 08:32 - 19 May 2020    Post subject: Reply with quote
Buying a bike at a £1000 discount that may require over £1000 to repair doesn't sound much like a bargain to me.
PostPosted: 11:34 - 19 May 2020    Post subject: Reply with quote
Agreed. There are PLENTY of litre sports that are working nice and won't need any work like that, could be £10, could be £2k.
I personally wouldn't risk it.
The last post was made 6 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 56.83 Kb
